Acer A315-34-P1SQ Huaqin NB8609 Rose GL NB8609 MB Fault
  • menderland
    • May 2023
    • 10
    • Greece
    Any help would be aprreciated on the following (Apollogises for any language related mistakes).
    As the title states I have a Aspire a315-34 with a NB8609_PCB_MB_V4 board. The laptop does not powers on. I have 5V present on L1 and 3.3V on L2. When I plug in the charger, I see, with the thermal camera, that L8 mosfet rises temperature, cools down and then the ethernet controler glows.
    Any suggestions on how to proceed would be helpful.
    Schematic ---> https://www.badcaps.net/forum/showth...55#post1216455
    Last edited by Vesko356; 06-26-2023, 01:20 PM. Reason: Added platform name and link to the schematic.
  • mon2
    • Dec 2019
    • 14660
    Re: Acer A315-34-P1SQ Fault
    Remove all power. Meter in resistance mode. Check the resistance to ground of L8.
    • menderland
      • May 2023
      • 10
      • Greece
      mon2 thank u for spending time reading & posting.
      Measurements are:
      Vin floating between kΩ and MΩ
      ΕΝ: 162kΩ
      PGOOD: 9.9kΩ
      VCC: 1,54MΩ
      LDO3:0.78MΩ
      FF:19.15kΩ
      BOOT: 14.7MΩ
      LX (INDUCTOR): 78Ω
      VOUT:78.2Ω
      • mon2
        • Dec 2019
        • 14660
        Can you link the schematic if available in the schematic forum?
        VOUT:78.2Ω
        This is a low resistance but may be normal if the regulator is with a low output voltage.
        • menderland
          • May 2023
          • 10
          • Greece
          Thank u for following. I cannot say I really understand. Unfortunately, the schematic is not available in the forum (i think only the cad file I was able to find). I was able to find it from another source however but as a newbie I need to read how to understand it (lots of videos and reading).
          • mon2
            • Dec 2019
            • 14660
            Post the topside markings of the mosfet that is heating up so we can locate the same in the schematic.
            • Vesko356
              VIP Moderator
              • Aug 2018
              • 4386
              • Bulgaria 🇧🇬
              Originally posted by menderland
              Unfortunately, the schematic is not available in the forum (i think only the cad file I was able to find). I was able to find it from another source...
              If the schematic for your machine is not available here at Badcaps but you are able find it elsewhere, you can share it at the Schematic sub-section, and link the thread to this topic.
              Become a Badcaps supporter
              Thanks to all supporters.​
              • menderland
                • May 2023
                • 10
                • Greece
                mon2 photo attached
                • menderland
                  • May 2023
                  • 10
                  • Greece
                  vesko356 hello. schematic is viewed by web explorer as is someones shared drive file. no download or print is available.
                  • mon2
                    • Dec 2019
                    • 14660
                    I think that we are referencing the same schematic but mine is locked to the paid viewer and service.
                    The part that is heating up is not a mosfet but the actual switching regulator IC @ PU202. The output inductor is @ PL201 and is nearby the same part.
                    This leg of the circuit is supposed to output 3v3 (+V3P3A) and this resistance is low for this voltage.
                    This low resistance could be linked to a defective capacitor or perhaps even the main CPU.
                    Would you have an adjustable power supply that can output 1 volts ? What is the max current supported by the power supply ?
                    • Vesko356
                      VIP Moderator
                      • Aug 2018
                      • 4386
                      • Bulgaria 🇧🇬
                      Share the link here.
                      • menderland
                        • May 2023
                        • 10
                        • Greece
                        mon2 I have an adjustable power supply with max current of 5A.
                        • menderland
                          • May 2023
                          • 10
                          • Greece
                          schematic diagram file for Acer A315 Huaqin NB8609 Rose GL NB8609 MB
                          link: https://drive.google.com/file/d/1555...74lSlwD4y/view
                          • Vesko356
                            VIP Moderator
                            • Aug 2018
                            • 4386
                            • Bulgaria 🇧🇬
                            It's available at the Schematic sub-section ---> https://www.badcaps.net/forum/showth...55#post1216455
                            I'll add the link in post #1
                            • mon2
                              • Dec 2019
                              • 14660
                              Re: Acer A315-34-P1SQ Acer A315 Huaqin NB8609 Rose GL NB8609 MB Fault
                              Remove all power / no battery.
                              Dial up the DC power supply to 1 volt (not higher) and max current you can support.
                              Inject this DC power supply rail (red lead) onto the inductor you noted as Vout = PL201. Black lead to ground.
                              As you do this, someone should heat up. Locate the component that is heating up. Ideally it will be a bad / partially shorted capacitor. Do also review if the CPU is warming up under this setup.
                              • menderland
                                • May 2023
                                • 10
                                • Greece
                                Re: Acer A315-34-P1SQ Huaqin NB8609 Rose GL NB8609 MB Fault
                                mon2 tnx for keeping up. 21mA are drawn and nothing heats up (thermal camera).
                                • mon2
                                  • Dec 2019
                                  • 14660
                                  Ok. Current is too low to heat up the component.
                                  Carefully, measure the voltage to ground of pin # 6 = EN (for enable) on PU202.
                                  We want to know if this power rail is being enabled or not as it heats up.
                                  Also, what is the voltage to ground at
                                  a) Vout = PL201 inductor ?
                                  b) V3P3A_VCC = pin # 9 (Vcc) of PU202 = power rail for this switching regulator
                                  • menderland
                                    • May 2023
                                    • 10
                                    • Greece
                                    EN Voltage:3.250V(pin #6)
                                    PL201:3.271 V
                                    VCC:3.256 V
                                      Acer Aspire A315 series Huaqin NB8609 Rose GL Laptop Boardview
                                      Acer Aspire A315 series Huaqin NB8609 Rose GL Laptop Boardview...
                                      10-29-2024, 03:38 AM
                                      09-06-2024, 05:27 AM
                                      Acer Aspire Acer Aspire 7 Charcoal Black Notebook 7 Specification for Upgrade or Repair
                                      This specification for the Acer Aspire Acer Aspire 7 Charcoal Black Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Acer Aspire 7 Charcoal Black boardview and Acer Aspire 7 Charcoal Black schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
                                      09-07-2024, 05:00 AM
                                      Acer Swift Acer Swift 3 Ultraschlankes Notebook Notebook 3 Specification for Upgrade or Repair
                                      This specification for the Acer Swift Acer Swift 3 Ultraschlankes Notebook Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Acer Swift 3 Ultraschlankes Notebook boardview and Acer Swift 3 Ultraschlankes Notebook schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that...
                                      Acer Nitro Acer Nitro 5 Black Notebook 5 Specification for Upgrade or Repair
                                      This specification for the Acer Nitro Acer Nitro 5 Black Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Acer Nitro 5 Black boardview and Acer Nitro 5 Black schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                      09-07-2024, 04:10 AM
