USB-C question
    USB-C question
    I have a motherboard that I am trying to repair. I have a know good USB-C charger with a light on it plugged into a USB-C ammeter. When I plug this cable combination into the board the light stays on the charger but the ammeter does not turn on.
    Does that sound like the port is bad? Is there a way I can check the continuity on the port, or will that matter?
    I posted this in the wrong forum. Can someone move this for me?
    Last edited by Bob_Crachet; 06-20-2023, 02:12 PM. Reason: I need to move this to the correct forum
    Re: USB-C question
    Done, thread moved from "Schematic requests" section.
    Become a Badcaps supporter
    Thanks to all supporters.​
      Re: USB-C question
      A well behaved USB Type C port will permit the USB Type C meter to display the power on default voltage of 5 volts + the current draw. This current draw may be any value from 0mA or higher.
      If the display on the meter goes dark, there is a hardware fault on the Type C connector.
      Which motherboard / widget are you testing?
      If you are mating with a removable paddle board / cable? If yes, remove it from the main board and test again.
        Re: USB-C question
        Thank you for the reply mon2.
        Would the ammeter still turn on if I removed it from the motherboard and then plugged it into just the port? I removed the ammeter and just plugged the USB-c charging cable into the port and tried measuring the voltage on the pins. At one point I was getting about 3.3v on one of the pins but now have been unable to repeat that. Would you say that the port is bad? I will remove one that I know works and test that as well. Thanks for your help!
