CPU Hot when plugged in - Inpiron 15 3511 P112F LA-L241P
  • willis6732
    • Feb 2023
    • 41
    Hey Everyone, This is my first post here. I opened a repair shop a few months ago and happy to have this as a resorce.
    Ive had a laptop come in with a broken display. I was able to get some fan spin and funky colors on the display. I orderred a display and now that the display has arrived the laptop has another problem.
    The issue happening causes symtoms similar to a shorted CPU but i am unsure that is the issue.
    When i plug in the motherboard to DC (Nothing else connected) the two coils Feeding the CPU get hottest as well as the CPU.
    https://photos.app.goo.gl/KTrViNjkwLM6sAdY6
    https://photos.app.goo.gl/xJSKTSKY7nE7mTx28
    When i take the Heatsink off the CPU, it seems to get hot evenly and no hot spots
    https://photos.app.goo.gl/kcrKUXuNgS4jNLec9
    https://photos.app.goo.gl/eVAxmR7nCRdhKxy39
    The reason i am unsure that its a short CPU is because if i apply about 1v to the CPU coils there is no voltage drop and no Amps flowing. If i increase to 1.5V, I still get no voltage drop and 20ma now flows into the board.
    THis makes it seem like it is not a short... Or am i wrong?
    Kevin
  • mcplslg123
    • Jun 2015
    • 7262
    • india
    Re: CPU Hot when plugged in - Inpiron 15 3511 P112F LA-L241P
    Injecting more then 1V is a clear no no. Chances of you having shorting in 19V rail is very high due to perhaps high side fet shorting. Check resistance to GND on CLR.
    • willis6732
      • Feb 2023
      • 41
      Thanks for the heads up, i will keep my test voltages lower.
      There is no short in main rail. 30MegaOhm.
      All the high side transistors seem fine. The low side transistor on CPU rail seem ok too.
      CPU rail resistance to ground is about 60 Ohms.
      WHat did you mean by "check resistance on CLR". Is that current load resistor on the main rail?
      Could it be an issue with the IC chip circuit thats controlling the transistor on the CPU Circuit?
      Confused if this is a shorted CPU or not
      Any guidance on what to check next?
      Hopefull i can figure this out soon, incase i need to return the replacement LCD ��
      Thank you
      • mcplslg123
        • Jun 2015
        • 7262
        • india
        CLR-Current Limit Resistor-so you are right. A hot SOC(CPU+PCH) is a bad symptom. Usually SOC gets killed when one of the high side mosfet is shorted and thereby leaking 19V to cpu. It rarely survives after that.
        Another reason is shorting in +3V LDO. This often leads to a shorted PCH.
        Observe carefully which die of SOC is heating. Check resistance to GND on +3V LDO/Bios chip pin 8.
          DELL Inspiron 3511 Notebook 3000 Specification for Upgrade or Repair
          This specification for the DELL Inspiron 3511 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 3511 boardview and 3511 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL Inspiron 3511...
          09-07-2024, 06:38 AM
          09-07-2024, 06:21 AM
        • Djamalhan
          Dell 15 3511 (P112F) (LA-L24EP) rev 1.0
          by Djamalhan
          Hi everyone ! looking for bios .. working .
          thanks in advance
          Dell 15 3511 (P112F) (LA-L24EP) rev 1.0...
          01-26-2023, 08:36 AM
