Asus UX534FT No ALW voltages
  • koby058
    • Jan 2017
    • 387
    • israel
    Hi
    The owner replaced an NVME stick since then the laptop not powering on.
    Probably he did not disconnect the battery but i don't know for sure.
    Main power rail is present with 20v but not other power is present.
    When looking with thermal cam i saw the 2N = chip and some chip under the nvme is getting warm.
    upon removal of the "other" chip. the 2N (RT8249CGQW) chip is not getting warm any more.
    the 2N have power entering its VIN pin 12 20V and its LDO3 pin3 is outputting 3.3v.
    but both enable pins voltages are not present. EN2 100k ohm, EN1 10k ohm
    attached a schematic that i found online i think it is only similar not exactly the one.
    Can you please help me inspect it ?
    • 21932
    Re: Asus UX534FT No ALW voltages
    Schematic copied to new thread so that others can find it when using the forum search -> https://www.badcaps.net/forum/showthread.php?t=119891
    Reminder: rules and organization of this section
    https://www.badcaps.net/forum/showthread.php?t=117483
    • mcplslg123
      • Jun 2015
      • 7262
      • india
      Very likely EN1/EN2 will come only after triggering the motherboard.Check resistance of 3V LDO/5V LDO rails, then move on to check requirements of SIO. Is it charging battery? What is the standby consumption on dc supply?
      • koby058
        • Jan 2017
        • 387
        • israel
        Hi
        Not charging
        0 consumption on power supply
        resistance is pretty high on all coils
        it is a BGA SIO so it is super hard to test with out boardview
        Any other ideas ?
        • Sephir0th
          • Oct 2020
          • 1289
          Could be worse. Take a look at PU8803, a dual load switch with common footprint. Here you can check whether the 3V for the EC are enabled and outputted at all
          FairRepair on YouTube
          • koby058
            • Jan 2017
            • 387
            • israel
            Hi
            This is super funny. it appears that the "other" chip that i removed is APL3533 which is the load switch.
            • Sephir0th
              • Oct 2020
              • 1289
              You're likely dealing with a shorted output of +3VA_EC then, which almost always means shorted embedded controller...
              • koby058
                • Jan 2017
                • 387
                • israel
                Well, ATM the L3533 is out of the board and i measure its output pins and it is having 0.02 ohm So i guess its the end of the line for me. i dont have an EC programmer.
                • koby058
                  • Jan 2017
                  • 387
                  • israel
                  Do you know if any body sell those pre ptogrammed?
                  • mcplslg123
                    • Jun 2015
                    • 7262
                    • india
                    Sorcing a reliable BGA ec is bit tough. My experience so far is pretty bad.Most of the time EC cant be programmed-they are a nightmare to program thru JTAG.May be need to learn more.
                    • koby058
                      • Jan 2017
                      • 387
                      • israel
                      Hi
                      Thanks for your reply, i did replace the chip and it was auto programmed. now the laptop turns on and boot to windows.
                      The issue is that it is not charging and on windows it showing the battery have 225% power
                      Can someone please help me debug this ? the charger IC is BQ24780s
                      • Sephir0th
                        • Oct 2020
                        • 1289
                        Hi
                        Start with the DC-IN Mosfets maybe one of them is internal shorted.
                        • koby058
                          • Jan 2017
                          • 387
                          • israel
                          Both mosfets have Mega ohms between: s to d, s to g, d to g
                          SDA is 3.26v
                          SCL is 0.38v
                          trying second battery (NEW)
                          when on battery, laptop does not turns on but when turning it on with battery connected then removing the AC adapter the laptop remains on.
                          • mon2
                            • Dec 2019
                            • 14673
                            Hey! Finally watched the last episode of Fauda. Doron, what a ham!! Always leaving enough room to have another season. Love it.
                            SCL is 0.38v
                            Too low. Remove the battery. Does this SCL voltage return to normal ~3v ?
                            If not, locate the ESD diodes that should be nearby the battery connector. It will need to removed.
                            • mcplslg123
                              • Jun 2015
                              • 7262
                              • india
                              SCL pulled low may be even for a defective EC.However, do check the esd diodes and resistors in between battery connector to SIO for SCL.
                              • koby058
                                • Jan 2017
                                • 387
                                • israel
                                Mon2 i am happy you enjoying Fauda so much
                                SCL still low without batt. when you say diode do you mean PD6001? if yes it is not soldered on this board
                                resistance of PR6002 is 330 ohms
                                resistance of SCL line to GND is 640 ohms
                                mcplslg123, this is a new EC chip i bought from SHUMS.
                                what do you think guys ?
                                • mon2
                                  • Dec 2019
                                  • 14673
                                  Locate the required pull up resistors for these SCL and SDA pins. Being an open drain interface, there must be a pull up resistor on each pin to create the soft high state.
                                  Once found, check the voltage to ground on each side of this pull up resistor.
                                  Then remove all power and confirm the resistance of this resistor. Often the recommended pull up resistance is 2k2 but can be any value upto 10k (from our testing on some designs). Either way, it must not be missing.
                                  • koby058
                                    • Jan 2017
                                    • 387
                                    • israel
                                    Thanks, i will try that and post, do you see this resistor in schematics ?
                                    where should it be in your opinion? near EC, Charger IC, batt conn ?
                                    • mon2
                                      • Dec 2019
                                      • 14673
                                      I do not have the exact schematic for this logic board but found a similar one.
                                      Review R3013 and R3020. Confirm they are present and check their voltage to ground on each pin.
                                      • koby058
                                        • Jan 2017
                                        • 387
                                        • israel
                                        Hi
                                        On R3013, there is 3.3n on the right side and 0.46 on the left side
                                        resistance on resistor is 4.5K ohms.
                                        right side to Ground 5.2k ohms
                                        left side to groung 800K ohms
                                          ASUS ZenBook UX534FT-AA283T Notebook 15 Specification for Upgrade or Repair
                                          This specification for the ASUS ZenBook UX534FT-AA283T Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the UX534FT-AA283T boardview and UX534FT-AA283T schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                                          09-06-2024, 06:20 PM
                                          ASUS ZenBook UX534FT-A9143T Notebook 15 Specification for Upgrade or Repair
                                          This specification for the ASUS ZenBook UX534FT-A9143T Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the UX534FT-A9143T boardview and UX534FT-A9143T schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                                          09-06-2024, 02:34 PM
                                          ASUS ZenBook UX534FT-A7621TS Notebook 15 Specification for Upgrade or Repair
                                          This specification for the ASUS ZenBook UX534FT-A7621TS Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the UX534FT-A7621TS boardview and UX534FT-A7621TS schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or...
                                          09-06-2024, 01:21 PM
                                          ASUS ZenBook UX534FT-A9175T Notebook 15 Specification for Upgrade or Repair
                                          This specification for the ASUS ZenBook UX534FT-A9175T Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the UX534FT-A9175T boardview and UX534FT-A9175T schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                                          09-06-2024, 12:20 PM
                                          ASUS ZenBook UX534FT-A9011T Notebook 15 Specification for Upgrade or Repair
                                          This specification for the ASUS ZenBook UX534FT-A9011T Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the UX534FT-A9011T boardview and UX534FT-A9011T schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                                          09-06-2024, 11:30 AM
