DELL INSPIRON 5593 FDI45 la-j091p no power on
  • koby058
    • Jan 2017
    • 387
    • israel
    Hi all, kindly asking for advise.
    owner tried to install a stick of ram and the does laptop does not powers on.
    the only schematic i found is here
    the charger IC is ISL 95522H and it is getting very hot.
    without battery
    DCIN is 17.4V
    ACIN is 2.4V
    VDD is 0.4
    CMSRC 0
    main power rail is missing power.
    Do you think charger IC is dead ?
  • garytech14
    • Nov 2022
    • 7
    • philippines
    Re: DELL INSPIRON 5593 FDI45 la-j091p no power on
    Sir you check the main Func = 3.3VALWP / 5VALWP if shorted
    • koby058
      • Jan 2017
      • 387
      • israel
      resistance on all coils is pretty high except for the near GPU coils which is about 3 ohms
      • mon2
        • Dec 2019
        • 14660
        Measure the voltage to ground on each pin of the dual diode at PDB01.
        Also at each pin of the DCin mosfet at PQB11.
        Source (1-2-3)
        Gate (4)
        Drain (5-6-7-8)
        • koby058
          • Jan 2017
          • 387
          • israel
          Hi mon2 , thanks for your reply and help
          Buy chance can you point me the the area of those components, the brdv i have is not correct
          • mon2
            • Dec 2019
            • 14660
            See attached. Found this (if it is correct) by searching for '5593'.
            • koby058
              • Jan 2017
              • 387
              • israel
              Found this diode butbit is a single diode
              Do you think this is it?
              I think that The suggested schematics is not exactly for this board
              • mon2
                • Dec 2019
                • 14660
                PQB11 = mosfet and should be 8 pins.
                Post a pic of your logic board. Perhaps have a suitable BV file but it is locked to my sub but it may help.
                • koby058
                  • Jan 2017
                  • 387
                  • israel
                  I was talking about the double diode
                  Here is the board pics with the best light i have
                  • mon2
                    • Dec 2019
                    • 14660
                    Which double diode? Can you point to it on the motherboard?
                    • koby058
                      • Jan 2017
                      • 387
                      • israel
                      Source (1-2-3)
                      Gate (4)
                      Drain (5-6-7-8)
                      I think we have a confusion.
                      Here you ask me to measure voltage on the dual diode, and i called it double diode. but i cannot find such dual diode
                      instead i have found a single diode on PDB01. as visible in picture on post #7.
                      • mcplslg123
                        • Jun 2015
                        • 7262
                        • india
                        As per post#1, VDD on charger ic is 0.4V .What is the exact resistance here? What about ACOK on charger IC?
                        • koby058
                          • Jan 2017
                          • 387
                          • israel
                          Hi
                          Resistance on VDD is 2 ohms
                          voltage on ACOK is 0.09v
                          resistance on ACOK 12 ohms
                          • Sephir0th
                            • Oct 2020
                            • 1289
                            Did you measure without power present? If yes, you indeed seem to deal with a shorted charging controller. It does not fit to the shared history though.
                            FairRepair on YouTube
                            • koby058
                              • Jan 2017
                              • 387
                              • israel
                              Hi, I am always measure resistance without power
                              I have subscribed to your channel looks good
                              • mcplslg123
                                • Jun 2015
                                • 7262
                                • india
                                Originally posted by koby058
                                Hi
                                Remove the charger IC and measure these same resistance to GND again.
                                • koby058
                                  • Jan 2017
                                  • 387
                                  • israel
                                  Hi
                                  I have replaced this charger IC and now the laptop turns on but the charger IC is still getting very hot,
                                  How can i continue inspection of the issue ?
                                  • Sephir0th
                                    • Oct 2020
                                    • 1289
                                    Just move around the charging controller in Ohms mode and see whether there is still a short to GND present. And next time you need to do that after you have removed the old one but before soldering the replacement. Sanity checks.
                                    • koby058
                                      • Jan 2017
                                      • 387
                                      • israel
                                      Hi
                                      I have measured resistance on all pins of this charger IC, the lowest was 40 ohms some pins was OL.
                                      i can see that the laptop is back to the same state the owner explained to me.
                                      where the laptops starts and working very slow and no charging
                                      Any other advise ?
                                      • Sephir0th
                                        • Oct 2020
                                        • 1289
                                        No, 40 Ohms are bad. You didn't realize? Share where you measured the low values and how much exactly.
                                          DELL Inspiron 5593 Notebook 5000 Specification for Upgrade or Repair
                                          This specification for the DELL Inspiron 5593 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 5593 boardview and 5593 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL Inspiron 5593...
                                          09-06-2024, 08:10 PM
                                          09-06-2024, 07:20 PM
                                          09-06-2024, 05:00 PM
