Default HP X360 ( FAROE _DIS_X32_MB_MV 18742-1) no charging
  • kingskie
    • Oct 2014
    • 249
    • indonesia
    hello everyone,
    i have a problem with HP X360 Convertible 14-dh1055TX that cannot charging.
    Schematic requested - https://www.badcaps.net/forum/showthread.php?p=1239028
    i measured some points on the battery pin charging on the motherboard as you can see in the attachment.
    any suggestion would be appreciated.
    thanks
  • mon2
    • Dec 2019
    • 14660
    Re: Default HP X360 ( FAROE _DIS_X32_MB_MV 18742-1) no charging
    Does the logic board function with the use of the power adapter only?
    Trace the area near the DCin connector and you should find 2*DCin mosfets.
    These mosfets will be controlled very likely by a charger IC by Texas Instruments BQ series IC.
    Interested in the full topside markings.
    Post a clear pic of the same area with the charger IC.
    Very carefully measure the voltage to ground of each pin of this charger IC. Ok go have both the adapter and the battery connected.
    Post the list of measurements and the pin numbers.
    • kingskie
      • Oct 2014
      • 249
      • indonesia
      hi @mon2,
      yes the laptop can turn on with power adapter.
      here by i attach the picture with measurents that you ask.
      thanks
      • mon2
        • Dec 2019
        • 14660
        Review pin #4 (ACDRV) on the charger IC.
        The BQ series of charger ICs like to use N-channel mosfets for the 2*DCin mosfets.
        Respectively, the gate pin voltage should be higher than the voltage between source & drain pins on each DCin mosfet on N-channel devices to power on.
        You presently have 19v which is the same as the source / drain pins so the mosfets should be off.
        The ACDRV pin voltage should be ~25v to enable.
        Remove all power. No battery.
        Meter in diode mode. Short your meter probes and the meter should tone beep.
        Touch one meter probe onto the 4k resistor but not the side close to pin #4 ACDRV pin on the charger IC. Touch the opposite side.
        Now hunt for the DCin mosfets and touch pin #4 on the mosfet. This is the gate pin.
        When you hear a tone beep, you have found the DCin mosfets.
        First mosfet will be mated to the DCin connector which powers this board. We are interested in the second DCin mosfet. Both of these mosfets share the gate voltage that is driven by the ACDRV pin.
        Now switch to resistance mode.
        Measure the resistance across this mosfet:
        Source (1-2-3) & drain (5-6-7-8)
        Source & gate (4)
        Gate (4) & drain
        Post each measurement. We are checking if this second DCin mosfet is defective through a resistance check.
        • piernov
          • Jan 2016
          • 4439
          • France
          https://www.badcaps.net/forum/showthread.php?t=90356
          • kingskie
            • Oct 2014
            • 249
            • indonesia
            Source & gate (4)
            Gate (4) & drain
            the pin 4 doesnt have 4K resistor on this board. the charging ic schematic that i attached before is taken from texas intrument website just for BQ24781 reference. and from this board pin 4 goes to a capasitor and the goes to pin 2. so it is different.
            N.B
            i dont have schematic and boardview for this motherboard. already looking everywhere but couldnt find it.
            • mon2
              • Dec 2019
              • 14660
              Review mosfet pu4401. This part may be on the opposite side of the PCB.
              Update: review the schematic link posted by @SMDFlea in your first post.
              • kingskie
                • Oct 2014
                • 249
                • indonesia
                thanks @mon2, tommorow i will check again.
                • piernov
                  • Jan 2016
                  • 4439
                  • France
                  Pin 4 does have a resistor connected to it.
                  PU4301
                  • kingskie
                    • Oct 2014
                    • 249
                    • indonesia
                    Source & gate (4)
                    Gate (4) & drain
                    hi @mon2 and @piernov,
                    this is the measurments for PU4031
                    Source (1-2-3) & drain (5-6-7-8) = 28K
                    Source (1-2-3) & gate (4) = 137 ohm
                    Gate (4) & drain (5-6-7-8) = 28k
                    • mon2
                      • Dec 2019
                      • 14660
                      Flux and remove this part off the board.
                      Then power up without this part. Measure ACDRV pin again.
                      What is the voltage to ground?
                      Measure the mosfet resistance again while the mosfet is off the board and on your table.
                      Very likely that this mosfet is damaged and needs to be replaced.
                      • kingskie
                        • Oct 2014
                        • 249
                        • indonesia
                        mosfet off the board:
                        Source (1-2-3) & drain (5-6-7-8) = 8.5M
                        Source (1-2-3) & gate (4) = OL
                        Gate (4) & drain (5-6-7-8) = OL
                        ACDRV when power on = 19V
                        • mon2
                          • Dec 2019
                          • 14660
                          This mosfet is not defective. As per @Piernov's comment above, review the resistance of PU4301.
                          Post your measurements.
                          • kingskie
                            • Oct 2014
                            • 249
                            • indonesia
                            this is the measurments for PU4031 @mon2 because PU4031 is the second mosfet.
                            do you want me to measure the first mosfet?
                            • mon2
                              • Dec 2019
                              • 14660
                              Yes, do so. Also check the resistance to ground of the 2nd mosfet pads. Something is making the 2nd mosfet look defective when it is on the logic board.
                              Check the voltage of REGN pin on the charger IC.
                              It should be ~6 volts.
                              • kingskie
                                • Oct 2014
                                • 249
                                • indonesia
                                yes @mon2 REGN voltage is 6V as you can see from my previews posting picture.
                                first mosfer measurements:
                                Source (1-2-3) & drain (5-6-7-8) = 0.8 ohm
                                Gate (4) & drain (5-6-7-8) = 137 ohm
                                • mon2
                                  • Dec 2019
                                  • 14660
                                  Flux and remove this first mosfet and check the mosfet again after it is removed.
                                  • kingskie
                                    • Oct 2014
                                    • 249
                                    • indonesia
                                    first mosfet off board measurements:
                                    Source (1-2-3) & drain (5-6-7-8) = 0.9 ohm
                                    Source (1-2-3) & gate (4) = 138 ohm
                                    Gate (4) & drain (5-6-7-8) = 138 ohm
                                    • mon2
                                      • Dec 2019
                                      • 14660
                                      To confirm, these are the measurements of the removed mosfet while it is on your work table?
                                      If yes, then this mosfet is defective and must be replaced.
                                      Perform the same resistance check of the mosfet pads on the PCB from where this mosfet was removed. The readings should now be much higher for the resistance checks.
                                      Also test the mosfet #2 pcb pads in the power path for the same reason.
                                      • kingskie
                                        • Oct 2014
                                        • 249
                                        • indonesia
                                        yes the measurements before is from mosfet on my tabe.
                                        here is the measurements of first mosfet pads:
                                        Source (1-2-3) & drain (5-6-7-8) = 9.3M
                                        Source (1-2-3) & gate (4) = 8.8M
                                        Gate (4) & drain (5-6-7-8) = 15M
                                        here is the measurements of second mosfet pads:
                                        Source (1-2-3) & drain (5-6-7-8) = 9.2M
                                        so that means that mosfet is failing right?
                                        kingskie is online now Report Post
                                        • coasterghost
                                          Lenovo T14 Gen 2 Type 20XK Model 20XK0069US Odd Charging Issues
                                          by coasterghost
                                          For Badcaps Readers, Please note that I am hopefully going to present this same message to Lenovo to see if they have any insight to the matter as well and figured to share the entirety here for clarification. The System is out of warranty as it is but does have the option to have it extended.
                                          Model Information: T14 Gen 2 (Type 20XK, 20XL) Laptop (ThinkPad) - Type 20XK - Model 20XK0069US
                                          Board: T14 Gen 2 (Type 20XK, 20XL) - Type 20XK.
                                          System Hardware:
                                          Processor: AMD Ryzen 7 PRO 5850U
                                          Memory: 1x 16GB DDR4 3200 (Soldered on Board); 1x Crucial 32GB DDR4...
                                          09-08-2025, 10:46 PM
                                        • pb1911nt
                                          MacBook Pro A2251 - 820-01949 Voltage Drop and unkown issues.
                                          by pb1911nt
                                          Hello forum,
                                          I'm still relatively new to the world of electrical repairs.
                                          I have a Macbook here that I can't figure out
                                          When the battery is gone, the USB input consumption goes up to 20 V and 0.06A. But it breaks down after about 2-3 seconds and you can also hear a small ticking on the logic board. But I can't pinpoint it exactly.
                                          I removed the logic board and took a few measurements.
                                          But I can't really figure it out.
                                          At first I thought the infamous CD chip was defective - but then of course you read more on the internet...
                                          09-07-2025, 11:35 AM
                                          HP ProBook x360 Pro x360 Fortis 11 inch G9 Notebook PC Hybrid (2-in-1) Specification for Upgrade or Repair
                                          This specification for the HP ProBook x360 Pro x360 Fortis 11 inch G9 Notebook PC Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Pro x360 Fortis 11 inch G9 Notebook PC boardview and Pro x360 Fortis 11 inch G9 Notebook PC schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum....
                                          09-07-2024, 05:50 AM
