Lenovo T460 Only Charges on One Charger
  • motormayhem
    • May 2023
    • 3
    Laptop Question
    I'm working on a Lenovo T460 that has been having trouble charging as of late. Its worked well since I've owned it for a few years. When I went to use it the other day it was dead and wouldn't turn on (was sitting on an Anker 65W GaN charger). After some fiddling with the charger I got it to turn on and start charging, but seemed like the charger was not working as it should (took a few plug and unplug cycles to get it to start charging).
    A day later it was dead again and wouldn't boot/charge no matter what I did. No lights or anything when I plugged in the charger. Later in the day, I hit the power button not expecting anything and it booted to my surprise. As soon as it booted, it shut down for low batt. However, this indicated to me that it can run on battery, just not DC input power.
    That lead me to believe the issue was on the input power circuit. I opened the bottom and found some schematics on this site (below). Being a mechanical engineer I'm not too familiar with board work, but I was able to measure an open circuit across the PF1 fuse right after the DC power in connection on the board. I ordered a replacement from Mouser and swapped it out on the board.
    When I plugged it in everything was good. It booted and was charging the battery - Awesome! This was on the 65W Lenovo charger it came with. To check I moved it over to the Anker charger it was plugged into previously and it wouldn't charge. I then tried another 45W Lenovo charger I had used previously and it wouldn't charge on that. I also tried a 12v Lenovo charger I've used many time and also got nothing. Moving it back to the 65W Lenovo it immediately recognized the charger and started charging.
    After tinkering with it more I've come to realize all the chargers will work if I plug them in when the computer is fully shut down or when I use a pin to press the power reset button on the bottom cover. At that point I can boot the computer and the charger will continue to work until I unplug it and re-install it. Then it will run on batteries until I shut it down.
    Measuring the DC power at the PF1 fuse when the charger is plugged in and not working shows all sorts of erratic readings like the voltage is jumping around (I don't have a scope so just looking at the multi meter). When I shut it down or press the reset button the charger output immediately goes to ~20.4V and things start charging. This is on multiple of the chargers that are no longer working unless I shut things down.
    Since it wasn't doing this before that fuse blew I am thinking there is something else that is failing in the circuit, but not sure where to start. I'm wondering if maybe the chargers are sensing an over current when plugged in and somehow plugging them in when the computer is off is just enough to stop them from tripping and then once they are plugged in there is no surge or inrush so you can boot and use them.
    Any suggestions on how to go about troubleshooting it? Is there a way to open the .tvw file on a Mac? My windows machine is the one having issues.
    Boardview: https://www.badcaps.net/forum/showth...37#post1238537
    Last edited by Vesko356; 05-13-2023, 02:55 AM. Reason: Attached boardview removed and replaced with link.
  • mon2
    • Dec 2019
    • 14679
    Re: Lenovo T460 Only Charges on One Charger
    In general, always remain with the recommended power adapter from the actual laptop vendor. If required, replace only with a known good adapter with the same power or higher rating (watts).
    It is known that with underrated power adapters, the laptop will be throttled and the battery charge function can cease. For at least Dell & HP models, there is a power adapter sense ID pin. These pins are used to identify if the power adapter has enough mojo to power the laptop and charge and operate at full speed. Anything under the specified rating will lose out on the above features.
    Personally do not see an adapter ID pin on this Lenovo schematic but perhaps others will know more.
    Any reason to not use the original Lenovo 65W adapter? The others are not able to support this model (from my quick search).
    • Vesko356
      VIP Moderator
      • Aug 2018
      • 4386
      • Bulgaria 🇧🇬
      This model uses square yellow jack with center ID pin, if the charger is not recognized (wattage ID by the center pin) battery will not be charged, and the laptop will not power on. I strongly advice you to use only original charger because in case of malfunction (for example 19V at the center pin) the multi-controller dies instantly. So do yourself a favor and don't make unnecessary experiments with no name aftermarket chargers.
      Become a Badcaps supporter
      Thanks to all supporters.​
      • motormayhem
        • May 2023
        • 3
        Hmm most of the chargers I am trying to use other than the Anker are Lenovo brand and I have used them in the past many times successfully with this laptop. I'm ok to not use the Anker charger. The one I'd really like to get working is the travel charger for this which is a 65W Lenovo 12V charger. I've used it many times in the past, but since I had the issue with the blown fuse its doing as I described above where it will only start working when the computer is powered all the way off.
        I've read thru this link a bit and assume I have some sort of issue in either the ID circuit or something causing it to overcurrent when I plug in the charger on power (maybe a shorted resistor or the current measurement circuit not working well causing an inrush current issue?)
        https://www.badcaps.net/forum/showthread.php?t=90356
        Since the charger starts working fine after being installed when powered off can I say the ID circuit is working? Would this computer be a Hybrid power boost design? I'm just not really sure where to start on trying to isolate the issue.
        • WTFRules!
          Lenovo IdeaPad Slim 3 15IAN8 won´t power on after power off without AC charger plugged in
          by WTFRules!
          Hi!
          I´ve this Lenovo IdeaPad Slim 3 15IAN8 with mainboard (KS480 / KS580) NM-E901 Rev 1.0
          I receive it for repair from another shop and it had shorted EC IT8227VG-256
          After replacing it and programming it with SVOD 4 (wich is new to me as I bought it in this week) the laptop is working fine now... BUT
          Once power off from windows, it will not turn on again. When off and the power on button is pressed, a white led turns on and that´s it.
          But if you plug the charger, then all the keyboard LEDs will lit and then you get image on screen and it boots normally....
          Yesterday, 02:50 PM
        • coasterghost
          Lenovo T14 Gen 2 Type 20XK Model 20XK0069US Odd Charging Issues
          by coasterghost
          For Badcaps Readers, Please note that I am hopefully going to present this same message to Lenovo to see if they have any insight to the matter as well and figured to share the entirety here for clarification. The System is out of warranty as it is but does have the option to have it extended.
          Model Information: T14 Gen 2 (Type 20XK, 20XL) Laptop (ThinkPad) - Type 20XK - Model 20XK0069US
          Board: T14 Gen 2 (Type 20XK, 20XL) - Type 20XK.
          System Hardware:
          Processor: AMD Ryzen 7 PRO 5850U
          Memory: 1x 16GB DDR4 3200 (Soldered on Board); 1x Crucial 32GB DDR4...
          09-08-2025, 10:46 PM
          Lenovo ThinkPad T460 Notebook T Specification for Upgrade or Repair
          This specification for the Lenovo ThinkPad T460 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the T460 boardview and T460 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Lenovo ThinkPad...
          09-06-2024, 08:05 AM
          09-06-2024, 07:05 AM
          09-06-2024, 07:02 AM
