Lenovo ideapad 5 - identify shorted chip
  • s_henya
    • Jan 2011
    • 482
    • Israel
    Hi guys,
    Got this nice laptop in yesterday.
    MB: GS557GS558
    Previous owner dropped a screw that shorted the MB.
    Removed faulty cap that got burned due to short.
    Found burning hot ic
    QqBUA- no information about it in google.
    Any advice what is this IC?
    Would be a shame to scrap this board…
  • mon2
    • Dec 2019
    • 14366
    Re: Lenovo ideapad 5 - identify shorted chip
    Silergy
    Qq*** SY8386BRHC - N/D (EL432 EL532 LA-H131P)
    • s_henya
      • Jan 2011
      • 482
      • Israel
      Originally posted by mon2
      Silergy
      Thanks!
      All of these ics are compatible replacements?
      • mon2
        • Dec 2019
        • 14366
        The tail end of the above are the logic boards that use this part so you can study the schematic.
        As long as the part starts with Qq, you will be ok. The rest are usually datecode markings.
        Here is one vendor:
        US $7.71 18%OFF | (5piece)100% New SY8386BRHC SY8386B QqAZB QqBTB Q9A.. QFN-16 Chipset
        https://a.aliexpress.com/_mqsEFbS
        • s_henya
          • Jan 2011
          • 482
          • Israel
          Here is one vendor:
          Thank you so much!
          Will update after replacing it.
          • s_henya
            • Jan 2011
            • 482
            • Israel
            Update:
            So i finally got the replacement IC from china.
            Unfortunately i have the same symptom- overheating ic
            i collected measurements
            Pin1: 0.43v
            Pin 2,3,4: 12.25v
            Pin5: 0.015v
            Pin6: 0v
            Pin7: 0v
            Pin8: 12.23v
            Pin9: 0.296v
            Pin10: 0.04v
            Pin11: 0.14v
            Pin12: 0.017v
            Pin13: 0.373v
            Pin14: 0v
            Pin15,16: 0.014v
            any suggestions?
            MOD EDIT: Link to schematic and boardview -> https://www.badcaps.net/forum/showthread.php?p=1240393
            • mon2
              • Dec 2019
              • 14366
              Remove all power. Meter in resistance mode.
              Measure the resistance to ground of:
              Pin # 16 (LX2)
              Pin # 13 (LDO)
              • s_henya
                • Jan 2011
                • 482
                • Israel
                Pin # 16 (LX2)
                Pin # 13 (LDO)
                Pin13: 1.7ohm
                Pin15,16: 2ohm
                that's probably bad :-(
                • mon2
                  • Dec 2019
                  • 14366
                  See attached.
                  1) Flux and remove PC414. Measure the resistance to ground again after removing this capacitor. No power during the resistance checks.
                  2) Flux and lift one leg (carefully) of the inductor @ PL402. Measure the resistance to ground again after removing this capacitor. No power during the resistance checks.
                  Which side of the circuit is with the low resistance after lifting the one leg of PL402?
                  3) Do you have an adjustable power supply that can support 1 volt?
                  4) Be sure that the replaced component is properly soldered. As a suggestion, flux and reflow the part well enough with low air pressure but spin the hot air tool in circles from the topside. Eventually, the solder will be in liquid form and allow for this component to swim onto the PCB pads and 'align like soldiers'. Louis, Alex and others have some great YT videos that demonstrate this process.
                  • mcplslg123
                    • Jun 2015
                    • 7262
                    • india
                    Before ordering/soldering a new IC, basic things has to be checked. Else new ic may also get damaged. Since you have shorting on 3v LDO line very very likely SIO is shorted.However, one can be sure with voltage injection as advised by@mon2.
                    • s_henya
                      • Jan 2011
                      • 482
                      • Israel
                      @mon2:
                      1. Removed cap from LDO line-> resistance is 1.3ohm to GND
                      2. Removed coil from LX line-> resistance is 1.5ohm on the pad to other side of the IC
                      3. I have. which point do you recommend me to inject the 1v?
                      4. Confirmed, it is my 1st time to replace QFN chip, but plenty of experience with soldering and reflow. so this one went smoother than expected. Alex is indeed very professional at his work :-)
                      @mcplslg123 i agree i should have tested, but i was hoping for an easy repair- i really hope the SIO is good, i don't believe i will find a pre-programmed IC.
                      Replacement MB is kinda pricy since this is i5 10th gen...
                      • mon2
                        • Dec 2019
                        • 14366
                        So it appears that you have 2 shorts linked to this regulator.
                        LDO rail is shorted.
                        Downstream switching regulator leg is shorted.
                        Be sure the QFN device is properly soldered, do check the resistance between the pins on this IC to confirm the LDO pin is not shorted with another.
                        After the above, consider to dial up 1 volt on your power supply.
                        Red probe of the power supply onto the LDO rail; black to ground. No other power sources should be applied.
                        Then monitor for which part heats up with this injection. Ok to increase the current but keep the voltage at 1 volt for now.
                        Same method can be used for the switching regulator leg where you have lifted the coil.
                        Hoping that a local capacitor heats up and is the root cause of the fault.
                        • s_henya
                          • Jan 2011
                          • 482
                          • Israel
                          Seems like indeed 2 different shorts..
                          Will attempt voltage injection and hope it's only a cap.
                          Hope it's not the SIO or a mosfet going to the cpu or gpu.
                          Will update tomorrow!
                          • mcplslg123
                            • Jun 2015
                            • 7262
                            • india
                            Unfortunately, its the SIO that's very likely going to heat up.
                            • s_henya
                              • Jan 2011
                              • 482
                              • Israel
                              I injected 1v on the LDO line. Current consumption was only 0.3amps.
                              I couldn’t feel anything warm on the board.
                              (Unfortunately i dont own a thermal camera) but i touched the SIO and didn’t feel anything abnormal.
                              Due to the risks of burning the CPU/GPU I can’t raise more than 1v right?
                              So i guess this is game over?
                              • mon2
                                • Dec 2019
                                • 14366
                                No. Locate the CPU power rail. Remove all power.
                                Meter in resistance mode. One meter probe here on this shorted rail. Other meter probe on the CPU power rail.
                                What is the resistance between the 2 points?
                                • s_henya
                                  • Jan 2011
                                  • 482
                                  • Israel
                                  Should i check on the coils or at the input of the mosfets?
                                  • mon2
                                    • Dec 2019
                                    • 14366
                                    Coils will be fine. This check will confirm if there is a leaky high side mosfet.
                                    • mcplslg123
                                      • Jun 2015
                                      • 7262
                                      • india
                                      AFAIK, @mon2, a leaky high side mosfet will affect 19V rail and not 3V LDO rail.
                                      • Sephir0th
                                        • Oct 2020
                                        • 1283
                                        I don't want to be the one who is stopping the fun here but I don't see the point to dig in elsewhere, if there is a high chance the PCH is shorted from +3.3VALW rail.
                                        FairRepair on YouTube
                                          Lenovo IdeaPad IdeaPad 3 15IGL05 Notebook 3 Specification for Upgrade or Repair
                                          This specification for the Lenovo IdeaPad IdeaPad 3 15IGL05 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the IdeaPad 3 15IGL05 boardview and IdeaPad 3 15IGL05 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                          09-07-2024, 05:20 AM
                                          Lenovo IdeaPad IdeaPad 3 15IML05 Notebook 3 Specification for Upgrade or Repair
                                          This specification for the Lenovo IdeaPad IdeaPad 3 15IML05 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the IdeaPad 3 15IML05 boardview and IdeaPad 3 15IML05 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                          09-07-2024, 05:00 AM
                                          Lenovo IdeaPad IdeaPad 1 14IJL7 Notebook 1 Specification for Upgrade or Repair
                                          This specification for the Lenovo IdeaPad IdeaPad 1 14IJL7 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the IdeaPad 1 14IJL7 boardview and IdeaPad 1 14IJL7 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                          Lenovo IdeaPad IdeaPad 5 CB 14ITL6 Notebook 5 Specification for Upgrade or Repair
                                          This specification for the Lenovo IdeaPad IdeaPad 5 CB 14ITL6 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the IdeaPad 5 CB 14ITL6 boardview and IdeaPad 5 CB 14ITL6 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                                          09-07-2024, 04:30 AM
                                          Lenovo IdeaPad IdeaPad 3 14IML05 Notebook 3 Specification for Upgrade or Repair
                                          This specification for the Lenovo IdeaPad IdeaPad 3 14IML05 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the IdeaPad 3 14IML05 boardview and IdeaPad 3 14IML05 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
