Dell E5520 adapter detect
  • ahkh_72
    • 109
    • Iran
    hi
    there is a dell e5520 MB:10ELT15F001-A KRUG 15, that can not detect adapter wattage.
    in bios show unkown AC adapter.
    I checked DC jack to MB conection was ok.
    how can i bypass this error?
    thnks
    .Today should be different from yesterday.
    • 21899
    Re: Dell E5520 adapter detect
    Originally posted by ahkh_72
    hi
    thnks
    Are you using a 3rd party charger or a genuine dell one.Have you tried another charger
    • ahkh_72
      • 109
      • Iran
      yes i checked it with 3 genuine dell charger.
      and i checked that charger on another dell laptop, was ok.
        • 21899
        Check the PS_ID circuit.Test the voltage and resistance on PR224 both pins also DCIN_CBL_DET# -> R337
        • ahkh_72
          • 109
          • Iran
          pq20 <3.420v> PR224 <3.414v> pu3
          resistance on pr224 6.2 kohm
          voltage on DCIN_CBL_DET# =0v
          resistance on DCIN_CBL_DET# =0.4 ohm
          R337=3.3V AND other side 0v
          • mon2
            • Dec 2019
            • 14666
            This is a bad reading for this component. It should be ~100 ohms. Replace this part or you can test with a short across this component. Better to place a low resistance resistor if available. Any value like 33 ohms to 390 ohms is ok.
            Then test again. Be sure that the resistance checks are without any power to the logic board and that you are checking the resistance with the meter probes across the part (not to ground).
            PS: Love the mazafati dates from your area Need to pick some up tomorrow...
            • ahkh_72
              • 109
              • Iran
              I apologize for my mistake.
              Yes its about 99 ohm.
              RE:Enjoy your meal (:
              • ahkh_72
                • 109
                • Iran
                I short 2 pins of r224 with wire .
                but still same result.
                • mon2
                  • Dec 2019
                  • 14666
                  Ok - the series resistor is ok.
                  What is the voltage to ground of the PSID pin at the DCin connector? This is referenced as pin #6 on CN1.
                  Carefully also measure the voltage to ground of each pin of PU3. This is the load switch that allows for the communication to pass through to / from the single wire ID device inside the Dell original adapters and the EC on your logic board.
                  This signal path is required to be working so that the ID of the adapter can be read by the logic board.
                  • ahkh_72
                    • 109
                    • Iran
                    PSID(DCin) pin is 4.3V.
                    pu3 pins:
                    1=0.6v
                    2=0v
                    3=3.4v
                    4=3.4v
                    5=5.1v
                    6=0v
                    • mon2
                      • Dec 2019
                      • 14666
                      This is too high.
                      Carefully measure the voltage to ground of each pin of the mosfet @ PQ20.
                      Post the measurements.
                      • ahkh_72
                        • 109
                        • Iran
                        This is too high.
                        PQ20:
                        pin1(S)=3.41v
                        pin2(G)=4.29v
                        pin3(D)=4.29v
                        • mon2
                          • Dec 2019
                          • 14666
                          PQ20 appears to be leaky as the GATE voltage is the same as the DRAIN voltage.
                          Flux and remove PQ20 mosfet. Then apply solder blob onto PR223 so that this solder blob will short the DRAIN & SOURCE pins.
                          Then measure the voltage to ground again of the PSID pin at the DCin connector.
                          It should be ~3v41 => same as the PSID voltage on the EC side of the circuit.
                          • ahkh_72
                            • 109
                            • Iran
                            thank you very much
                            Now AC Adapter is =90W in bios.
                            But PSID voltage in DCin is 0.03v.
                            TNKS again for your time.
                            • mon2
                              • Dec 2019
                              • 14666
                              Well done! Just repeating some of the tricks posted by @mcplslg123 and others in the forum
                              PS: The same local store has THE best baklava we have had. One of these days, will try to learn how to make it ourselves.
                              • mcplslg123
                                • Jun 2015
                                • 7262
                                • india
                                I still wonder why so many threads are started for dell PSID problems when every possible solution is already there in the forum. Members should first read atleast some threads with similar contents before starting a new thread. If the issue is resolved by reading any thread, they can sum up there experience in those threads. This help us to help many others who may have something more tricky problems. I dont mean any offence to anyone but just raising an issue which should be addressed for the benefit of badcaps family.
