samsung NP300E5
  • baki60
    • May 2020
    • 78
    • Türkiye
    samsung NP300E5
    led green red green red
    no trigger where should i watch
  • mon2
    • Dec 2019
    • 14316
    Re: samsung NP300E5
    See attached.
    Connect the power adapter. Meter in DC volts (20V or higher is ok).
    Carefully, measure the voltage to ground of each test point on the charger IC.
    The charger IC is U509 - see attached.
    Interested in the voltage readings for:
    ACN
    ACP
    REGN
    ACDRV
    VCC
    Post each measurement.
    • baki60
      • May 2020
      • 78
      • Türkiye
      Re: samsung NP300E5
      What program should I open it with?
      BoardViewer 2.1.0.8-
      it didn't work expert
      • mon2
        • Dec 2019
        • 14316
        Re: samsung NP300E5
        Try the attached.
        • baki60
          • May 2020
          • 78
          • Türkiye
          Re: samsung NP300E5
          black screen
          Originally posted by mon2
          Try the attached.
          • baki60
            • May 2020
            • 78
            • Türkiye
            Re: samsung NP300E5
            ACN 18.5
            ACP 18.5
            REGN 6.0
            ACDRV 24.5
            VCC 18.5
            these are experts
            • mon2
              • Dec 2019
              • 14316
              Re: samsung NP300E5
              These are good values for these pins.
              With the adapter connected, check the voltage to ground of each coil (inductor) on the logic board.
              You are checking for any low voltage measurements on the coil to ground. Each coil is linked to a local buck switching regulator. If the coil is with a low or zero voltage, that power rail could be defective or disabled due to a shorted part. A shorted part will consume too much current and the regulator will sense this fault and turn off the regulator.
              Otherwise, you need to review the BIOS devices on the logic board which may be corrupt.
              • baki60
                • May 2020
                • 78
                • Türkiye
                Re: samsung NP300E5
                I solved the problem master
                bios yazdım düzeldi
                thank you for your interest
                • baki60
                  • May 2020
                  • 78
                  • Türkiye
                  Re: samsung NP300E5
                  bios yazdım düzeldi
                    09-07-2024, 05:50 AM
                  • String2016
                    samsung np300e green screen
                    by String2016
                    I need help on this samung np300e laptop, laptop turns on but the display green screen samsung logo and no bootable device shows but all green, I have replaced good lvds cable and good screen still problem persist.anyone encounter this problem please help
                    07-26-2025, 04:00 AM
                    09-06-2024, 11:40 PM
                    09-06-2024, 08:40 PM
