Dell E7450 not charching La-A961P
  • arber1232
    • Dec 2019
    • 377
    • Albania
    HI, how are you. I have a dell laptop which does not turn on with charger and not charching
    the light of the power button for a while and turns off, with battery the laptop turns on and works fine. I have done some measurements and I doubt Pq705 but I want your help to be sure....
    Some measurements of pq 705 with charger without battery
    D1-19,13y
    S1/D2- voltage change 12v to 10v 13v
    G1- voltage change 13v, 14v, 16v
    G2-ov
    S2-gnd
  • arber1232
    • Dec 2019
    • 377
    • Albania
    Re: Dell E7450 not charching La-A961P
    Originally posted by arber1232
    hi, how are you. I have a dell laptop which does not turn on with charger and not charching
    the light of the power button for a while and turns off, with battery the laptop turns on and works fine. I have done some measurements and i doubt pq705 but i want your help to be sure....
    d1-19,13y
    s1/d2- voltage change 12v to 10v 13v
    g1- voltage change 13v, 14v, 16v
    g2-ov
    s2-gnd
    [MOD EDIT]
    Schematic - https://www.badcaps.net/forum/showthread.php?t=73364
    • mon2
      • Dec 2019
      • 14342
      Be sure the adapter is original and of the correct power rating.
      Measure the voltage to ground of NB_PSID. This is from the power adapter center pin but on the logic board.
      Post the measurement.
      • mon2
        • Dec 2019
        • 14342
        Next, check on the charger IC, the voltage to ground of:
        VCC
        REGN
        ACDET
        Pins. Do connect the adapter. Post each measurement.
        • arber1232
          • Dec 2019
          • 377
          • Albania
          i try with 2 Adapter
          NB_PSID-3,2v
          VCC- Change to 10v 12v 13 v
          REGN-5.3v
          ACDET-3,1v
          • mon2
            • Dec 2019
            • 14342
            Ok. Focus on VCC - it should be stable.
            Measure the voltage to ground before PR708. Is it stable ?
            Then measure BEFORE PD704. This diode should provide a low voltage drop from the power adapter and then power the VCC rail but it should be stable.
            Once this VCC is stable, then REGN should be ~6 volts. Confirm it.
            • arber1232
              • Dec 2019
              • 377
              • Albania
              Measure the voltage to ground before PR708. Is it stable ? Yes 19,34 volt
              I find problem is PR708 CHANGE OHMS
              I CHANGE AND NOW WORK OK
              • mon2
                • Dec 2019
                • 14342
                Remove all power. Meter in resistance mode.
                Check the resistance across the 2 pins of PR708.
                Next, still with no power -> measure the resistance to ground of the VCC pin on the charger IC. We are checking for a low resistance on the VCC pin which may be causing the voltage to fluctuate.
                What are the resistance readings ?
                • arber1232
                  • Dec 2019
                  • 377
                  • Albania
                  Thank you, pr708 had changed the value from 10 ohm, it was somewhere around 2.7 kohm
                  i change pr and laptop turn on and charging
                  • mon2
                    • Dec 2019
                    • 14342
                    Well done
                      DELL Latitude E7450 Notebook 7000 Specification for Upgrade or Repair
                      This specification for the DELL Latitude E7450 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the E7450 boardview and E7450 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL Latitude...
                      09-06-2024, 04:40 PM
                      09-06-2024, 04:10 PM
