HP Pavilion 15 -- DAY23AMB6C0 REV C, Dead
  • Jmine
    • Dec 2022
    • 52
    • Sri Lanka
    Here I am with yet another dead motherboard on my hands, seeking your help guys!
    The Charging LED is on and no shorts on the board,19V and 3VPCU are present. I measured the power IC, it goes like this.
    VCC: 19.7V
    ACPRES: 2.9- 3.0V noticed when measuring this pin the Charging light Blinks
    ACDRV: 24V
    ACDET: 2.5V When measuring here, the Charging LED turns off
    REGN: 6.1V
    BQLODRV: 0V
    BQHIGHDRV: 2.5V
    BQPHASE: 2.5V
    I guess these values are good, I went on to measure some voltages on EC.
    VCC: 3.3v
    AVCC: 3.3V
    ACIN: 2.8V
    LIDEC: 2.8V
    ECPOWEROK: 0V,
    I learned that the last one should be higher in order to power on the laptop. What Could be the reason? Help me Diagnose Guys!
    You may Find Schematic Here,
    https://www.badcaps.net/forum/showthread.php?t=73190
  • Jmine
    • Dec 2022
    • 52
    • Sri Lanka
    Re: HP Pavilion 15 -- DAY23AMB6C0 REV C, Dead
    I measured the coils,
    PL11: 130K
    PL17: 8 ohms
    PL21: 17ohms
    PL22: 63 ohms
    PL24: 87 ohms
    PL25: 51K
    PL26: 500 ohms
    PL29: 14K
    • mon2
      • Dec 2019
      • 14206
      So the EC is reporting the power is NOT OK.
      Be sure that you are using the proper rated and original power adapter suitable for this logic board.
      Measure the voltage to ground of the AD_ID pin athe DCin connector.
      This analog voltage is being used to detect if the adapter is suitable or not.
      What is the voltage to ground of +3VPCU?
      • Jmine
        • Dec 2022
        • 52
        • Sri Lanka
        AD_ID 0.5v
        +3vpcu 3.3V
        It's an hp 45W charger
        • mon2
          • Dec 2019
          • 14206
          What is the voltage to ground of +3VPCU_EC?
          • Jmine
            • Dec 2022
            • 52
            • Sri Lanka
            3.3V present @67th pin of EC
            • mon2
              • Dec 2019
              • 14206
              Confirm the voltage to ground on each pin of R555.
              D18 is acting like a low cost dual input AND gate.
              The power good will be high by use of R555 only if BOTH inputs to the diode are good or floating.
              If either input pin is LOW because the power is not good or missing a pull-up voltage then this dual diode will be pulled low.
              • Jmine
                • Dec 2022
                • 52
                • Sri Lanka
                R555 I've got nothing on both pins
                • Jmine
                  • Dec 2022
                  • 52
                  • Sri Lanka
                  Why do I see variable voltage on pin 2 of D18( 2.9v to 3.7v)? It shouldn't be high as cpu section is not yet on?
                  • mon2
                    • Dec 2019
                    • 14206
                    So 3VS5 is missing on R155.
                    Review PU16.
                    What is the voltage to ground of pin #1 (SY8208BEN / EN1) ?
                    Voltage of S5_ON signal?
                    Remove all power. Measure the resistance to ground of PL29 (3VS5).
                    Post each measurement.
                    • Jmine
                      • Dec 2022
                      • 52
                      • Sri Lanka
                      Review PU16.
                      Pu16 pin 1 voltage to the ground: 0v
                      S5_on pin101 of EC: 0v
                      PL29 resistance to the ground: 14k
                      • mon2
                        • Dec 2019
                        • 14206
                        Wait on other comments but your EC maybe with corrupt firmware or defective.
                        • Jmine
                          • Dec 2022
                          • 52
                          • Sri Lanka
                          Thank you very much for the help mon2.!
                          Got a dumb question though. Do the 3v and 5v supplies turn on before pressing the power button on this board? Is that why they are named 3vs5 and 5vs5? I have no idea of the power sequence of this board.
                          • mon2
                            • Dec 2019
                            • 14206
                            Yes, these are indicators of different power states.
                            These enable signals are driven by the EC controller which is a stand alone microcontroller (8051 type) that has its own firmware.
                            Reference reading:
                            https://medium.com/@eileenchu/system...s-bf90b4c1b04f
                            • Jmine
                              • Dec 2022
                              • 52
                              • Sri Lanka
                              Reference reading:
                              Thank you for the valuable article
                              • mcplslg123
                                • Jun 2015
                                • 7262
                                • india
                                Without ECPWROK being present, no point looking for S5_ON.
                                I'll suggest to check all the requirements of kbc.
                                • Jmine
                                  • Dec 2022
                                  • 52
                                  • Sri Lanka
                                  What Should I specifically check, apart from what I've already measured?
                                  • mcplslg123
                                    • Jun 2015
                                    • 7262
                                    • india
                                    Measure Pin14/19/90/93/95/127/124/102/37 of KBC
                                    • Jmine
                                      • Dec 2022
                                      • 52
                                      • Sri Lanka
                                      14, 19 90 93 95 nothing!
                                      127: 3.1v
                                      124: 3.3V
                                      102: 2.5V
                                      37: 3.3v
                                      • reformatt
                                        • Feb 2020
                                        • 1412
                                        What about KBC_RST# on pin 13? I'd be checking these things after power is first applied too (after 3920_RST# goes high). EC might detect a fault condition and shut down for example. Failing that, I'd be re-programming the EC as @mon2 suggested with a SVOD or similar.
                                          HP Pavilion Wave Pavilion Wave Desktop - 600-a030na Pavilion Wave i3-6100T Specification for Upgrade or Repair
                                          This specification for the HP Pavilion Wave Pavilion Wave Desktop - 600-a030na can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Pavilion Wave Pavilion Wave Desktop - 600-a030na boardview and Pavilion Wave Pavilion Wave Desktop - 600-a030na schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps...
                                          09-12-2024, 03:44 PM
                                          HP Pavilion Pavilion Desktop - 570-p056 Pavilion 570 i7-7700 Specification for Upgrade or Repair
                                          This specification for the HP Pavilion Pavilion Desktop - 570-p056 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Pavilion Pavilion Desktop - 570-p056 boardview and Pavilion Pavilion Desktop - 570-p056 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no...
                                          HP Pavilion Pavilion Desktop - 570-p030na Pavilion 570 i3-7100 Specification for Upgrade or Repair
                                          This specification for the HP Pavilion Pavilion Desktop - 570-p030na can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Pavilion Pavilion Desktop - 570-p030na boardview and Pavilion Pavilion Desktop - 570-p030na schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer...
                                          HP Pavilion Pavilion p6560be-m Desktop PC Bundle Pavilion p6500 E6600 Specification for Upgrade or Repair
                                          This specification for the HP Pavilion Pavilion p6560be-m Desktop PC Bundle can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Pavilion Pavilion p6560be-m Desktop PC Bundle boardview and Pavilion Pavilion p6560be-m Desktop PC Bundle schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
                                          HP Pavilion Pavilion Desktop - 570-a079w Pavilion 570 J4205 Specification for Upgrade or Repair
                                          This specification for the HP Pavilion Pavilion Desktop - 570-a079w can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Pavilion Pavilion Desktop - 570-a079w boardview and Pavilion Pavilion Desktop - 570-a079w schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer...
