Acer Aspire 5 A515-51G power on but black screen
  • mcplslg123
    • Jun 2015
    • 7262
    • india
    Re: Acer Aspire 5 A515-51G power on but black screen
    It seems you have shifted 4 resistors instead of 3 mentioned at post#17. Only those 3 needs shifting and rest untouched. Double check your work.
    • resistor83
      • Oct 2018
      • 127
      • Italy
      why do you say 4 resistors?
      below i put a "before and after" picture and you can see i moved only ID0, ID2 and ID3
      • mcplslg123
        • Jun 2015
        • 7262
        • india
        I said what it looked like from pics. Your later pics confirm that you did it right. Sorry, i've no imore idea.
        • resistor83
          • Oct 2018
          • 127
          • Italy
          could it be the video card?
          UMA?
          • resistor83
            • Oct 2018
            • 127
            • Italy
            I read on some forum that for UMA conversion you have to move RC134 to RC133
            I tried to move it but the problem is still there, the only thing is the absorption from 0.50A drops to 0.42. I guess because the video card is actually disabled
            • resistor83
              • Oct 2018
              • 127
              • Italy
              #26
              well, maybe i found the problem. As I wrote a few posts back, there are no voltages on VCC_GT and therefore also on the PL906 coil
              By measuring the PQ906 chip I discovered that pin 2 has 19v while pin 1 has 0v
              The same chip (PQ1202 and PQ1201) is also present in the area of the dedicated video card and measures them 1,12v
              Do you think I should change PQ906?
              • piernov
                • Jan 2016
                • 4437
                • France
                #27
                https://logi.wiki/index.php/User:Pie..._I_solve_it.3F
                I am missing VCCAXG/VCCGFX/VCCGT (iGPU core voltage), how do I solve it?
                The iGPU core voltage is almost never relevant. It typically only comes up when there's a significant load on the iGPU. It can often be seen spiking a couple of times on the oscilloscope when POSTing.
                In other words, it's generally normal that it's missing. If you have some kind of issue with the machine, the cause is most likely elsewhere.
                • resistor83
                  • Oct 2018
                  • 127
                  • Italy
                  #28
                  Thanks for the info.
                  Could someone tell me what measurements I could do?
                  Thank you
                  • resistor83
                    • Oct 2018
                    • 127
                    • Italy
                    #29
                    Anyone please?
                    • resistor83
                      • Oct 2018
                      • 127
                      • Italy
                      #30
                      Hi, no :\
                      Have you same problem?
                      • Jmine
                        • Dec 2022
                        • 52
                        • Sri Lanka
                        #31
                        I think vcc gt doesn't turn on at these stages. It only turns on when graphic intensive program is run on the windows.
                        Someone correct me if I'm wrong.
                        Edit : Sorry. Piernov had already mentioned that.
                        • kilometrs
                          • May 2025
                          • Latvia
                          #32
                          resistor83 Have you managed to find the problem? Only I have 1A version instead of 1C.
                          • kilometrs
                            • May 2025
                            • Latvia
                            #33
                            Sorry for double-posting.
                            PLT_RST# and DRAMRST# are both 3.33v for me. Switching onboard ram by moving resistors also didn't seem to work. Flashing latest bios. Same symptoms. Haven't tried UMA switching yet.
                            • kilometrs
                              • May 2025
                              • Latvia
                              #34
                              Correct the double-posting please.
                              After switching the onboard ram off and flashing mcplslg123​'s bios file from this thread, laptop started working again!
