dell latitue e5450 AC Adaptor unknown
  • apostsamking
    • Dec 2017
    • 118
    • Ghana
    Hello everyone hope all is well. Pls I bought this second hand dell latitue e5450, I realize that the battery cannot be charged because it says ac adopter unknown at bios. I tried several chargers but still I get the same messageAC Adaptor unknown. So I open the laptop up checked the motherboard and i realised that the diod PD5 is fried so I changed, but I still get the same message, changed even the charging ic still the same message AC Adaptor unknown. Can any one help me?
  • mon2
    • Dec 2019
    • 14575
    Re: dell latitue e5450 AC Adaptor unknown
    The fault is linked to the PS_ID circuit. See attached. A number of components exist between the PS_ID pin on the power adapter connector and the EC IC. The EC is the controller that communicates with the power adapter using the single-wire protocol. The single-wire protocol is well documented by Maxim / Dallas Semiconductor and there are a number of 'hack' articles on how to emulate the same using other ICs. Once the logic board is pacified that the proper adapter signature is present, the logic board will remove this message and allow for a normal operation.
    If PQ2 or perhaps PU1 are defective, the adapter communication cannot proceed and then the logic board defaults to the 'unknown adapter' message.
    Suggest to remove and bypass PQ2. Be sure to download a datasheet for this mosfet so that you can review the exact pinout for this SOT-23 package.
    Then bypass the source & drain pins with a piece of wire and test again.
    If it works, which is often the fault, replace this PQ2 with another.
    Otherwise, proceed to review and replace PU1.
    During this review, do measure the voltage to ground of the PS_ID line before and after PQ2.
    • mcplslg123
      • Jun 2015
      • 7262
      • india
      Make sure PR9 is exact 33 Ohms.
      • apostsamking
        • Dec 2017
        • 118
        • Ghana
        Thanks Very much, I will work on it and give you a feed back. Thanks once again.
        • apostsamking
          • Dec 2017
          • 118
          • Ghana
          I did everything but I still get the ac adapter unknown
          • mon2
            • Dec 2019
            • 14575
            Post the voltage the ground of PS_ID.
            Also share the resistance of the series resistor in the circuit.
            Is it 33 ohms? No power when checking the resistance.
            • apostsamking
              • Dec 2017
              • 118
              • Ghana
              It was no power when checking the resistance.
              • mon2
                • Dec 2019
                • 14575
                Ok, but what is the resistance across PR9 ?
                Next, power up and with the meter in DC volts mode -> check the voltage to ground of this line.
                Check the voltage at the power adapter connector and again after the mosfet that you have bridged.
                Post each measurement.
                • apostsamking
                  • Dec 2017
                  • 118
                  • Ghana
                  I get 0.169v
                  • mon2
                    • Dec 2019
                    • 14575
                    This line should be at a higher voltage.
                    Can you post a pick of the mosfet bypass wiring?
                    • apostsamking
                      • Dec 2017
                      • 118
                      • Ghana
                      Pls show me I don't know how to go about it.
                      • tomodachi
                        • Apr 2012
                        • 606
                        • Turkey
                        Can you check whether PD5 is good or not ?
                          DELL Latitude E5450 Notebook 5000 Specification for Upgrade or Repair
                          This specification for the DELL Latitude E5450 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the E5450 boardview and E5450 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL Latitude...
                          09-06-2024, 08:40 PM
