Acer Swift SF314-54 charging, not powering up
  • mon2
    • Dec 2019
    • 14214
    Re: Acer Swift SF314-54 charging, not powering up
    Am I the only one here who have issues with the pictures shared here? They're way to small. I can't identify anything
    You need one of these - pretty sure they sell them on Aliexpress. From one of my favorite TV shows while growing up.
    • kuupotin
      • Aug 2016
      • 30
      • Finland
      Affs... Lets try this.
      • mcplslg123
        • Jun 2015
        • 7262
        • india
        Voltage Injection at this stage of troubleshooting is a clear NO. Exact resistance on 3V/5V coil(no power connected)??
        Why not check the basic requirements of KBC first??
        Pin125/111/67/124//100/103/106/107/121/16/17/37 of KBC-Voltage measurements. If any of the pins have no voltage, measure resistance as well on those pins.
        Printing on the schematics is bit mislaigned on pg24.So make sure you are measuring the correct pins.
        • kuupotin
          • Aug 2016
          • 30
          • Finland
          280 ohm 5Vcoil.
          I don't know 3V coil location.
          • kuupotin
            • Aug 2016
            • 30
            • Finland
            PINS: 16, 17, 37, 67, 124, 125
            3,3V
            PIN: 111
            2,9V
            PINS with 0V: with power/no power resistance
            100 51/10k
            103 52/320k
            106 7/8
            107 20/92k
            111 2,9/very high
            121 20/10k
            • mon2
              • Dec 2019
              • 14214
              Resistance and also diode mode meter readings are always with no power to the logic board.
              Can you review and update your posted values with no power to the logic board?
              • kuupotin
                • Aug 2016
                • 30
                • Finland
                #27
                3,3V
                PIN: 111
                2,9V
                PINS with 0V: no power resistance
                100 10k
                103 320k
                106 8
                107 92k
                111 2,9/very high
                121 10k
                Here
                • mon2
                  • Dec 2019
                  • 14214
                  Pin 106 is 8 ohms or 8k ohms to ground resistance?
                  If 8 ohms, that is too low and there is a shorted part on that line.
                  Double check now in diode mode.
                  Meter in diode mode. No power to the logic board.
                  Red meter probe to ground.
                  Black meter probe to pin #106.
                  What is the measurement?
                  • kuupotin
                    • Aug 2016
                    • 30
                    • Finland
                    #29
                    0,009V something wrong here...
                    • mon2
                      • Dec 2019
                      • 14214
                      Indeed. Have not yet checked the schematics.
                      What is this power rail?
                      Do you have an adjustable power supply? That can be adjusted to a 1 volt output ( not higher ).
                      The process is then to inject 1 volt onto this rail and check who heats up.
                      Yes, you have a power supply ☺️
                      • kuupotin
                        • Aug 2016
                        • 30
                        • Finland
                        #31
                        Am I reading this right?
                        Signal from RTCRST_ON pin106 tells to switch mosfet Q1701 on. So is there something wrong in mosfet or near?
                        • mon2
                          • Dec 2019
                          • 14214
                          Correct. Pin 106 is driving the GATE pin of the mosfet (2N7002) @ Q1701.
                          Either this pin or something on this pin is shorting.
                          Start with removing the pull-down resistor @ R1703.
                          With no power to the logic board, check the DIODE mode reading again on this pin.
                          Is it improved ? The reading should be higher. If not, remove the mosfet @ Q1701 and measure again.
                          If the 'hard short' still remains on pin 106 then the conclusion is that the KBC is defective.
                          Wait on other comments but believe this KBC controller will then need to be replaced.
                          • kuupotin
                            • Aug 2016
                            • 30
                            • Finland
                            #33
                            After resistor remove. 0,012V
                            after mosfet same...
                            • kuupotin
                              • Aug 2016
                              • 30
                              • Finland
                              #34
                              So if KBC is faulty, am I able to replace it or should it be flashed?
                              • mon2
                                • Dec 2019
                                • 14214
                                This line is based on a GPIO pin (general purpose input/output pin).
                                From the measurements, this pin appears to be defective / damaged.
                                Do wait on other comments but to me, this KBC controller is damaged and must be replaced. From my (limited) understanding, this is a 8051 based KBC IC that uses firmware that is internal to the device. For this reason, this KBC controller requires a special programming tool.
                                Some KBC ICs use an external SPI interface flash memory device to boot the firmware.
                                There are vendors on Ebay, etc. that offer pre-flashed KBC ICs.
                                • kuupotin
                                  • Aug 2016
                                  • 30
                                  • Finland
                                  #36
                                  Ok, i'll start to find some vendor who is selling preflashed chips. I'll wait a moment if someone will confirm this fault true.
                                  Big thanks to you 👍
                                  • rediii
                                    h???, spurrrn
                                    • Mar 2018
                                    • 487
                                    • somewhere in europe
                                    #37
                                    Big thanks to you 👍
                                    i know one trustworthy guy, who is selling these ics programmed on ebay (pitstopcomputers). just ask him, he will help you out for sure. and give him my best regards, pls
                                    • kuupotin
                                      • Aug 2016
                                      • 30
                                      • Finland
                                      #38
                                      Ok, big thanks. Let's put that behind the ear (finnish saying to keep something in mind)
                                      • reformatt
                                        • Feb 2020
                                        • 1412
                                        With Acers with integrated power buttons in the keyboard, you should always rule out that out first. They are the most common failure I see and can hold the on/off line down low. This basically appears as if you are holding the power button down and can be misinterpreted as a faulty EC.
                                        With all Acers (and some Lenovo's too with power button in the keyboard) I first disconnect the keyboard, and trigger it manually with tweezers. So in this one its pin 1 of KB1, short it briefly to ground and test.
                                        • mcplslg123
                                          • Jun 2015
                                          • 7262
                                          • india
                                          #40
                                          As @mon2 has highlighted, it seems something wrong in RTC circuit. I'll suggest to check these first before jumping on the conclusion of defective KBC. I've never seen a bad EC pulling down RTC circuit. If thats the case here, it'll be rare instance. My doubt goes to PCH instead.
                                          01.Resistance on Q1701-All pins
                                          02.Resistance on G1701 pin2.
                                          If resistance on G1701 jumper,pin2 is low, you are very likely staring at a shorted RTC section of PCH. If you are lucky, it could be a shorted cap on RTC lines.
                                            Acer Swift Acer Swift 3 Ultraschlankes Notebook Notebook 3 Specification for Upgrade or Repair
                                            This specification for the Acer Swift Acer Swift 3 Ultraschlankes Notebook Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Acer Swift 3 Ultraschlankes Notebook boardview and Acer Swift 3 Ultraschlankes Notebook schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that...
                                            09-07-2024, 05:00 AM
                                            Acer Swift Swift X Notebook X Specification for Upgrade or Repair
                                            This specification for the Acer Swift Swift X Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Swift X boardview and Swift X schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Acer Swift...
                                            09-07-2024, 02:20 AM
                                            Acer Swift Swift 1 Netbook 1 Specification for Upgrade or Repair
                                            This specification for the Acer Swift Swift 1 Netbook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Swift 1 boardview and Swift 1 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Acer Swift Swift...
                                            Acer Swift SF314-511-55X6 + Pack Gold Acer 14'' Notebook 3 Specification for Upgrade or Repair
                                            This specification for the Acer Swift SF314-511-55X6 + Pack Gold Acer 14'' Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the SF314-511-55X6 + Pack Gold Acer 14'' boardview and SF314-511-55X6 + Pack Gold Acer 14'' schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that...
                                            09-07-2024, 03:10 AM
                                            Acer Swift SF114-34-P2H0 + Pack Gold Acer 14'' Notebook 1 Specification for Upgrade or Repair
                                            This specification for the Acer Swift SF114-34-P2H0 + Pack Gold Acer 14'' Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the SF114-34-P2H0 + Pack Gold Acer 14'' boardview and SF114-34-P2H0 + Pack Gold Acer 14'' schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we...
