Asus STRIX GL703GE keyboard issue
  • macbook1967
    • Feb 2022
    • 13
    • US
    I need help in troubleshooting an Asus STRIX GL703GE. This laptop has no working keyboard and keyboard lights. Device Manager does not show any keyboard at all (it shows a USB keyboard if connected, but not built in). The touchpad and ON/OFF button are ok. I checked keyboard circuitry on a motherboard, and everything seems to be good except there is no KBL_EN signal on pin #64 of IT8296E120A Keyboard Controller (U23, +3V_S5 is present). Pin #63 LED_PWR#_KB has 3.6V. Pin #1 on KCN1 KB CONN has 5.1V, pins #7-30 have 2.5V. G524 Power Distribution Switch (U24) is not shorted: pin #5 - 5v, pin #4 - 0V, pin #1 - 0V.
    KBID1 not present (pin#36 - KCN1 KB CONN and pin#8 - U23), KR133 and KR91 are ok. Replacement keyboard brings the same issue.
    Does that mean U23 IT8296E_LQFP-64 chip is faulty? If so, is it necessary to program new IT8296E chip?
  • mon2
    • 14659
    Re: Asus STRIX GL703GE keyboard issue
    Does the keyboard work in the bios?
    • macbook1967
      • Feb 2022
      • 13
      • US
      No. But the keyboard itself is good.
      • mon2
        • 14659
        Remove all power. Measure the resistance to ground of KBL_EN.
        Also check in DIODE mode.
        Meter in diode mode. Red meter lead, yes red to ground.
        Black meter probe to KBL_EN.
        What is the reading?
        • macbook1967
          • Feb 2022
          • 13
          • US
          98.2kOhm
          0.564V
          • mon2
            • 14659
            Ok readings.
            What is the voltage to ground of pin #13 (wrst#) on the EC? (U23)
            The KBL_EN is for the keyboard backlight leds.
            The keyboard will be a detection of passive keys being scanned in x&y directions. Is U23 warmer than usual?
            Is it being powered on every rail.
            • macbook1967
              • Feb 2022
              • 13
              • US
              pin #13 - 0.12V
              KR43 - 99kOhm
              KC44 not shorted
              U23 is not warmer as usual.
              P.S. I've motherboard removed from the laptop --> +5V_S5, +3V_S5 are missing. Let me assemble it.
              • mon2
                • 14659
                +3V_S5 are missing
                Yes and this is causing this EC controller to remain in reset state.
                WRST# = active low signal and pin #13 - 0.12V = RESET state.
                Confirm again after this line is ~3 volts = out of reset state.
                • macbook1967
                  • Feb 2022
                  • 13
                  • US
                  OK, the laptop is on: pin #13 - 3.28V
                  • elmark
                    HP 15-cw1002ua strange keyboard issue
                    by elmark
                    HP Pavilion 15-CW1002UA
                    S/N 5CD0251CBC
                    P/N 7KE54EA
                    Hello guys!
                    I have a strange issue with my laptop keyboard and I'm lost trying to detect what's wrong - the KB9028Q-C or the keyboard itself.
                    It powers on OK and has no other issues except the following:
                    • CAPS LOCK does not work at all
                    • Fn button toggles Flight Mode
                    • When I press 't' or '5', it produces 't5', and when I press 'y' or '6', it produces 'y6'
                    • (with SHIFT pressed: 't%' and 'y^' respectively)
                    I initially thought it was a keyboard malfunction (internal short, etc.),
                    but when I press and hold...
                    06-27-2025, 01:10 AM
                  • ugamazing
                    820-02020 Super Weird Issue: Keyboard Input Character Map "Wrong"?
                    by ugamazing
                    So, I have a really bizarre issue that I'm struggling to identify the cause of. Working on an 820-02020 board with some bizarre keyboard/input-source character mapping. My suspicion is a possible damaged SPI ROM (U1970), perhaps, but I'm really not sure in this case:
                    1. The issue is pretty weird, but when installing MacOS, I noticed my WiFi password did not work. I quickly realized the special characters (!@#$%^& etc) were not mapping correctly.
                    2. I noticed the keyboard layout/input-source is defaulting to JAPANESE every single time I restore the board. I am not...
                    04-10-2024, 08:06 AM
                  • hollox123
                    ASUS ROG Strix G713QR - Keyboard, backlight and side LEDs don't work
                    by hollox123
                    Hello, I have an "ASUS ROG Strix G713QR" laptop, and for approx. 3 months I have the following problems:
                    1. Laptop keyboard doesn't work
                    2. The backlight on the laptop keyboard doesn't work
                    3. The x2 side LEDs (red) on the laptop don't work
                    The power button works, the touchpad works, and all the USB, HDMI, Ethernet, etc. ports work.
                    I already tried to reinstall all the drivers and reinstall Windows. So I don't know what to try anymore that is software-related.
                    But I am strongly aiming that it is somehow a BIOS-related problem,...
                    05-11-2025, 08:05 AM
                    ASUS 14.0 FHD 1920X1080 16:9 non-Touch Wide View / 7505 / Intel UMA / 4GB / 128GB PCIE G3 SSD / WIN10 HOME S / N/A /Chiclet Keyboard / To Notebook Specification for Upgrade or Repair
                    This specification for the ASUS 14.0 FHD 1920X1080 16:9 non-Touch Wide View / 7505 / Intel UMA / 4GB / 128GB PCIE G3 SSD / WIN10 HOME S / N/A /Chiclet Keyboard / To Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 14.0 FHD 1920X1080 16:9 non-Touch Wide View / 7505 / Intel UMA / 4GB / 128GB PCIE G3 SSD / WIN10 HOME S / N/A /Chiclet Keyboard / To boardview and 14.0 FHD 1920X1080 16:9 non-Touch Wide View / 7505 / Intel UMA / 4GB / 128GB PCIE G3 SSD / WIN10 HOME S / N/A /Chiclet Keyboard...
                    09-07-2024, 02:50 AM
                  • Safio
                    Asus Rog Strix g15 g512LI BOOT ISSUE
                    by Safio
                    Hello
                    My asus rog strix g15 g512 keeps repeating the "Republic of Gamers" animation and won't power on. Anyone know what could be wrong with it?
                    i tried to install new system on it but it is same issue , does the same thing when i try to boot from usb or externals hard drive, flashed bios still same issue , if its a hardawre issue please share your experience
                    thank you
                    06-08-2024, 08:43 PM
