HP Pavilion x360 - 13-s060sa HDD no detection
  • OKRPKCOMP
    • Dec 2020
    • 432
    • PAKISTAN
    board code: FAUCHON-BDW MB 14259-2
    serial no: 8CG52617B7
    everything is fine,, only hdd detecting problem
    need help. thanks advance
  • mon2
    • Dec 2019
    • 14369
    Re: HP Pavilion x360 - 13-s060sa HDD no detection
    Is the drive being tested a known good drive?
    Check all related cables and connector contacts.
    For M.2 ssd - Check the connector and the PCIe capacitors that will be nearby the same connector. They should not be damaged or missing.
    • OKRPKCOMP
      • Dec 2020
      • 432
      • PAKISTAN
      Yes, hdd checked properly and replaced it also
      there is no option for m2 ssd. only sata hdd option available.
      Also checked capacitors,
        • 21218
        HDD_Redriver U5603 SN75LVCP601RTJR-G
        Datasheet https://www.ti.com/lit/gpn/sn75lvcp601
        • OKRPKCOMP
          • Dec 2020
          • 432
          • PAKISTAN
          Sir, i tried my best to find U5603 on this motherboard
          i didnt find it
          where it is located on board
          • OKRPKCOMP
            • Dec 2020
            • 432
            • PAKISTAN
            i didnt find it
            i find schmatic on this site
            But this one also the exact diagrame for this board
            • OKRPKCOMP
              • Dec 2020
              • 432
              • PAKISTAN
              this is my board
              • OKRPKCOMP
                • Dec 2020
                • 432
                • PAKISTAN
                this is my board
                This is location for u5603 but there is no ic
                • OKRPKCOMP
                  • Dec 2020
                  • 432
                  • PAKISTAN
                  Anybody help
                  • mon2
                    • Dec 2019
                    • 14369
                    Is this a known good logic board or a spare purchased from Ebay or similar? That is, is it possible that some parts are missing from this logic board by other techs?
                    • OKRPKCOMP
                      • Dec 2020
                      • 432
                      • PAKISTAN
                      This one is good logic board from hp company. some days before it was detecting harddrive and running windows fine. but i by mistake removed
                      PR4413 (R010) Fuse type resistor, afterthat this problem occured
                      i put back that part again, but went something wrong for hdd detection
                      • mon2
                        • Dec 2019
                        • 14369
                        Unable to locate a schematic for this model. If only this current sense resistor was removed, consider to flux it well and reflow the part to see if this will fix the fault.
                        • OKRPKCOMP
                          • Dec 2020
                          • 432
                          • PAKISTAN
                          Yes cant find the schematic for this model. and also fails to find the faulty ic or something else, which stops to detect hdd.
                          i posted the board pics also
                          can u guess which component is faulty?
                          • mon2
                            • Dec 2019
                            • 14369
                            Post a clear pic of where the HDD Sata connects to the logic board. Perhaps some component is missing from the other rework.
                            • OKRPKCOMP
                              • Dec 2020
                              • 432
                              • PAKISTAN
                              post a clear pic of where the hdd sata connects to the logic board. Perhaps some component is missing from the other rework.
                              2nd pic is backside of hdd jack
                              • mcplslg123
                                • Jun 2015
                                • 7262
                                • india
                                The HDD cable often goes faulty. Have you ruled that out??
                                • OKRPKCOMP
                                  • Dec 2020
                                  • 432
                                  • PAKISTAN
                                  yes i have changed it first of all
                                  replaced with working one
                                    • 21218
                                    Did you install intel RST driver
                                    • OKRPKCOMP
                                      • Dec 2020
                                      • 432
                                      • PAKISTAN
                                      May i instal it before windows and without hdd detection????
                                      it it, then plz guide me
                                      • J_PH
                                        • Dec 2022
                                        • 37
                                        • Chile
                                        if the BIOS has not detected the HDD it is highly unlikely that you need the RST drivers.
                                        If the HDD is recognized by the BIOS but does not appear as a drive for windows installation, you will have to manually load the driver at installation.
