HP ZBook 15 G3 won‘t turn off
  • Razor0601
    • May 2021
    • 34
    Good morning, I have an HP ZBook 15 G3 which will not turn off. When I shut it down from windows, the screen and power LED turns off but WLAN and Speaker LED‘s are still on and the GPU Fan goes on full speed. This is on battery only. If I plug in the AC Adapter or also with battery and shut it down the ZBook stays off but the wlan and speaker led‘s stays on. Can someone help me?
  • mon2
    • 14664
    Re: HP ZBook 15 G3 won‘t turn off
    Link or post the schematic.
    Review the voltage rail that powers the LAN / WLAN.
    Perhaps you have wake on lan setting active? For this the to work, that controller needs to be powered.
    Are you able to enter and exit the bios? Power down is normal?
    If on power adapter only, remove the battery, same issue?
    Perhaps some mosfet is leaking and keeping the logic board powered but schematic will help. We need to know at least the charger IC onboard. Likely the 'BQ' series from Texas Instruments.
    • Razor0601
      • May 2021
      • 34
      Sorry, I have no Schematic for the ZBook. I can go into Bios and will check if this setting is enalbled or not.
      On AC Adapter or on AC Adapter and with battery it shut down completely except the WLAN and Speaker LED‘s are on.
      There was another Thread but for ZBook 15 G2. There it was the DC DC Converter. Could that also be the issue?
      • mon2
        • 14664
        Share all silk screen markings on the logic board that may help us to identify the schematic.
        • Razor0601
          • May 2021
          • 34
          You mean to identify the Mainboard?
            • 21889
            Yes.Each motherboard has a model number
            https://www.badcaps.net/forum/showthread.php?t=88758
            1.1.3 Motherboard model number
            • Razor0601
              • May 2021
              • 34
              The Number is LA-C381P
              • Razor0601
                • May 2021
                • 34
                I think there is no schematic?
                • mon2
                  • 14664
                  From the internet...the charger IC on this logic board is
                  pu8 = BQ24780s
                  Can you confirm this detail?
                  • Razor0601
                    • May 2021
                    • 34
                    I don't think so.
                    • mon2
                      • 14664
                      Can you post a better pic of this area? It is a very small image from this side.
                      Zbook 15 G6 has the TI charger IC - maybe your G3 does as well under a different part # ?
                      • Razor0601
                        • May 2021
                        • 34
                        Can you see it now?
                        • mon2
                          • 14664
                          Yes. The (same as referenced earlier) charger chip can be seen to the right of the PU8 silk screen. It is the square IC with the 2478x markings on the second line. BQ on the top line.
                          • Razor0601
                            • May 2021
                            • 34
                            And this one must be replaced?
                            • mon2
                              • 14664
                              OMG that is a good & clear picture Recently ordered a 4k microscope - ETA is next week sometime.
                              No, we do not want to replace this part but only want to check the voltages linked to this charger IC.
                              Now that we know the charger IC #, we can use reference designs / schematics or even the factory datasheet (if public) from Texas Instruments (TI). TI acquired the BenchmarQ group that designed this IC. That is why it has the 'BQ' marking.
                              Will post more details after a late lunch break.
                              • mcplslg123
                                • Jun 2015
                                • 7262
                                • india
                                I'll start with removing the wifi card and then desoldering the sound chip. this problem has nothing to do with charging chip in my opinion. If problem persists after these steps, Look for dc-dc converter. the Enable for DC-DC conversion is perhaps not removed even after shutdown and that may be due to a broken dc-dc converter. So take the following steps in sequence.
                                01.Remove wifi card
                                02.De-solder sound chip
                                03.De solder lan chip
                                04.Clean install windows
                                05.Probe dc-dc conversion for 3V/5V.
                                • Razor0601
                                  • May 2021
                                  • 34
                                  01.Remove wifi card
                                  Do you know which is the DC-DC converter?
                                  • mcplslg123
                                    • Jun 2015
                                    • 7262
                                    • india
                                    Look for an IC with 7 pins on each side i.e total 14 pins. Since Scheme not avlbl, i cant confirm the part number but google TPS22966 to get a image of the likely target ic. Dc-DC conversion circuit is designed in many ways and differs between boards. With newer boards, usually this ic is 14 pins.
                                      HP ZBook ZBook 15v G5 Mobile Workstation (7PA09AV) Mobile workstation 15v Specification for Upgrade or Repair
                                      This specification for the HP ZBook ZBook 15v G5 Mobile Workstation (7PA09AV) Mobile workstation can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the ZBook 15v G5 Mobile Workstation (7PA09AV) boardview and ZBook 15v G5 Mobile Workstation (7PA09AV) schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps...
                                      09-06-2024, 12:10 PM
                                      HP ZBook ZBook 14u G6 Mobile Workstation Mobile workstation 14u Specification for Upgrade or Repair
                                      This specification for the HP ZBook ZBook 14u G6 Mobile Workstation Mobile workstation can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the ZBook 14u G6 Mobile Workstation boardview and ZBook 14u G6 Mobile Workstation schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer...
                                      09-06-2024, 09:10 AM
                                      HP ZBook ZBook 15 G2 Mobile workstation 15 Specification for Upgrade or Repair
                                      This specification for the HP ZBook ZBook 15 G2 Mobile workstation can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the ZBook 15 G2 boardview and ZBook 15 G2 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                                      09-06-2024, 08:20 AM
                                      HP ZBook Workstation ZBook 15 G3 Mobile workstation 15 Specification for Upgrade or Repair
                                      This specification for the HP ZBook Workstation ZBook 15 G3 Mobile workstation can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Workstation ZBook 15 G3 boardview and Workstation ZBook 15 G3 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any...
                                      HP ZBook Workstation ZBook 17 G3 Mobile workstation 17 Specification for Upgrade or Repair
                                      This specification for the HP ZBook Workstation ZBook 17 G3 Mobile workstation can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Workstation ZBook 17 G3 boardview and Workstation ZBook 17 G3 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any...
