Re: PS2 Slim Not Powering On
Buck converter is a step down converter. It takes a certain voltage and steps it down to a different one. And yes that in the picture are them.
Well, I guess you have to follow the power to the buck converters that convert the 8.8 down to 1.8V, 3.3v etc that are on the top side of the board. There has to be one buck converter (stby) that’s always on. If it’s not working, things are simple. If the stby buck converter does work and no LED, I’d say you got a junk board for parts. The buck converters are on the top side of the board from the yellow plug all the way down to the coin cell battery.
Look at the bright side, you got a working board to cheat your way through it. Just don’t short anything out, other than that you got 2 paper weights.Leave a comment:
Ah! So there is power going through the fuse. Keep the black probe on the black point (Ground reference) and move the red probe to both sides the fuse PS15 below. See if power is going through it.Leave a comment:
Btw… you don’t measure voltage with both probes on both sides of the fuse, right?Leave a comment:
For shits and giggles put the power directly to the far end of the fuse and see if the led comes on.Leave a comment:
re-flow the solder on the yellow socket - the joint on the right looks a bit suspectLeave a comment:
yea, here is nothing but a copper track between that connector and the fuse.
check again, but meter the connector from it's actual solder joints
if you still get voltage then maybe the soldering under the fuse is crackedLeave a comment:
Post 5, second pic, top right is a yellow connector. You saying you get 8.8V there and no voltage on either end of the fuse below it? I am saying bad connector.Leave a comment:
The AC Adapter prominently specifies 8.5V (this is not an OEM PSU). MM shows 8.88 from the adapter and 8.88 on the mobo where the DC Connector is.
I am not getting any voltage at the main fuse, however I am getting continuity between the both points of the fuse.
The standby LED is off.
A user, Lotas, highlighted a bunch of the fuses in an attached picture. I checked the fuses and they all demonstrated continuity.Leave a comment:
do you get 12v at the main fuse?
maybe the connector is badLeave a comment:
Just to double check:
When you plug in a good working PSU into the main board, you don’t have the standby led and everything is dead?
Now with the PSU plugged into power and with the main board connected, measure the dc voltage again on the main board. See if you got power while everything is plugged in.
There has to be constant power to the main board for the Stby to work. If I remember correctly the power supply puts out 12V., this has to run through some fuses and some buck converters and finally arrive at the main ic. There are a shitload of fuses one the board marked PSxx. It can’t be the power button, if the standby led isn’t even on. The next problem could be the thing stuck in reset somehow..Leave a comment:
I can confirm with 100% certainty that there is an abundance of flux in that area.Leave a comment:
I found an identical part on another mobo and they look identical. They both have the same continuity tooLeave a comment:
This specification for the SHUTTLE XPC slim DX30 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the XPC slim DX30 boardview and XPC slim DX30 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for SHUTTLE...09-12-2024, 03:30 PM
This specification for the SHUTTLE XPC slim Office DL1000XA can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the XPC slim Office DL1000XA boardview and XPC slim Office DL1000XA schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...09-12-2024, 03:28 PM
This specification for the HP Slim Desktop S01-aF0010ns can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Slim Desktop S01-aF0010ns boardview and Slim Desktop S01-aF0010ns schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...09-12-2024, 03:28 PM
This specification for the HP Slim Desktop S01-pF0127d can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Slim Desktop S01-pF0127d boardview and Slim Desktop S01-pF0127d schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...09-12-2024, 03:28 PM
This specification for the SHUTTLE XPC slim DH110SE can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the XPC slim DH110SE boardview and XPC slim DH110SE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...09-12-2024, 03:28 PM
- Loading...
