Dell Wyse 5070 3 LED blinks
  • noTurner
    • Nov 2022
    • 61
    • Austria
    Hi there! I'm having some problems with some Dell Wyse 5070 ThinClients. We have a lot of clients laying around which need, according to the blinks of the orange LED (3 Blink, pause, 3 Blink = BIOS Recovery image not found), a cleaned BIOS. I have dumped the BIOS from a fully working Wyse 5070 and flashed one broken Wyse 5070, but unfortunately, it didn't really work. The LED is white which means it's powered on, but as soon as it gives output to all USB ports, it blinks orange again. What should I do in this case?
    The chip is a Winbond W25Q128FWSG, 1,8V.
    I hope that there is a way to revive these.
    Thanks!
  • hardware1
    • Sep 2021
    • 2948
    • N/A
    Re: Dell Wyse 5070 3 LED blinks
    Thanks!
    The file is TXE Configured, that's mean it didn't used before.
    Your dump file is from the working machine or the broken one?
    Also try this file.
    all donations are welcome,
    • noTurner
      • Nov 2022
      • 61
      • Austria
      Also try this file.
      Hey, thanks for the answer! It's from the working machine, as I couldn't dump the broken one for some reason. It couldn't read it's contents properly. But now, it has the dump from the working one and I also verified the chip contents using ch341a software. I'll try that file tomorrow. What did you modify specifically?
      Thanks again!
      • hardware1
        • Sep 2021
        • 2948
        • N/A
        Thanks again!
        I have replaced the old bios region using the latest version that provided by Dell.
        • noTurner
          • Nov 2022
          • 61
          • Austria
          Ah okay, one more question.. is it really necessary to verify chip content after flashing?
          Thanks again!
          • hardware1
            • Sep 2021
            • 2948
            • N/A
            Thanks again!
            Yes, it's important to be sure that the programming process done correctly.
            • noTurner
              • Nov 2022
              • 61
              • Austria
              And which programmer software is the best? Using a cheap CH341A.
              • hardware1
                • Sep 2021
                • 2948
                • N/A
                NeoProgrammer works fine, or you can search and find a better one.
                • noTurner
                  • Nov 2022
                  • 61
                  • Austria
                  Hi! It didn't work, it's still the same. Looking for BIOS update image, but it's turned on. No display.
                  • noTurner
                    • Nov 2022
                    • 61
                    • Austria
                    Ok, so it worked now and we got a picture, I'm able to access the BIOS and so on. But we can't use Wyse Imaging tool. It tells me that there is no security key set (wrong one) and that the platform architecture is not matching. I mean.. we are configuring all clients with this tool..
                    Any way to solve that? I'm sure it has to do something with the BIOS.
                    But thanks for reviving it.
                    • noTurner
                      • Nov 2022
                      • 61
                      • Austria
                      Any solution for this issue? Are there any BIOS regions storing the service tag or security keys? I mean, it's showing a picture but I can't get it imaged which leads us to a "non-functional" thin client.
                      Thanks!
                      • noTurner
                        • Nov 2022
                        • 61
                        • Austria
                        @hardware1 is it possible to use an older BIOS version such as 1.3.1? I could dump an even older BIOS version from another thin client.
                        • noTurner
                          • Nov 2022
                          • 61
                          • Austria
                          I got a dump for BIOS version 1.1.3. Flashed it on the broken ThinClient, now I have a white LED without any display output. Here's the dump. Anyone able to clean it for me?
                          Thanks!
                          • hardware1
                            • Sep 2021
                            • 2948
                            • N/A
                            Thanks!
                            I'm not aware about thin client device, I don't know how it does work or what's the different between it and the normal PCs. If you want to move your old service tag to the new bios file, you should have the original bios backup.
                            • noTurner
                              • Nov 2022
                              • 61
                              • Austria
                              It works like a PC, but we put a ThinOS image on it to run properly. It also lets me to enter my Service tag, so no worries. But unfortunately, it is in need of some security key I don't know about. That's why I wanted to use 1.1.3 BIOS to try it out again. Can you do that for me? Or is it really necessary to use the newest BIOS?
                              Thanks!
                              • noTurner
                                • Nov 2022
                                • 61
                                • Austria
                                Is there any way to extract 1.18.0 BIOS from this exe?
                                For reviving another ThinClient which has 3 LED blinks.. Service Tag: B9N45P2
                                Thanks!
                                • noTurner
                                  • Nov 2022
                                  • 61
                                  • Austria
                                  Hi hoaca388, here is the corrupt BIOS.
                                  Thanks!
                                  • noTurner
                                    • Nov 2022
                                    • 61
                                    • Austria
                                    Dell Wyse 5070 - BIOS needed
                                    Hey there!
                                    I need a cleaned bin for this Dell Wyse Thin Client.
                                    Corrupt BIOS uploaded.
                                    Thanks!
                                    • noTurner
                                      • Nov 2022
                                      • 61
                                      • Austria
                                      Is the attachment visible? xD
                                      • noTurner
                                        • Nov 2022
                                        • 61
                                        • Austria
                                        Re: Dell Wyse 5070 - BIOS needed
                                        Oh, the motherboard works, I can even charge devices using the USB-C port. It's just the BIOS having issues.
                                          DELL OptiPlex 5070 OptiPlex 3000 i5-9500T Specification for Upgrade or Repair
                                          This specification for the DELL OptiPlex 5070 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the OptiPlex 5070 boardview and OptiPlex 5070 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL...
                                          09-12-2024, 03:44 PM
                                          DELL OptiPlex 5070 OptiPlex 3000 i5-9500 Specification for Upgrade or Repair
                                          DELL OptiPlex 5070 OptiPlex 5000 i5-9500T Specification for Upgrade or Repair
                                          09-12-2024, 03:36 PM
                                          DELL OptiPlex 5070 OptiPlex 3000 i7-9700 Specification for Upgrade or Repair
