Lenovo ThinkCentre M920s - 10SJ-000VUS - I3X0MS - BIOS locked
  • snhcfixes
    • Apr 2022
    • 5
    Greetings,
    I have a ThinkCentre M920s (type 10SJ-000VUS) with a supervisor password. The motherboard model is I3X0MS.
    I tried already the suggestion to clear CMOS, remove CMOS battery, etc. on this model to clear the password. Even the manual suggests that this should remove the password but simply had no luck with this method.
    Attached is a dump of the BIOS. The chip type is a W25Q128JV.
    Thanks for your suggestions!
    Edit: Realized this is posted in the mobile devices section. Apologies! Could someone move this to the desktop BIOS section?
  • snhcfixes
    • Apr 2022
    • 5
    Re: Lenovo ThinkCentre M920s - 10SJ-000VUS - I3X0MS - BIOS locked
    Any suggestions? Grateful for any ideas!
    So far all my searches off-site for this particular model have lead me to questionable sites behind paywalls.
    Thanks!
    • keeney123
      Lauren
      • Sep 2014
      • 2536
      Originally posted by snhcfixes
      Greetings,
      So, you followed this Manufacturer's Exact Model with motherboard in the Manual procedure to clear the CMOS chip and it did not clear the BIOS Security?
      Wonder if the procedure told you to take out the battery, unplug unit, press the power button for 30 sec.
      If all that was done, I would also do the above procedure first and then remove the hard drive, and external connected devices and ram. Do not reconnect the devices. Just reconnect the BIOS battery and plug in only the power cord. and press the power button to boot up. See if it will get into the BIOS and if the supervisory password is reset.
      If the above is done I would consider the manufacturers procedure to be incorrect. Is this a UEFI BIOS? I had an Acer UEFI BIOS that automatically set the hard drive password. They only allow the user to change this after first boot up into the BIOS after a certain procedure was done. After that they set the Hard drive password themselves. The supervisory password could not be set until the hard drive password was set.
      • snhcfixes
        • Apr 2022
        • 5
        If all that was done, I would also do the above procedure first and then remove the hard drive, and external connected devices and ram. Do not reconnect the devices. Just reconnect the BIOS battery and plug in only the power cord. and press the power button to boot up. See if it will get into the BIOS.
        Correct. I have tried that and several variations of it. Despite the fact the manual implies this should reset the password, it has not.
        I have not yet tried without the RAM and other devices yet. That's a new idea to me. I will give it a try tomorrow and report back.
        • keeney123
          Lauren
          • Sep 2014
          • 2536
          You might want to tell the manufacturer their procedure fails. Also, have you read the attach PDF?
          Your unit has a clear Cmos jumper look at below 920 hardware manual attached page 9
          Correct proceedure for clearing the Cmos with jumper is in information manual. page 23
          Manual attached below.
          All information from lenovo site.
          • snhcfixes
            • Apr 2022
            • 5
            Thanks for these files. I had the UGHMM PDF already but have not seen the other ones. I followed the BIOS recovery procedure in the IPIG document (burnt a CD, enable the CMOS recovery jumper, update the BIOS) and this worked perfectly.
            No idea why the other procedure did not work for me but at least this is a manageable solution. I have a couple more of these boxes I will try this on but I have no doubts this will work for them too.
            Thanks for the help.
            • keeney123
              Lauren
              • Sep 2014
              • 2536
              Glad you got it working. I don't know why Manufacturer has to hide a procedure in multiple PFD instead of just one. It is almost like trying to follow a law that has been written. One has to jump around a lot.
              • hotcrossedbuns999
                M715q Desktop (ThinkCentre) - Type 10M3 - Request bios chip location and useable bios for use with CH341A Programmer.
                by hotcrossedbuns999
                My pc updated bios through Windows Update and I was greeted with BLACK SCREEN WITH CPU FAN MAX SPEED. I don't think there is even a screen signal, because it triggers my monitor for a couple seconds and then the monitor turns off. I tried the other outputs as well.
                1. I tried clearing bios, resetting bios, removed the CMOS battery, removed m.2 ssd, wifi, and ram. Still black screen with CPU fan blasting.
                2. I tried using the Lenovo BIOS CD and BIOS USB, but neither worked. At least I couldn't get anything to work.
                3. I could only locate two chips that look like bios chips. Could someone verify this
                01-03-2025, 12:32 PM
                LENOVO ThinkCentre M920s ThinkCentre M i5-8500 Specification for Upgrade or Repair
                This specification for the LENOVO ThinkCentre M920s can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the ThinkCentre M920s boardview and ThinkCentre M920s schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                09-12-2024, 01:58 PM
                LENOVO ThinkCentre M920s ThinkCentre M i5-9500 Specification for Upgrade or Repair
