HP ProDesk 400 G6 Small Form Factor PC bios
  • kt1998
    • Aug 2024
    • 12
    #81
    Hi, I have another HP ProDesk 400 G6 desktop mini PC bios got corrupted. If you could, can you teach me how to recover 400 G6 corrupted? because i have like 70 of it in my school.
    Serial 8CC1241JFP
    SKU 227Q1PA#UUF
    Thanks again for the help.
    • Sentano
      • Nov 2024
      I have an HP ProDesk 400 G6 desktop mini PC where the bois is bricked. Could someone help me?
      Serial 8CC1384CQP
      SKU 23H17EA#ABD
      Many thanks in advance
      • kt1998
        • Aug 2024
        • 12
        #83
        Serial 8CC1384CQP
        SKU 23H17EA#ABD
        HP ProDesk 400 G6 desktop mini PC Bundle
        • Sentano
          • Nov 2024
          Great, works perfectly and has been given a second life. thanks kt1998
          • SultanPindakaas
            • Jan 2025
            • 5
            • Nederland
            #85
            Do you guys use the SOP16 clip or a 8 clip for the bios?
            • Sentano
              • Nov 2024
              It's a 16 pin Chip, so I use a SOP16 clip with a 16 pin to 8 pin adaptor.
              • SultanPindakaas
                • Jan 2025
                • 5
                • Nederland
                #87
                Thank you for the information.
                • SultanPindakaas
                  • Jan 2025
                  • 5
                  • Nederland
                  #88
                  What am i doing wrong? It just wont detect..
                  • SultanPindakaas
                    • Jan 2025
                    • 5
                    • Nederland
                    #89
                    Oke i found a way to connect, i also hear windows making a sound that something has been connected, but it wont read it.... any clues?
                    • kt1998
                      • Aug 2024
                      • 12
                      #90
                      ​It's seem to be you are using the wrong 16 to 8sop clip
                      16 to 8 pin only use 8 pin from 8 header corners pin of the chip
                      you can modify the one you have or buy the right one
                      the correct trace is on the clam pcb there is place to solder 16 pin chip follow the trace under pcb to match which pin of 16 connect to 8 pin
                      when you connect ch431a to computer i recommend you should plug directly instead of external cable
                      use the ch341a programming software to detect the chip
                      Click image for larger version  Name:	image.jpg Views:	0 Size:	65.1 KB ID:	3540740
                      • SultanPindakaas
                        • Jan 2025
                        • 5
                        • Nederland
                        #91
                        Oke done that now. But now i keep getting this error…
                        • JITESH MOORPANI
                          • Aug 2024
                          • INDIA
                          #92
                          Hello need help, I am looking for the bios of the HP ProDesk 400 G6 Small Form Factor PC
                          SR NO:-MXL943629B
                          PRODUCT NO:- 6EF24AV
                          • mobisota61
                            • Feb 2025
                            • 9
                            • Russia
                            #93
                            Good afternoon!
                            During the bios firmware update, the computer turned off and now does not turn on. The bios firmware is damaged. Could you help me fix the firmware? Thank you.
                            Serial 8CC0471KRJ
                            Product 1C6Z1EA#ACB
                            • hoaca388
                              Badcaps
                              • Jan 2022
                              • 12268
                              #94
                              Originally posted by mobisota61
                              Good afternoon!
                              During the bios firmware update, the computer turned off and now does not turn on. The bios firmware is damaged. Can you help fix the firmware? Thank you.
                              HP ProDesk 400 G6 Desktop Mini PC
                              • mobisota61
                                • Feb 2025
                                • 9
                                • Russia
                                #95
                                That's great!!! I can't believe it! The computer turned on, some time waiting and the HP screensaver appears on the screen.
                                How did you do it?
                                Thank you very much, hoaca388​ !
                                • mobisota61
                                  • Feb 2025
                                  • 9
                                  • Russia
                                  #96
                                  Please excuse me, but another HP Prodesk 400 G6 won't boot also.
                                  It happened after a severe thunderstorm and lightning strike.
                                  The symptoms are as follows - 5 long red beeps and 7 short white beeps. As I understand it, this means that the firmware of the BIOS chip is faulty.
                                  If possible, please help me restore the firmware.
                                  Thank you so much!
                                  Serial 8CC10316S6
                                  Product 1C6Z1EA#ACB
                                  • hoaca388
                                    Badcaps
                                    • Jan 2022
                                    • 12268
                                    #97
                                    Thank you so much!
                                    Serial 8CC10316S6
                                    Product 1C6Z1EA#ACB
                                    • mobisota61
                                      • Feb 2025
                                      • 9
                                      • Russia
                                      #98
                                      Thanks for the reply! But unfortunately, the computer won't start. Still, 5 and 7 beeps. There it possible with hardware trouble...
                                      • mobisota61
                                        • Feb 2025
                                        • 9
                                        • Russia
                                        #99
                                        The chip SRH1A died... Thank you for help
                                        • jeinercm13
                                          • Apr 2025
                                          • Estados Unidos
                                          #100
                                          GOOD AFTERNOON, I HOPE YOU ARE WELL. WHO CAN HELP ME PLEASE? I PRESSED THE CMOS BUTTON ON MY PC AND IT WON'T BOOT. THE LED LIGHT ONLY LIGHTS UP WHEN I PRESS THE POWER BUTTON, AND IT DOESN'T DO ANYTHING ELSE. I'VE BEEN INVESTIGATING AND IT'S A BIOS PROBLEM. IT'S CORRUPT. I NEED YOU TO PLEASE SHARE THE BIOS FOR MY PC WITH ME. I DELETED THE ORIGINAL BIOS AND I DON'T HAVE A BACKUP. I WOULD LIKE YOU TO SHARE THE ORIGINAL. THE ONES YOU'VE SHARED HERE HAVE NOT WORKED FOR ME.
                                          Serial: MXL0383S6K
                                          Product: 7ZE28LA
                                          Thank you for your collaboration. Thank you very much.
