Help me pls. Dell optiplex 3080 clean bios
  • hoaca388
    Badcaps
    • Jan 2022
    • 11659
    Re: Help me pls. Dell optiplex 3080 clean bios
    Show screenshot about "Absolute".
    • elkhiyhie
      • Jun 2020
      • 29
      • philippines
      need to remove the bios password first, to see if the absolute is enabled ..
      but pls remove the bios first thank you.
        • 20731
        Under warranty
        Service Tag: 5XG4SH3 Support Services: ProSupport ⦁
        Expires 16 SEP 2024
        • elkhiyhie
          • Jun 2020
          • 29
          • philippines
          Originally posted by SMDFlea
          Under warranty
          Expires 16 SEP 2024
          its fine to remove sir .
          • elkhiyhie
            • Jun 2020
            • 29
            • philippines
            here is the example of absolute issue, grayed out ..
            • elkhiyhie
              • Jun 2020
              • 29
              • philippines
              #26
              please clean bios password & absolute of these 3 thank you.
              please help me to clean bios password ..
              • Arrow16
                • Apr 2022
                • 229
                • Philippines
                #27
                optiplex 3080 micro bios password need to remove
                need clean me
                anyone can help TIA
                • hardware1
                  • Sep 2021
                  • 2930
                  • N/A
                  #28
                  need clean me
                  anyone can help TIA
                  Here's your Unlocked file, hope it works fine.
                  I don't know why you ask for Clean ME!
                  all donations are welcome,
                  • deepfreak
                    Mr.
                    • Jan 2023
                    • 7
                    • Netherlands
                    #29
                    Hi guys,
                    I have a question for everyone who posted a BIOS dump of the Dell OptiPlex 3080 Micro to remove the admin password.
                    If I understood correctly, you need a Flash Programmer to do this, correct?
                    Which one did you use, i.e. one that can not only successfully read the BIOS but also successfully flash the modified BIOS again?
                    Assuming you also have a SOP 16-pin Macronix MX25L25673GMI-08G BIOS chip installed.
                    Thanks in advance for an answer.
                    • hoaca388
                      Badcaps
                      • Jan 2022
                      • 11659
                      #30
                      Originally posted by deepfreak
                      Hi guys,
                      Red : that right.
                      Blue : I'm using SFLY SP20P
                      https://www.sflytech.com/English/Pro...986173950.html
                      • deepfreak
                        Mr.
                        • Jan 2023
                        • 7
                        • Netherlands
                        #31
                        Red : that right.
                        Thankyou very much for your answer.
                        This flash programmer is probably a very good device, especially if you do something like this often or maybe even commercially.
                        But in my case it would only be one job and therefore the cost-benefit ratio is not acceptable respectively its too expensive.
                        Has anyone else used other cheaper flash programmers successfully for the Dell OptiPlex 3080 Micro?
                        • Arrow16
                          • Apr 2022
                          • 229
                          • Philippines
                          #32
                          dell optiplex 3080 micro biospassword
                          need to unlocked admin passwod
                          and need to know what software you use to edit bios to remove bios/admin password, and thers ny change where i can see an accurate video tutorial how how o use tnx.
                          • Arrow16
                            • Apr 2022
                            • 229
                            • Philippines
                            #33
                            need help fôr this Thnx
                            • hoaca388
                              Badcaps
                              • Jan 2022
                              • 11659
                              #34
                              optiplex 3080 micro
                              • Arrow16
                                • Apr 2022
                                • 229
                                • Philippines
                                #35
                                i have anôther Dell optiplex 3080 micro need to rémove bios password
                                tnx
                                • volinakis
                                  • Jan 2021
                                  • 2721
                                  • N/A
                                  #36
                                  tnx
                                  try
                                  • deepfreak
                                    Mr.
                                    • Jan 2023
                                    • 7
                                    • Netherlands
                                    #37
                                    tnx
                                    Which flash programmer model dou you use to read and write the bios image?
                                    • Arrow16
                                      • Apr 2022
                                      • 229
                                      • Philippines
                                      #38
                                      Dell OptiPlex 3080 micro need help remove bios password and absolute lock enable, no highlights to disable
                                      Here is my dump, tnx
                                      • Arrow16
                                        • Apr 2022
                                        • 229
                                        • Philippines
                                        #39
                                        RT809F isp programmer
                                        • Arrow16
                                          • Apr 2022
                                          • 229
                                          • Philippines
                                          #40
                                          Need help for this bios lock thank you
                                            DELL OptiPlex 3080 OptiPlex 3000 i5-10500T Specification for Upgrade or Repair
                                            This specification for the DELL OptiPlex 3080 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the OptiPlex 3080 boardview and OptiPlex 3080 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL...
                                            09-12-2024, 02:30 PM
                                            DELL OptiPlex 3080 OptiPlex 3000 i5-10500 Specification for Upgrade or Repair
                                            09-12-2024, 03:44 PM
                                            DELL OptiPlex 3080 OptiPlex 3000 i3-10100T Specification for Upgrade or Repair
                                            DELL OptiPlex 3080 OptiPlex 3000 i3-10100 Specification for Upgrade or Repair
                                            09-12-2024, 03:36 PM
