Dell Optiplex 9010 E93839 Bios dump
    need help please i have dell OptiPlex 9010 tower working but no display and no errors lights need bios
    its old files
    thanks for all
    Re: Dell Optiplex 9010
    its old files
    thanks for all
    the posted bios is not ok ... read the bios chip and post again..remove the bios chip from the motherboard, before writing or reading ...
      i removed bios from motherboard first but i will red it again
        Hello. Have a problem with dump.2 Chip corrupto. Ill find this in internet, but not work. restarting with yellow led. anyone has a clear dump?
          Hi. I need bios for Dell Optiplex 9010 E93839
            Re: Dell Optiplex 9010 E93839 Bios dump
            Post your original corrupt bios file and sevice tag number here.
            Become a Badcaps supporter
            Thanks to all supporters.
              Service Tag: HQN5LY1
                Dell OptiPlex 9010
                  Originally posted by hoaca388 View Post
                  Dell OptiPlex 9010
                  It works. Thanks for the help
                    Hello Everybody
                    Clean Following Bump Please
                    PHP Code:
                    [ATTACH]294689[/ATTACH
                      Hello I need the bios for SERV TAG 9ZNMMW1 / Express Service Tag 21747044449, Dell Optiplex 9010, there is 2 chips , one is 8 pin sp1 , and sp2/3 is 16pin.
                        Post your backups.
                          hello guys, can someone help me to fix my bios Optiplex 9010 with SERV TAG 4LDRNW1/ Express Service Tag 10000044721 please
                            Dell OptiPlex 9010
                            Working fine . Thanks
                              I hope someone can help me. I am a complete noob when it comes to BIOS flashing. I corrupted the BIOS in my Dell 9010 desktop trying to update it via an .exe file. Fans run and error LED blinks a BIOS code, but no screen or any other function. I have procured the ch143a programmer and the 9010 desktop BIOS files. I have found the location of the BIOS and EC ICs. Both are next to each other and they are both 8 pin SOP-8 packages. One of the ICs has a dual mount option 8 pin or 16 pin. I have attached a picture where both ICs can be seen. Sorry about the washed out contrast, I can send a new picture if needed. I need to know which IC is the main BIOS and which IC is the EC before I start try to flash and mess up something else. I have looked all over the internet and found everything but which IC is which. Thank you!
                              What is the name of the yellow chip ?
Name:	2025-04-10 14_35_25-Dell Optiplex 9010 BIOS IC Locations - Badcaps.png
                                I did mean to post the IC numbers. Top chip in the picture which you highlighted in yellow is Winbond 25Q32JVSIQ. The bottom IC is a Winbond 25Q64JVSIQ, which I suspect is the main BIOS IC, with the upper IC being the EC IC. Thanks!
                                  Both chips are bios chips, your bios file is 12MB split on one 8MB chip and one 4MB chip.
                                    Yes, they are both BIOS ICs. There are two .bin BIOS files for the Dell 9010 desktop, one is labeled MAIN and the other file EC. So which IC is the MAIN BIOS IC and which one is the EC IC?
