HP Elite Mini 600 G9
  • 16golfr
    • Jul 2023
    • 12
    Hello, this is all new to me. Hoping for some help.
    Uploaded the firmware backup, Hoping I did this right lol
    Thanks for the help
    • 24577
    Please post the PC serial number, and explain what the problem is https://www.badcaps.net/forum/troubl...before-posting
    • volinakis
      • Jan 2021
      • 3254
      • N/A
      Thanks for the help
      is something wrong with your backup, it should have 33.554.432 bytes and it has 32.062.889 bytes. Read it again and if possible read also EC chipset, XU68, on left side of wifi. thanks.
      please support this forum
      • 16golfr
        • Jul 2023
        • 12
        Bios Lock <- HP no longer does resets.. even though It's under warranty.. and I have the receipt.. horrible company
        I actually have 3 of these, I wanted to make into a cluster, it does work for basic os installs, but I need bios access to enable some features
        MXL24030T9
        • 16golfr
          • Jul 2023
          • 12
          Very possible I messed something up... I did the backup via the bios update..
          I just realized you are asking me to pull the data from the chip not what the numbers are lol
          • 16golfr
            • Jul 2023
            • 12
            Let me try and read from bios chip before I read that XU86
            I hope i'm doing this right lol.. I couldn't find the exact chip but closest.. If I'm doing something wrong please advise
            • 16golfr
              • Jul 2023
              • 12
              this isn't right lol
              • volinakis
                • Jan 2021
                • 3254
                • N/A
                use AsProgrammer or Neo Programmer, not software came with CH341A
                • 16golfr
                  • Jul 2023
                  • 12
                  working on it, just trying to figure out IC
                    • 24577
                    What type of clip are you using, SOP or WSON
                    • volinakis
                      • Jan 2021
                      • 3254
                      • N/A
                      I'm not using clips, I desolder chipsets and use adapters for programmer. Clips and CH341 are the perfect recipe for disaster. If you are using clips read chipsets 2-3 times and compare results, if you have 2 identical it means you have a good backup.
                      • 16golfr
                        • Jul 2023
                        • 12
                        that would require me, to get read out in the first place :P
                        going to order a soldering iron, all of mine are to big to work on chips lol
                        • 16golfr
                          • Jul 2023
                          • 12
                          That type of clip and the bottom attachment Click image for larger version
                          • volinakis
                            • Jan 2021
                            • 3254
                            • N/A
                            sorry, I thought you wrote "What type of clip are you using, SOP or WSON"
                            • 16golfr
                              • Jul 2023
                              • 12
                              No worries, I have been told to pickup a WSON8 maybe I try that method first?
                              https://vi.aliexpress.com/item/1005007321023647.html <-not that exact one but to get an idea, I just need to buy the right size for that chip
                              • 16golfr
                                • Jul 2023
                                • 12
                                Life got in the way, let's try this again
                                This machines serial is MXL2413LD4
                                • lokmanolgun
                                  • Aug 2014
                                  • 20
                                  • istanbul
                                  Hello. I have an HP 600 G9 mini PC. I replaced the motherboard, but when I transfer the BIOS, the device boots initially, then gives a BIOS identification error and the display cuts off. Can you help me change the serial number and DMI information in the motherboard's original BIOS? The serial number I want to add to the BIOS is: 8CC225386P
                                  PRODUCT:4B435AV
                                  working motherboard information:
                                  SERIAL:8CC333276D
                                  PRODUCT:8L7V2EC
                                  DAF96MB18B0
                                  BERZERK REV:B
                                  MODEL:F96A
                                  MBQ-2201
                                  The attached BIOSes are working, but there is a BIOS password. Can you help me remove the password and change the DMI information? Thank you.​
                                  • lokmanolgun
                                    • Aug 2014
                                    • 20
                                    • istanbul
                                    SN:8CC33326S5 Please unlock password.
                                    • hoaca388
                                      Badcaps
                                      • Jan 2022
                                      • 12713
                                      PRODUCT:4B435AV
                                      SERIAL:8CC333276D
                                      PRODUCT:8L7V2EC
                                      DAF96MB18B0
                                      BERZERK REV:B
                                      MODEL:F96A
                                      MBQ-2201
                                      Description : HP Elite Mini 600 G9
                                      Serial Number : 8CC333276D
                                      SKU Number : 8L7V2EC#AB8
                                      Buidid : 22WWQ6AD302#SAB8#DAB8
                                      Fearture byte : 3E3Y 6E6J 6S6a 7H7M 7Q7T 7W7d 7j7m bhfP guhK jhk8 m6n7 nVng pDpV .aQ
                                      If you have found our forum useful please consider supporting us. Subscribe for a small monthly fee and receive extra benefits including our bios, boardview & schematic archive.
                                      Subscribe to support us. It only takes 1 minute:
                                      https://www.badcaps.net/settings/subscriptions
                                      • lokmanolgun
                                        • Aug 2014
                                        • 20
                                        • istanbul
                                        Hello, the device turned on but it gives an error saying "bios data identity recovered". After clicking OK, the device resets and the password is still there. I pressed F10 during the first boot but as I said, as soon as it turns on, it gives an error saying "bios data identity recovered". How can I fix it? Thanks.
                                        • Boardview and Schematic Bot
                                          HP Elite Elite Slice Elite i5-6500T Specification for Upgrade or Repair
                                          This specification for the HP Elite Elite Slice can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Elite Elite Slice boardview and Elite Elite Slice schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                                          09-12-2024, 03:44 PM
                                          HP Elite Elite Slice Elite i3-6100T Specification for Upgrade or Repair
                                          HP Elite Elite 7200 MT Elite 7200 i5-2400 Specification for Upgrade or Repair
                                          This specification for the HP Elite Elite 7200 MT can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Elite Elite 7200 MT boardview and Elite Elite 7200 MT schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                                          HP Elite Elite 7100 Microtower PC Elite 7100 i3-530 Specification for Upgrade or Repair
                                          This specification for the HP Elite Elite 7100 Microtower PC can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Elite Elite 7100 Microtower PC boardview and Elite Elite 7100 Microtower PC schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any...
