Hi guys I hope to help someone with this , I made a backup of the bios of this video card, the PCB is EVGA196 Rev1.1, GPU: TU104-450-A1, Tsop: MXIC 25U8033E, 8Gb vRam Samsung
EVGA geforce RTX2080 super bios backup Contribution
by MORETTIGIANTitle:
Description:
Procedure performed:
- Removed backplate
- Reapplied thermal compound
- Reassembled card
- GPU powers on and operates normally under...11 Photos -
by Destroyer-Br[HELP] Acer AN515-55 (LA-J871P Rev: 1B) – Board won't power on after GPU investigation – Suspecting Super I/O or PCH
I'm working on an Acer Nitro 5 unit with the following specs:- Motherboard: LA-J871P Rev: 1B
- Model: Acer AN515-55-59MT
- S/N: NHQ7JAL00403906A973400
- SNID: 03902728734
Initial Issue
The laptop initially presented graphic issues and driver failure (Code 43) for the GPU.
After preventive maintenance (cleaning, thermal paste, etc.), it powered on normally. We disassembled it again to inspect the GPU, reassembled... -
by Shawnb03Requesting Boardview file for an EVGA 2060 Super SC P/N 08G-P4-3062-KR.
Thank you in advance...-
07-20-2025, 09:08 PM -
Thermal pad thickness for various laptop GPU / Graphics Cards
ASUS Dual RTX 2070 OC 8GB
ASUS ROG STRIX RTX 3080 OC
ASUS ROG STRIX RTX 3090
ASUS TUF Gaming RTX 3080 OC Edition
ASUS TUF GTX 1660 S-O6G GAMING
EVGA RTX 3060 Ti XC GAMING 8GB
EVGA RTX 3060 XC GAMING 12GB GDDR6
EVGA RTX 3080 FTW3 ULTRA GAMING
EVGA RTX 3080 TI FTW3 ULTRA GAMING
EVGA RTX 3090 XC3 ULTRA GAMING 24GB
Gainward RTX 2080 Phoenix GS Specs
Gainward RTX 3070 Phoenix 8GB
Gainward RTX 3080 Ti Phoenix
GIGABYTE AORUS RTX 3080 MASTER 10G
Channel: Schematics and Boardviews
by ReparaPCI have an RTX 2070 Super from evga with a blown up IC. With the IC on the card, pin 17 had a short to ground. This pin is connected to the 5V rail by R993, a 0hm resistor. I removed both U610 and R993, to discover that the 5V rail has 800 Ohms of resistance to ground. After checking some resources online, i found a picture which describes the usual measurements a Turing series GPU should have in order to "work properlly". Interestingly enough, this gpu doesn't have U31, the IC responsible for the creation of the 5V on the card, as well as no L47.
Are these 800 ohms rigth... - Loading...
