Seeking GA-970A-DS3 Schematic and Boardview
  • AstutePauciloquent
    • Oct 2023
    • 9
    • New Zealand
    Hi, I'm working on this GA-970A-DS3 REV1.0 as a hobby to learn motherboard diagnostics. Today I found 2 inductors that are shorted to ground. So i am requesting your help to locate the GA-970A-DS3 Schematic and Boardview, to help further locate the shorted component.
    Thanks for your time.
  • pooya_pm
    • Jan 2021
    • 254
    • iraq
    Re: Seeking GA-970A-DS3 Schematic and Boardview
    Originally posted by astutepauciloquent
    hi, i'm working on this ga-970a-ds3 rev1.0 as a hobby to learn motherboard diagnostics. Today i found 2 inductors that are shorted to ground. So i am requesting your help to locate the ga-970a-ds3 schematic and boardview, to help further locate the shorted component.
    pdf schematics
    • AL._.EX
      • Dec 2022
      • 890
      • Belarus
      Boardview
      • Yagers
        MSI B450 Gaming Pro Carbon AC MS-7B85 rev 1.1 schematic and/or boardview, seeking help.
        by Yagers
        My motherboard has recently gone out. Seems to be something on the VSB circuits, which I was already suspicious as I went through 5 PSU's in 5 years, most of which had damaged VSB circuits, but It stopped working a week ago, I thought it was the PSU again, but a new one didn't remedy the no start, I walked away with it hooked up and came back in and it was on and running all on its own, shut it down and it wouldn't turn on again, after about 5 button presses it turned on and worked fine until this sunday, It wouldnt start, so I tried swapping psu's, I then noticed a slight whine, and noticed the...
        02-14-2024, 02:51 PM
        Seeking GA-M57SLI-S4 Schematic And Boardview
        by AstutePauciloquent
        Hi everyone, can anyone help me to find the Gigabye GA-M57SLI-S4 motherboard Schematic And Boardview. I am attempting to diagnose an ALC883 Audio codec, I have replaced the Audio IC with a new one, however the problem was not solved. I believe that if i am able to get hold of the Schematic And Boardview it will shed some light on BITCLK 24Mhz, and SYNC 48kHz clock that are both missing from the Audio IC, after powering on. I think it might have something to do with the clock IC.
        Thank you in advance for your help.
        10-15-2023, 11:37 PM
      • newtest
        Seeking Biostar H110MG Pro D4 - IH11M-MHS Schematic And Boardview
        by newtest
        Hello, I want to learn about the main biostar H110MG Pro D4 - IH11M-MHS for long-term use, so I need its schematic and boardview, thank you for your time.
        * Translated by google so if my words are dry or misleading, please forgive me.
        10-23-2023, 03:00 AM
      • PacoGT
        HP ENVY x360 gidget 8L 203038-1, boardview and schematic need
        by PacoGT
        hello firends
        i search the schematic or boardview
        I have this motherboard, but I can't find the schematic or the boardview.
        The problem is that on the chip marked where 3V should be, there are 5 volts, which indicates that the two are connected.
        So the computer doesn't turn on, and the 3V disappears after a few seconds.
        The original problem was that when I turned off the computer, the fan stayed on and saw that it was bad since it was directly in the 5V area.
        The new problem arose after removing the bad chip.
        3V and 5V remained together,...
        08-19-2025, 08:25 PM
      • hosain0489
        Request for Schematic and Boardview for HP Omen 16-xf0006AX (AMD Ryzen 7 7840H Version)
        by hosain0489
        I’m looking for the schematic and boardview files specifically for the AMD version of the HP Omen 16 laptop, model xf0006AX, equipped with the Ryzen 7 7840H CPU.
        Most of the files I’ve found are for Intel CPU versions, and I need the exact files for this AMD Ryzen 7 7840H model to assist with repair and troubleshooting.
        If anyone has access to these files or can kindly share the boardview and schematic for this particular AMD version, I would really appreciate your support.
        Thank you very much in advance!
        07-15-2025, 11:20 AM
