HP EliteDesk 800 G2 Mini Bios Bin
  • hoaca388
    Badcaps
    • Jan 2022
    • 11787
    Re: HP EliteDesk 800 G2 Mini Bios Bin
    Originally posted by meomeo888
    Thank you so much!
    After Flashing your modded BIOS file by CH431, my HP MiniPC boot fine, but the MPM is still not Unlocked. Please advise!
    Unlock MPM
    • meomeo888
      • Oct 2023
      • 15
      Originally posted by hoaca388
      Unlock MPM
      After Flashing this Modded Bios file, my HP MiniPC is still not unlocked MPM again. Do I need set Jumper or something else?
      • komser
        • Nov 2023
        • 10
        • Deutschland
        Re: HP DMI Tool NBDmiFit
        This is HP EliteDesk 800 65W G2 Desktop Mini PC, like the serial number you posted, and the bios file you posted is not the complete file, you need a programmer to render the original bios file.
        https://www.badcaps.net/forum/showpo...40&postcount=2
        i have at my HP mini the problem with no video, no beep, (corrupted update) ... therefore i ordered the CH341a USB programmer, which should delivered within the next days.
        i read the guidelines only be prepared for the rescue operation.
        the BIOS chip has following label:
        MXIC MX / 25L12873F / M2I-10G / 8B368500 / L152804
        --> Macronix MX25L12873FM2I-10G, "2.7 to 3.6 volt for read, erase, and program operations"
        questions:
        1) read IC should create a file with 8.192 KB or 16.384 KB?
        1.1) because i see user uploads with the mentioned sizes. as i understand, neo-programmer do only "read" and shows the size on the left pane. this part confusing me.
        2) after get file [1] how i create the file for the write operation?
        2.1) with the official HP update file is N21_0261.bin within sp146663.exe
        3) no need for 1.8V adapter, right?
        thanks in advance
        • meomeo888
          • Oct 2023
          • 15
          questions:
          thanks in advance
          What's your Product serial number?
          1. The BIOS chip 25L12873F mean 128Mb => 16MB
          1.1 Full size BIOS DUMP file of your BIOS Chip is 16MB (16.384KB). The N21_0261.bin bios file update is only the BIOS region in the full BIOS dump file.
          2. You can use UEFItool and HxD to modify your BIOS dump file, then write using CH431
          3. No need 1.8V adapter.
          I hope these can help you!
          • komser
            • Nov 2023
            • 10
            • Deutschland
            SN i'll provide later with the BIOS file request (if i'm not able to create it for myself).
            the exact model name: HP EliteDesk 800 G2 DM 35W Business PC (DM = Desktop Mini)
            the thread/guide https://www.badcaps.net/forum/showthread.php?t=121948 doesn't explain the use of UEFItool/HxD.
            Do you have more details or a link that i read how to do the change.
            • hoaca388
              Badcaps
              • Jan 2022
              • 11787
              #26
              Again
              • meomeo888
                • Oct 2023
                • 15
                I asked about Product Serial number to know exactly the Product Name. Because my Mini PC is showing HP EliteDesk 800 G2 DM 65W, but I still able to flash the BIOS dump file of HP EliteDesk 800 G2 DM 35W (in the beginning of this thread) and it still work fine.
                I saw you said your BIOS update file is N21_0261.bin, the same my MiniPC, so I think you can edit your BIOS dump file by UEFItool and HxD, or using another Bios dump file of HP EliteDesk 800 G2 DM 35W in this thread.
                • meomeo888
                  • Oct 2023
                  • 15
                  Again
                  Thank you very much!
                  Yesterday I had used a paid service on tele to unlock MPM, and it work fine. My HP mini had been unlocked MPM.
                  • meomeo888
                    • Oct 2023
                    • 15
                    Again
                    This BIOS file work fine. Running smooth. Thank you so much!
                    • komser
                      • Nov 2023
                      • 10
                      • Deutschland
                      #30
                      Again
                      i performed the rescue operation. now, i see video and i can access BIOS.
                      but, system info shows no serial number and the UUID is only F. almost everything at this page is blank.
                      normal behaviour?
                      Code:
                      CRC32 = 0x31154C39
                      17:02:30
                      Erasing memory...
                      Success
                      Execution time: 00:00:41.430
                      17:03:33
                      Erasure control...
                      Success
                      Execution time: 00:02:39.167
                      17:06:44
                      Programming memory(verifying)... Main Memory
                      Success
                      Execution time: 00:05:53.220
                      17:12:54
                      Reading memory... Main Memory
                      Success
                      Execution time: 00:02:40.053
                      CRC32 = 0x31154C39
                      • komser
                        • Nov 2023
                        • 10
                        • Deutschland
                        #31
                        Re: HP EliteDesk 800 G2 Mini 35w Bios Bin
                        HP EliteDesk 800 35W G2 Desktop Mini PC
                        when i use this file (CRC32 = 0x88445B64) my faulty behaviour with no video is still exists.
                        • komser
                          • Nov 2023
                          • 10
                          • Deutschland
                          #32
                          maybe i have general understanding issue ... there is no generic bin file and every bin needs to be created/generated by the supporters. in others words, when i make an bin file request with my backup file, then i'll not have the mentioned issue with the blank SN?
                          • komser
                            • Nov 2023
                            • 10
                            • Deutschland
                            #33
                            two dead PCs; both same failure; no video/screen
                            attached zip file include 'read' from 'CH341 Black'
                            CZC6089T2G
                            P1G34EA#ABD
                            MD5: 98A4B63AA30CB1F6B30A7F4B48F0EF42
                            CRC32: 345231C6
                            CZC62374NN
                            X3J17EA#ABD
                            MD5: ED8A6589C9F7D2A7C8D0B89564E81320
                            CRC32: 918B89B9
                            with request/please to mod/edit the bin files, that i can write back via CH341.
                            • komser
                              • Nov 2023
                              • 10
                              • Deutschland
                              #34
                              Re: HP EliteDesk 800 G2 DM
                              i realized that the CZC62374NN has different chip typ with Winbound. at neo-programmer the ‘Currently selected: MX25L12873F [3.3V] 128 Mbits, 16 Mbytes’ was selected, which is correct for CZC6089T2G (Macronix). before i upload the file i check/opened it with UEFI tool. this means the read operation was successful and the file is valid?
                              • hoaca388
                                Badcaps
                                • Jan 2022
                                • 11787
                                #35
                                CZC6089T2G
                                P1G34EA#ABD
                                CRC32: 345231C6
                                CZC62374NN
                                X3J17EA#ABD
                                CRC32: 918B89B9
                                HP EliteDesk 800 G2
                                • komser
                                  • Nov 2023
                                  • 10
                                  • Deutschland
                                  #36
                                  Thanks!
                                  In short, one is working, the other one not!
                                  The file "HP EliteDesk 800 35W G2_CZC6089T2G.bin" is working fine.
                                  SN, FeatureByte, ... everything is there after apply.
                                  BIOS update working too, it's was already with the "N21_0261.bin", but only to check.
                                  update ME: with the Hirens Boot CD i was not able to perform the update (Windows PE). I"ll give a try after windows is installed.
                                  unfortunately, the other file "HP EliteDesk 800 35W G2_CZC62374NN.bin" was without success. the error is still there ... can you please check again?
                                  • komser
                                    • Nov 2023
                                    • 10
                                    • Deutschland
                                    #37
                                    The only difference between the PCs is the Chip.
                                    At the none working is the chip "Winbond, 25Q128FVSQ, 1610".
                                    I used the CH341a 1.18, AsProgrammer, NeoProgrammer and Colibri > no success.
                                    Only with bin from post #15 i have very high fan speed, "HP mini 800 G2 DUMP BIOS_clear DMI.bin", CRC32 = 0xC44F0563, but w/o video.
                                    • jonico2007
                                      • May 2022
                                      • 28
                                      • Philippines
                                      #38
                                      Can Someone help regarding this device freeze-8105
                                      HP EliteDesk 800 G2 Desktop Mini-35w
                                      Serial: 2UA6242MBC
                                      • hoaca388
                                        Badcaps
                                        • Jan 2022
                                        • 11787
                                        #39
                                        Serial: 2UA6242MBC
                                        HP EliteDesk 800 35W G2 Desktop Mini PC (ENERGY STAR)
                                        • jonico2007
                                          • May 2022
                                          • 28
                                          • Philippines
                                          #40
                                          thank you so much will try it.
