  • Forest79
    • Jul 2023
    • 5
    However, the chip (a Macronix MX25L25673GMI-08G) has a size of 32 MB, and the BIOS file from the Lenovo website (extracted with UEFITool) has a little more than 16 MB. Thus, the software my acquaintance used (SiberiaProg v1.45, with a CH341A Programmer) did not work. He sent me the file he could read from the chip, but I could not find strings in it that match with the BIOS file from the Lenovo website. I guess this file from the chip is simply garbage.
    If anyone having the knowledge how to do this reads this post: Could you please create the required 32 MB BIOS file for me?
    The serial number of the machine is S4JQ2779.
    Thanks a lot in advance!
    P.S.:
    Or, alternatively: Is there a guide describing how to edit the BIOS files?
    I guess I have to cut something from the beginning (and perhaps also from the end) of the original file, so it is exactly 16 MB (16777216 Bytes). But where do I cut? And then: Should I simply put the 16 MB content twice into a file with 32 MB (33554432 Bytes)? Or fill the 16 MB file with zeros, up to the needed size of 32 MB? And, finally: In some posts I saw that the serial number is required. Is it necessary to enter this number somewhere into the file?
  • volinakis
    • Jan 2021
    • 2869
    • N/A
    Re: Lenovo ThinkStation P520 BIOS file needed
    Originally posted by Forest79
    I got a Lenovo ThinkStation P520 ...
    Post your bios dump here. And read the rules.
    • Forest79
      • Jul 2023
      • 5
      thanks for the quick answer!
      I left the BIOS dump out because I thought it would be useless. But here it is:
      • hardware1
        • Sep 2021
        • 2945
        • N/A
        Here is your New BIOS, try it and let me know.
        It's better to use NeoProgrammer software with the CH341A.
        all donations are welcome,
        • Forest79
          • Jul 2023
          • 5
          thank you for your help!
          Unfortunately, it does not work:
          The attached monitor stays black (it does not power-up from power saving). An attached USB DVD drive with a Windows 10 install disc is being accessed periodically for less than a second (with a few seconds pause in between), but obviously the PC does not boot from the disc: Only the LED of the DVD drive lights up, there is no sound from the drive indicating that it is really reading the disc (this sound can only be heard for the first 4 or 5 times after switching on the PC).
          Another observation: If I switch NumLock off at the keyboard, it is switched on again when the PC accesses the USB DVD drive again.
          There was a beep, only once when I switched the PC on for the first time after flashing the chip (the CR-2032 battery is not installed). Since then, there is no beep anymore when I switch on the PC.
          All in all, the PC behaves quite the same as before I flashed the chip with NeoProgrammer.
          Hopefully, this might give you a hint for the cause of the problem.
          Again, thank you for your help!
          • hardware1
            • Sep 2021
            • 2945
            • N/A
            You're welcome.
            Did you select verify the chip after programming it and the process ends find?
            Is the Caps-Lock key responding when you are pressing it?
            • Forest79
              • Jul 2023
              • 5
              yes, I had the written data verified in NeoProgrammer, and it said "Success".
              When I press the Caps-Lock key, the corresponding LED at the keyboard lights up. However, the LED turns off as soon as the next access to the attached USB DVD drive happens (and the NumLock LED turns on again if I have also pressed NumLock).
              If the USB DVD drive is detached, the LEDs for NumLock and Caps-Lock work as usual (i. e. they just light up and turn off when the corresponding key is pressed).
              I saw that meanwhile there is a new BIOS Version (S03KT60A) at the Lenovo website. The readme file names as one of the two changes:
              Code:
              -Update J3/J9/JY BIOS flash tool.
              I wonder if the previous BIOS flashing routine had a flaw in it which might have caused the flashing failure with Windows Update.
              Now that your BIOS file is flashed onto the chip:
              Should I perhaps try the emergency flashing procedure again, this time with the new version 60? Or could this possibly just create confusion for possible further proceedings?
              (Before posting here, I have tried this emergency procedure with versions 58 and 59. The emergency flashing procedure consists of setting a jumper on the mainboard and booting the update CD from a drive attached internally via SATA cable. The update CD has to be burnt from the ISO from the Lenovo webiste.)
              Again, thank you very much!
              • hardware1
                • Sep 2021
                • 2945
                • N/A
                As far as I know, If the Caps-Lock/Num-Lock is respond when pressing it, that means it's not a BIOS issue. You can start looking for a Hardware problem, or wait for someone else might have another opinion.
                • omartancol
                  • Jul 2020
                  • 10
                  • Queretaro
                  hi, im also looking to fix a ThinkStation P520, mobo : Salween BD0331 REV 1.2, my client said it failed to start after a blackout (when you plug it, it auto start and power off after a couple of seconds, and do the same if you press power button) so i checked the "ATX" and the board looking for something wrong, after check in everything i went for the bios and found that the bios IC (MX25L25673GMI-08g) allow me to read it but no to write it, so my guess is that my client tryed a bios update and this was the real reason of the failure (clients tends to lie) so since i don't have the exact same IC and din't find it on my country (México) im using a ps4 fat ic (MX25L25635FMI-10G) while i w8 for the spare ic to arrive from china.
                  I Found a supposed good bios from same board model on vinafix so i edited it with the "INTEL ME/TXE injector" with the extracted region of my original bios and writted it to the ps4 Ic , now the board starts and stays on, the dissipator of the procesor heats up but i don't see any leds light up on keyboard and don't have image display (checked the video card on other pc wich is a CUADRO P4000 and it's ok) so any pointers will be highly appreciated.
                  • hoaca388
                    Badcaps
                    • Jan 2022
                    • 12237
                    Serial number ?
                    • omartancol
                      • Jul 2020
                      • 10
                      • Queretaro
                      Originally posted by hoaca388
                      Serial number ?
                      SN: MJ09N5FV
                      MAC: EA = 1CA0B8786197
                      • omartancol
                        • Jul 2020
                        • 10
                        • Queretaro
                        i fixed my pc with this bios if some one need it (P520 (1s)MT-M 30BF S3YC00)
                          LENOVO ThinkStation P520 ThinkStation P W-2235 Specification for Upgrade or Repair
                          This specification for the LENOVO ThinkStation P520 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the ThinkStation P520 boardview and ThinkStation P520 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                          09-12-2024, 02:15 PM
                          LENOVO ThinkStation P520 ThinkStation P W-2275 Specification for Upgrade or Repair
                          LENOVO ThinkStation P520 ThinkStation P W-2133 Specification for Upgrade or Repair
                          LENOVO ThinkStation P520 ThinkStation P W-2255 Specification for Upgrade or Repair
