HELP !!! Gigabyte Auros X470 Gaming Wifi 7 - Identifying IC
  • gurj1979
    • Dec 2014
    • 188
    Hi guys,
    I've got hold of a mangled board mentioned in the title. Board work OK but had missing Audio and DAC IC's, which I've ordered from AliExpress.
    BUT, on the underside of the board (under the DAC chip), there should be an IC, im guessing a BIOS.
    Can someone help me identifying this IC ? If it a BIOS for DAC, can someone provide me with the .BIN file for it as well ?
    Thanks in advance.
  • gurj1979
    • Dec 2014
    • 188
    Re: HELP !!! Gigabyte Auros X470 Gaming Wifi 7 - Identifying IC
    Typo - Aorus
    • gurj1979
      • Dec 2014
      • 188
      Anyone help please ?
        • 22159
        Post a picture of the area where the missing IC is
          • 22159
          You can get the bios from the support wesite,there are 2 different revisions,at the top left is the revision number you can select
          https://www.gigabyte.com/Motherboard...WIFI-rev-11#kf
          • gurj1979
            • Dec 2014
            • 188
            Hi, you've misread the BIOS part. I'm not sure if the missing IC is a BIOS or something else. The IC is on the other side of the board, directly under the DAC IC.
              • 22159
              Right,i`m with you now .Post pictures.I can`t find a schematic or boardview for the board,but there are some others available that might have the same IC layout
              • gurj1979
                • Dec 2014
                • 188
                Thanks. Not sure if the X570 version has the same DAC.
