Sapphire RX 5700 Pulse Missing 1.8V
  • Zsombi114
    • Apr 2022
    • 23
    • Romania
    Hi guys! I have a faulty RX 5700 Pulse which has no 1.8V. I want to repair it, because the gpu is 100% functional. Interestingly, I had the same problem a few months ago with this card. I worked a lot diagnosing and "repairing" the card (I replaced 2 caps and 2 resistors at the 1.8v line, but nothing changed). After a few weeks, I was measuring the voltages when I noticed that the gpu is hot. I plugged the card into my pc, and it worked fine. I wasnt able to believe its working. I used the card for 3 weeks and I decided to sell it. Unfortunetaly, when the buyer bought the card, the card was not working. He returned it to me, and it has the exact same problem.
    Voltages present : 12V, 5V, 3.3V
    Missing voltages : 1.8V, 0.9V, 0.75V, Vcore, Memory, Mem controller
    I measured the card again, and it doesnt have 1.8v pgood, so I decided to change that buck converter which is an AREK043 (maybe an MPS nb685agq, I couldnt identify it exactly). I replaced it with an AREF946 (Mps nb685a), still nothing. There is a resistor which has a 3.3V side and the other should be the pgood which is not present. If I inject 1.8v to this side (pgood side) of the resistor, tha card has 1.1V at soc, 1.1vcore, 1.35 memory, and others. Thats why I know that the pgood itself is my problem.
    Any idea what to do? The resistors at the 1.8V line seem to be good, I dont know how to restore this pgood.
    Thanks for you help!
  • ductranvinh
    • Dec 2021
    • 123
    • Republic of Vietnam
    Re: Sapphire RX 5700 Pulse Missing 1.8V
    Take a picture of board and post it. I can help u
    PC work for schemaltic:
    Mainboard: Gigabyte Z68XP-UD4
    CPU: I3-3240
    Ram: 16Gb
    Graphic Card: GTX 1050Ti zotac 4Gb Mini
    SSD: 120Gb
    HDD: 2Tb
    • Zsombi114
      • Apr 2022
      • 23
      • Romania
      I edited the thread with pictures.
      • ductranvinh
        • Dec 2021
        • 123
        The quality of pic is not good.
        CPU: I3-3240
        Ram: 16Gb
        SSD: 120Gb
        HDD: 2Tb
        • Zsombi114
          • Apr 2022
          • 23
          • Romania
          It is good, but the forum makes its quality worse...
          • ductranvinh
            • Dec 2021
            • 123
            Wait minute
            CPU: I3-3240
            Ram: 16Gb
            SSD: 120Gb
            HDD: 2Tb
            • Zsombi114
              • Apr 2022
              • 23
              • Romania
              Which part of the card do you wanna see?
              • ductranvinh
                • Dec 2021
                • 123
                https://imgur.com/a/dJXZFK0
                CPU: I3-3240
                Ram: 16Gb
                SSD: 120Gb
                HDD: 2Tb
                • Zsombi114
                  • Apr 2022
                  • 23
                  • Romania
                  This is what i have already replaced. It was an AREK043 and the replacement was AREF946 (i think they are the same). I couldnt get an exact replacement for AREK043. (0 information on the internet about this arek043)
                  • ductranvinh
                    • Dec 2021
                    • 123
                    maybe u need some dead board of them. Now in china ic is verry hard to find
                    CPU: I3-3240
                    Ram: 16Gb
                    SSD: 120Gb
                    HDD: 2Tb
                    • Zsombi114
                      • Apr 2022
                      • 23
                      • Romania
                      Thanks for your help, tomorrow i will try to put back the old chip, maybe there was a bad connection. If not, then i will have to find somewhere the exact same ic.
                      • ductranvinh
                        • Dec 2021
                        • 123
                        yep i think some signal pin is bad connect. u should check Capacitor of signal rail.
                        CPU: I3-3240
                        Ram: 16Gb
                        SSD: 120Gb
                        HDD: 2Tb
                        • piernov
                          • Jan 2016
                          • 4435
                          • France
                          • Zsombi114
                            • Apr 2022
                            • 23
                            • Romania
                            I found an arek 535 on a sapphire rx 5600 xt, and I soldered it onto this card, still nothing. I changed 2 resistors which were next to this chip (1 of them is connecting to pg the other is i think enable), nothing changed. I have no idea what to do with this card.
                            • ductranvinh
                              • Dec 2021
                              • 123
                              OK! Now u check 5v level. Because 5v level make a signal to en 1.8v ic
                              CPU: I3-3240
                              Ram: 16Gb
                              SSD: 120Gb
                              HDD: 2Tb
                              • Zsombi114
                                • Apr 2022
                                • 23
                                • Romania
                                5V is generated by an FFK530. It has 3.6V vcc and 3.95V enable.
                                • Zsombi114
                                  • Apr 2022
                                  • 23
                                  • Romania
                                  Thanks for your help guys! I wont work on this card anymore, I will sell it as a non working one. I wasted enough time.
                                  • UngibX
                                    • Dec 2020
                                    • Беларусь
                                    Возникла аналогичная проблема с Sapphire Pulse 5600XT. Точно так же не было 1.8В, отсутствовал сигнал EN2 на микросхеме NB685A, маркировка в моем случае "AREM983". Сигнал растет от сдвоенного транзистора Q1000, вообще их там три: Q1001,Q1000,Q1021 - находятся возле разъема дополнительного питания 8pin. В моем случае Q1021 был пробит, его замена вылечила проблему.
                                    I had a similar problem with the Sapphire Pulse 5600XT. In the same way, there was no 1.8V, there was no EN2 signal on the NB685A chip, the marking in my case is “AREM983”. The signal grows from the dual transistor Q1000, in general there are three of them: Q1001, Q1000, Q1021 - located near the 8pin additional power connector. In my case, Q1021 was broken, replacing it cured the problem.
