PNY RTX 2080 TI , No Post with 100% Fan Spin
  • mrsmith128
    • Feb 2022
    • 4
    • US
    I have a non working 2080 TI that I receive to try on repairing. It doesn't display anything and the fan goes to full speed. I have tried it as a secondary,, there is nothing on device manager on this card. I tried nvflash to see if it even detects the card to re-flash the BIOS in case it is corrupted BIOS. It doesn't appear to detect it either.
    Could a corrupted or damage vbios flash chip keep the could from even being detected?
    This to me appears to be either failed BIOS or GPU. I didn't find any shorts on the PCIE lanes.
    I have tested all voltage rails, everything appears to be present (PEX, 1.8, VCORE, VRAM, 12V and 5V)
    I took some resistance reading:
    1.8 Volt Rail: 36.2 Ohms (Way too low from what I research)
    PEX: 10 Ohms
    3.3 Volts on the PCIE slot: 18KOhms
    12 Volts at the PCIE slot: 6.1KOhms
    5 Volt Rail: 70KOhms and 12 Volt Rails: 17.5KOhms, 6KOhms and 5.1 KOhms
    Memory: 18 Ohms (SAMSUNG VRAM)
  • benwaterson
    • Aug 2008
    • 202
    • United Kingdom
    Re: PNY RTX 2080 TI , No Post with 100% Fan Spin
    Do you have access to an oscilloscope to check activity on pin 1 of the bios chip (CS line which should pull low when the core is communicating with the chip to read the bios)
    If not try this : https://www.youtube.com/watch?v=0hWn...ctronicsRepair
    • benwaterson
      • Aug 2008
      • 202
      • United Kingdom
      Originally posted by mrsmith128
      PEX: 10 Ohms
      Seems a bit low?
      • mrsmith128
        • Feb 2022
        • 4
        • US
        I do have a oscilloscope, I haven't tried that yet, the flash chip on this card is a is25wp080, pin 1 is marked as CE# which is chip enable, appears to be the same thing if i understand correctly.
        Keeping CE# in a high state deselects the device and switches it into its low power
        state. Data will not be accepted when CE# is high
        I will check that next. Thanks for you input on this issue.
        • mrsmith128
          • Feb 2022
          • 4
          • US
          Seems a bit low?
          The normal resistance for the PEX on a 2080ti is 5 to 10 Ohms when I looked it up, it is 1.8 volt rail that way too low.
          • Apraga
            • Oct 2022
            • Romania
            I have the same problem with a reference 2080ti but i have a shorted PEX, what might cause it ?
            • Prott
              • May 2022
              • 154
              • Czechia
              How many ohms do you get Apraga?
              My first hunch would be a dead core, but my first wish would be a shorted cap. Try injecting a low voltage (0.4 V for example) into the circuit while measuring where it goes (if any other rail is being powered from it). If it doesn't go anywhere else try to increase it (while keeping it under 1 V of course) and check what's heating up.
              If you are lucky it might be a shorted capacitor somewhere on the card.
              • DynaxSC
                Stubborn GIGABYTE B365M AORUS ELITE - main PCIe x16 GPU port working only in x8 width mode
                by DynaxSC
                I have this board, where I have exchanged the LGA1151 socket. During testing I discovered, that the large PCIEX16 slot won't by no force work in x16 mode, but keeps to work in x8 mode only.
                I tested this with GPU-Z, also with Render Test (but tried also Furmark and Heaven Benchmark - no effect).
                Tested on Core i5-9600K as well as on an Pentium G5420 and MSI NVIDIA GTX1070 and 2 other cards, including RTX3060Ti.
                Board architecture definitely allows x16 mode, as all 16 PCIe lanes are present between CPU and main GPU slot (nearest to CPU).
                05-04-2025, 12:08 PM
                Acer Spin Spin 511 R753TN Chromebook Specification for Upgrade or Repair
                This specification for the Acer Spin Spin 511 R753TN Chromebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Spin 511 R753TN boardview and Spin 511 R753TN schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or...
                09-07-2024, 02:20 AM
                Acer Spin Spin 3 SP313-51N-58JR Hybrid (2-in-1) 3 Specification for Upgrade or Repair
                This specification for the Acer Spin Spin 3 SP313-51N-58JR Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Spin 3 SP313-51N-58JR boardview and Spin 3 SP313-51N-58JR schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                09-06-2024, 09:30 PM
                Acer Spin Spin 3 SP313-51N-58LR Hybrid (2-in-1) 3 Specification for Upgrade or Repair
                This specification for the Acer Spin Spin 3 SP313-51N-58LR Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Spin 3 SP313-51N-58LR boardview and Spin 3 SP313-51N-58LR schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                Acer Spin Spin 3 SP314-54N Hybrid (2-in-1) 3 Specification for Upgrade or Repair
                This specification for the Acer Spin Spin 3 SP314-54N Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Spin 3 SP314-54N boardview and Spin 3 SP314-54N schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                09-06-2024, 07:50 PM
