P4SD - case LEN
    Re: P4SD - case LEN
    UPDATE: I did some manual resoldering of random areas, i found some surface elements that were a lil moved i guess because of the over heat i applied... after this it booted, then i inmmediately truned it off and back on and it showed the 5 flash error "memory error" then i tried again and got no boot, so I keep going from good POST, to froze POST, to memory error code, to nothing.... over and over again.
    Any idea is very welcome.
    Thanks.
    We don't have a great war in our generation, or a great depression, but we do, we have a great war of the spirit. We have a great revolution against the culture. The great depression is our lives. We have a spiritual depression.
      Re: P4SD - case LEN
      UPDATE: after several reheating times the board booted, and i began testing, mtest lasted about 30mins when i decided to put mprime on and it didnt last a split second on...
      weird fact about this board: i accidentally turned it on with some caps missing, three actually i found missiing, one a 1000/6.3 in between pci slot 1-2, the other is the 3300/6.3 cap besides the DIMM slots and the other was a SM on the back, under the CPU area...
      yeah the board booted several times without those. but it was an accident, when i realized those caps were off i inmediatly recapped em on, (specially because the 3300 religiously is a rubycon on everyboard, the board could be filled up with cheap caps, but that one) wel just the two on the top surface, the one on the back i didnt realize it was missing til this morning. i have already soldered it back, is there a chance this missing cap (the smd) was the reason why it shut up on mprime? (when i got to the mprime part the board was only missing the cap underneath the cpu area)
