this board powers up and the fans run for 4 to 10 seconds and then it powers down and then back up again and does this over and over. sometimes it will boot up to the bios or go into the OS before freezing . It power loops even with no memory installed. it has dual bio chips and i removed both and reprogrammed them but the issue remains
gigabyte z97x gaming 7 power cycling issue
Re: gigabyte z97x gaming 7 power cycling issue
My test rig did sometimes (while ago) power cycling too but because my ram slots where dirty and only worked with ram modules only a little inserted (Gigabyte z87-hd3), since I cleaned them with a toothbrush and IPA a pair of times it works with fully inserted ram modules and no more cycling.
I think its a ram module problem, if rams are ok I think it will be a ram socket problem, a cpu problem or ram electronic related problem in the motherboard.
Start cleaning ram sockets, then cpu socket inspection and then ram power supply in the motherboard, capacitors check.
Have luckComment
I had the same problem with my Gigabyte GA-B85M-D3H. After re installing bios.... the power cycling has gone. But One problem arise. Pc doesn't turn off when I press the shut down. Please someone tell me that how can I fix this shit.Comment
Thermal pad thickness for various laptop GPU / Graphics Cards
ASUS Dual RTX 2070 OC 8GB
ASUS ROG STRIX RTX 3080 OC
ASUS ROG STRIX RTX 3090
ASUS TUF Gaming RTX 3080 OC Edition
ASUS TUF GTX 1660 S-O6G GAMING
EVGA RTX 3060 Ti XC GAMING 8GB
EVGA RTX 3060 XC GAMING 12GB GDDR6
EVGA RTX 3080 FTW3 ULTRA GAMING
EVGA RTX 3080 TI FTW3 ULTRA GAMING
EVGA RTX 3090 XC3 ULTRA GAMING 24GB
Gainward RTX 2080 Phoenix GS Specs
Gainward RTX 3070 Phoenix 8GB
Gainward RTX 3080 Ti Phoenix
GIGABYTE AORUS RTX 3080 MASTER 10G
Channel: Schematics and Boardviews
02-09-2024, 08:08 AM -
by pubsinbgkHello Everyone,
Need Boardview file for Gigabyte GA-Z97X Gaming 5 motherboard. Kindly help.
Thanks in Advance.
Regards.-
06-27-2025, 12:14 AM -
Gigabyte GA-Z97X-GAMING 7 Motherboard Schematic...
10-17-2024, 09:28 AM -
by manusoftarI need a boardview file for a pc motherboard Gigabyte Z97x Gaming GT, I found it on a russian website but I'm afraid it may indeed be in russian and also a little afraid to use my credit card there...
- Loading...
