I'm looking for some help with an inexpensive used ASUS M5A78L-M LX Plus board I got recently. I'd like to max out the RAM at 16 GB, but one DIMM slot works and the other does not. With one 8 GB stick it only boots with the RAM in the outside slot, and if I put two 8 GB sticks in, only 8 GB total are seen by the BIOS and OS. I don't see any obvious physical damage to the board--no shorts or bad solder. Does anyone have any ideas on what to look for and what I might do to fix it? I suppose that the most likely thing is damaged contacts within the slot. I don't like the idea of unsoldering the old slot and putting in a new one, assuming that I can find such a thing, but I'm game if necessary.
Bad DIMM slot on old ASUS M5A78L-M LX Plus
Re: Bad DIMM slot on old ASUS M5A78L-M LX Plus
Hi
I'm afraid this motherboard does not support more than 8GB memory in total.
See manual.
Attached Files -
I'm aware of that statement, however it's false according to several forums and at least one Amazon review of the board--where several people have successfully used a total of 16 GB--and, in any case, the board won't POST with one 8 GB stick in the slot closer to the CPU (or even a 4 GB stick), but it will POST with one 8 GB stick in the slot further from the CPU. It'll POST with an 8 GB stick in each slot, but only see one stick. It seems to me that there's something wrong with the closer slot. A BIOS update didn't change anything either.Comment
If so, the only things which come to my mind are:
1. There might exist different revisions of the board
2. Some pin/pins in the CPU is/are bent, check them carefully, especially the half of the socket near the memories. Memory sockets rarely get broken.
3. Memory timings/supply voltage - maybe experimenting, if Bios allows, could help.
4. Use a DDR socket tester, compare both sockets, can be bought on Ali...s (China), are quite cheap.
5. One momory Dimm broken ? Probably not, but could theoretically be the case.
6. Try to setup memory step by step: 1. Bios reset 2. Boot with one dimm. 3. Power down, insert second dimm 4. Power on.
7. Not sure about AMD boards, but on Intel boards updating Management Engine (ME) of the chipset (an internal chipset control SW, kind of chipset firmware), if available on vendor site (usually done with BIOS update, sometimes there is dedicated sw for it). If for some reason, the ME is not updated (or even missing, eg. due to replacing the chipset), and there is no dedicated SW to do this, the only way is to downgrade the Bios to first version (using a HW programmer), and then go the full bios update path. If ME present/working, you should have in Windows Device Manager under System Devices a device called "Inter(R) Management Engine Interface #1"
8. Maybe there is some modded Bios, or a Bios modder for such kind of board Bios. Also a Bios from a similar but one generation higher board may work, but this is already an atomic solution - you need to have a HW Bios programmer, eg. CH341, and this can be risky, as well as it might require to add to the Bios the older CPU codes (also not sure how AMD hadles this). Win-Raid is a good forum to look for such solutions.Last edited by DynaxSC; 02-01-2022, 10:41 AM.Comment
DynaxSC, Thanks very much for the detailed reply!
1) Surely there are different revisions of the board, but I don't know about them or if it makes any difference.
2) If this were an LGA socket, this would be a great thing to check, and fairly easy. (I work on mechanical watches, so I have tools to see and manipulate very small objects.) But the M5A78L-M LX Plus supports AMD processors, not Intel ones, and the socket is an AM3+ PGA socket. I'll try spraying the socket with contact cleaner. The board did arrive looking a bit grimy, so there is a reasonable chance. My CPU is in good shape, but I should also check its pins carefully.
3) I didn't know about DDR3 socket testers. I'll see if I can get one on AlieExpress. I've never ordered from them before.
5) I have swapped DIMMs around, so both DIMMs work in the far socket and neither one in the near socket. In either permutation the board only sees 8 GB.
6) Already tried this, several times with different DIMMs. No joy.
7) There's no Intel Management Engine on this board, but I hear that AMD has something similar that I know nothing about.
8) Probably a different BIOS is not needed as I have a known-good 4 GB DIMM that also isn't seen when it's in the near socket. At first I thought the board was totally dead because it wouldn't POST with the 4 GB DIMM in the near socket and the far socket empty, but then I tried it in the far socket and it POST-ed and booted my OS. Fortunately, the 8-pin DIP BIOS is socketed(!) so it could be changed out if it ever became corrupt.
I'm running Slackware, not Windows. I don't know much about Windows except about installing it for other people. My first OS, about thirty years ago, was NeXTstep 3.2/Intel and then I migrated to Slackware Linux and, for a while, OS X on a laptop, since it is--or was--NeXTstep underneath.
I'll take another look at the board as soon as I get a chance.
TedComment
A minor update...
I took out the CPU and cleaned the socket well with quick-dry electronic cleaner and let it dry.
I inspected the pins of the CPU and all are straight and line up nicely. I booted with 16 GB of ECC RAM but the system still only saw 8 GB, so I took out the RAM and put in two known-good 2 GB sticks of non-ECC RAM. Now the system only sees 2 GB of RAM. No firmware update or special hardware version should be necessary to see this full amount and kind of RAM.
I'll have to test the socket with a tester, but that'll likely take weeks to get such a tester from AliExpress.
Meanwhile, I'll see if I can inspect the pins in the non-working DIMM socket. Maybe there's some foreign object blocking some pins. I have cleaned that DIMM socket twice with quick-dry electronic cleaner, so it seems to me that it's more likely a mechanical problem rather than dirt, or perhaps something else entirely.
Mostly I'm confused. I've never seen this particular problem before. I'm amazed that the system would ignore one whole stick of RAM and still POST. It seems like that should be a clue. It's as if the socket isn't there/connected at all. I would expect the system to be confused and not POST if only some of the pins of that DIMM were connected. I wonder if the DIMM is getting power.Comment
try this, put only one stick in that slot, work with the 2gb ones, so if you burn them will not be a big lost.
place it firmly, then push only one of the retainers a little so the stick tries to get off, if not working try again some more, then some more, my test rig worked like this until I cleaned it enough to work as spected.
Hope you understand meComment
How did you clean the DIMM socket? Did you need a small brush or something similar?Comment
Short answer
How did I fixed the slots? slowly cleaned them with IPA (isopropilic) and a toothbrush, 4 or 5 times.
Long story:
Well, ill tell you my story, that computer was a third PC I had and only used sometimes, so really didnt care a lot of it, then it gave me problems and left it in a corner for cleaning. After a year I took it off the case and cleaned it just with a compressor and a brush, it came back to life and I started using it as a Graphics cards test rig, but it had problems with rams slots and only worked when rams where only half pushed in. From time to time, because of gpus in and gpus out, the rams i suppose moves and i needed to reseat them and worked some other days. One day it stopped working at all, I thougt the motherboard went faulty, took everything out, cleaned it with a brush and all the slots softly with a teethbrush and isopropilic alcohol, the rams with a pen eraser and after that with alcohol too, started looking for the fault and nothing was shorted or burned, started testing the PSU, cleaned bios and didnt work nothing. looked again and tested again and it worked, really dont know why, but it worked, after that all the slots worked as supposed to do, rams fully inserted and no problems anymore.
Hoy did I fixed the motherboard? I dont know, its a mistery.
How did I fixed the slots? slowly cleaned them with IPA (isopropilic) and a toothbrush.
Maybe you can take a diagram of the cpu slot and test it in continuity mode with the rams contacs, looking for bad contacts and looking for the voltage supply of the rams in the slot. Will be slow, but maybe you find something and for sure you will learn a lot.
Hope you have luck.Comment
Long story:
Hope you have luck.Last edited by tj2; 02-06-2022, 10:57 AM.Comment
This specification for the ASUS ASUS E410MA-BV815TS 14.0 HD 1366x768 N4020 4GB 64GB with Office 365 1 Year Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the ASUS E410MA-BV815TS 14.0 HD 1366x768 N4020 4GB 64GB with Office 365 1 Year boardview and ASUS E410MA-BV815TS 14.0 HD 1366x768 N4020 4GB 64GB with Office 365 1 Year schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively...09-07-2024, 02:50 AM
This specification for the ASUS Chromebook ASUS Chromebook CX1100CNA-GJ0038 11" HD Celeron 4GB 64GB Chromebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the ASUS Chromebook CX1100CNA-GJ0038 11" HD Celeron 4GB 64GB boardview and ASUS Chromebook CX1100CNA-GJ0038 11" HD Celeron 4GB 64GB schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional...09-07-2024, 02:50 AM
This specification for the ASUS ASUS E510MA-EJ015TS 15.6" FHD Intel Celeron N4020 Processor 4GB 64G with M365 1 year Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the ASUS E510MA-EJ015TS 15.6" FHD Intel Celeron N4020 Processor 4GB 64G with M365 1 year boardview and ASUS E510MA-EJ015TS 15.6" FHD Intel Celeron N4020 Processor 4GB 64G with M365 1 year schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated...09-07-2024, 01:30 AM
This specification for the ASUS ASUS Chromebook CX1400CNA-BV0061 14" HD Intel Celeron N3350 Processor 4GB 64G Chromebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the ASUS Chromebook CX1400CNA-BV0061 14" HD Intel Celeron N3350 Processor 4GB 64G boardview and ASUS Chromebook CX1400CNA-BV0061 14" HD Intel Celeron N3350 Processor 4GB 64G schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional...09-06-2024, 11:40 PM
by ShadowAiHello, I have an issue with the motherboard. Specifically, it doesn't power on, more precisely, the POST initialization doesn't occur.
Let me start from the beginning, the motherboard suddenly stopped working one day. There are no beep signals from the speaker, and the debug LEDs are not lighting up. After inspecting it under a microscope and using thermal imaging, I didn't find anything that could be damaged.
After that, I began voltage measurements, in which I noticed the absence of VDDQ, VDDP, VTT, and VPP lines. Later, I checked if there is an EN state on these lines,... - Loading...
