RTX 3080 Ventus 10GB OC - powers on for 10 secs then off again
  • dicky96
    Sun Seeker
    • Mar 2017
    • 1825
    • Spain
    Hey guys has anyone come across this fault?
    MSI RTX 3080 Ventus 16GB OC
    The GPU powers up, all voltages look OK, Vcore 0.76V, Vmem 1.38V, PEX 0.95V
    Then after about 10 secs or so all voltages power back down again apart from 5V and 1.8V.
    It does not seem to be temperature related - if I power off and on immediately, it just does the same thing again
    I have a power sequence chart that says another voltage powers up after 1.8V and before PEX . It could be MSVDD but I am not totally sure
    Does anyone have a schematic or boardview for this one? I could start tracing from 1.8V_PG using datasheets but I thought I may save a bit of time if someone saw this problem before.
    Follow me on YouTube
    Learn Electronics Repair
  • DynaxSC
    • Apr 2021
    • 458
    • Poland
    Re: RTX 3080 Ventus 10GB OC - powers on for 10 secs then off again
    Hi, I would'nt be sure that it's not temperature related.
    The silicon in the chips internally can get warm much faster then the case.
    I'd give a try with a freezer spray on the vrm chips, just to test if it would prolong the power on time.
    The usual powersequence is 5v -> 1,8V, NVVDD (GPU core) -> PEX -> FBVDD (mem).
    So something with GPU, PEX and Mem voltage is wrong, probably FBVDD. Possibe could be also a problem with the 1,8V vrm, as it gives the EN signal to NVVDD. Try to look if and which EN signal is missing after the 10 sec's, or better trace it with a scope after powering on. Only way is probably to find the EN signal in VRM datasheet's, would'n expect there is a schematics available for such an new card.
    • dicky96
      Sun Seeker
      • Mar 2017
      • 1825
      • Spain
      According to the power sequence chart I have, there is another rail between 1.8V and PEX but I can't quite make out what it is (see attached)
      I have the board view for this GPU as well so that will help a lot- someone posted it on my discord. it's here if anyone else wants it
      • DynaxSC
        • Apr 2021
        • 458
        • Poland
        Impressive this part density on the card, there is a lot what can get broken.
        I'd guess the "in between signal" is MSVDD, from the boardview some important power supply to the GPU chip beside NVVDD, 6 phases and quite lot of pads used. Have no idea what it is, didn't had such card/GPU on the bench. But found some track from the driver/mosfets to 5V_PGOOD signal over a resistor, but didn't get into detail. Look for PS_MSVDD_DRVON signal, this probably triggers this supply, maybe somehow "anded" with 1V8.
        Good luck in this labirynth
          Thermal pad thickness for various laptop GPU / Graphics Cards
          ASUS Dual RTX 2070 OC 8GB
          ASUS ROG STRIX RTX 3080 OC
          ASUS ROG STRIX RTX 3090
          ASUS TUF Gaming RTX 3080 OC Edition
          ASUS TUF GTX 1660 S-O6G GAMING
          EVGA RTX 3060 Ti XC GAMING 8GB
          EVGA RTX 3060 XC GAMING 12GB GDDR6
          EVGA RTX 3080 FTW3 ULTRA GAMING
          EVGA RTX 3080 TI FTW3 ULTRA GAMING
          EVGA RTX 3090 XC3 ULTRA GAMING 24GB
          Gainward RTX 2080 Phoenix GS Specs
          Gainward RTX 3070 Phoenix 8GB
          Gainward RTX 3080 Ti Phoenix
          GIGABYTE AORUS RTX 3080 MASTER 10G
          02-09-2024, 08:08 AM
        • Chivo77
          DELL LATITUDE 5420, ST 20TFKN3, LA-K491P REV:2.0 (A01) powers on and die about 15 secs later, no video
          by Chivo77
          hello friends, I have a DELL LATITUDE 5420---MODEL P137G, ST 20TFKN3 LA-K491P REV:2.0 (A01) and its quite a challenge. It powers on with the battery disconnected, lasts on for about 15 secs, and then shuts off. It does the same with battery only (no adapter). With battery and adapter it sometimes starts after hitting the button several times. It displays nothing in every case. Since only the Boardview is available, I guided myself with schematics similar to this laptop (I'll add them down).Some measurements:
          1- After receiving power SIO_SLP_S0# goes high and never changes.
          2-every...
          07-03-2025, 09:20 AM
          NVIDIA GeForce RTX 3080 / RTX 3090 Schematic & Board View
          The GeForce RTX 3080 is an enthusiast-class graphics card by NVIDIA, launched on September 1st, 2020. Built on the 8 nm process, and based on the GA102 graphics processor, in its GA102-200-KD-A1 variant, the card supports DirectX 12 Ultimate. This ensures that all modern games will run on GeForce RTX 3080. Additionally, the DirectX 12 Ultimate capability guarantees support for hardware-raytracing, variable-rate shading and more, in upcoming video games. The GA102 graphics processor is a large chip with a die area of 628...
          10-02-2024, 08:52 AM
          DELL OptiPlex 3080 OptiPlex 3000 i3-10100T Specification for Upgrade or Repair
          This specification for the DELL OptiPlex 3080 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the OptiPlex 3080 boardview and OptiPlex 3080 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL...
          09-12-2024, 03:44 PM
          DELL OptiPlex 3080 OptiPlex 3000 i5-10500 Specification for Upgrade or Repair
