MS-6340 v1 - really weird problem
  • Rainbow
    • Aug 2005
    • 1375
    I have a MSI MS-6340 v1 board with a really weird problem. When powered up, it works fine. After a couple of minutes, it starts to do silly things - characters displayed at wrong place in text mode, crashing, hangs, then it sometimes hangs before POST. When powered down for some time, it cools down and works again for a while. Never seen this before. Checked CPU and chipset voltages and they're OK.
    I guess that this is not capacitor problem. The board has 6 big 3900uF/10V Yageo caps and although there are some smaller craps - one 2700uF/6.3V Tayeh, six 1000uF/6.3V Chsi - they all look fine.
  • PeteS in CA
    • Aug 2005
    • 3581
    • USA, Unsure of Planet
    Re: MS-6340 v1 - really weird problem
    Check for ripple on the voltages, too.
    PeteS in CA
    • Rainbow
      • Aug 2005
      • 1375
      I would if I had an oscilloscope
      • sulbert
        • Dec 2004
        • 59
        What buck controller does it have? I have a socket A MSI mATX (don't remember the exact model number and can't check it right now) that had SC1155 and was unstable and did all kinds on weird things.
        • Rainbow
          • Aug 2005
          • 1375
          SC1155CSW... Maybe adding some ceramic and tantalum caps will help. Looks like I really need an oscilloscope
          I've read somewhere that many of these boards have stability problems - maybe not only from bad caps but also from this.
          • sulbert
            • Dec 2004
            • 59
            Does the buck controller get hot? Mine got hot when the board crashed. I read in some kind of Russian message board that replacing the inductors would help... But there were no values given or something.
            • Rainbow
              • Aug 2005
              • 1375
              Don't remember if it gets hot but letting fan blow on the board make it run a bit better.
              Yes, the inductor looks really weird - never seen anything big like that on any other board (the caps are huge too).
              • the_tinkerer
                • Sep 2005
                All I did was replace the 2700uF-6.3v cap and now it runs fine
                • Rainbow
                  • Aug 2005
                  • 1375
                  I've already replaced that Tayeh (only one on the board) but it didn't help at all so I put it back.
                  • Rainbow
                    • Aug 2005
                    • 1375
                    Knowing that those SMD 10uF/16V caps go bad on MSI boards, I checked them on this one too. ALL of them were bad, of course - ESR at least 100 ohms, some completely open (>300). I replaced them all and also all 1000uF Chhsi caps, one 100uF and one Tayeh 2700uF. And guess what? No change!
                    • chaos-theory
                      Nitro rx580 very weird problem, VCORE and EN
                      by chaos-theory
                      Hello!
                      I have this very weird problem, I got this rx580 nitro saphire and the fans don't even spin but the saphire logo is lit.
                      All voltage rails are present except for VCORE at the coils, then I started checking NCP81022 and it has voltage but vdd pwrgd is missing, enable EN is missing it shows 2.5ohm, everything seems fine, i tried checking the back of the card, to see where the enable pin goes, i dont have a schematic so i started touching randomly until i measured a resistor on the back and the fans started spinning, now I was amazed like what is wrong here? So I thought it's a...
                      08-17-2024, 04:56 PM
                    • c.daniel
                      Lenovo V310-15IKB weird bios problem...
                      by c.daniel
                      Lenovo V310-15IKB Type 80T3 laptop, i7 7th cpu with dedicated Ati video
                      sn LR09493E
                      MB DAOLV6MB6F0 REV. F
                      The laptop was working fine, the only problem was that when I turned it on, the screen was hard to turn on, it would wait for about 30-40 seconds before an image appeared on the screen.
                      Initially, I updated from windows to Intel Management Engine 11.8 Firmware, restarted, everything was fine.
                      Then I updated the bios, also from windows, to the last vs, vs 46. It restarted, those lines with bios update progress appeared, restarted and that's it, since then...
                      08-22-2025, 05:39 AM
                    • sorrowfulfloyd
                      Samsung UE32J5373AS Weird LED Problem
                      by sorrowfulfloyd
                      Hi all, first time seeing a LED problem this weird so I wanted to discuss with y'all before handing back this TV to my costumer.
                      This TV came to my shop with no picture but sound present. So I thought ok this must be a LED problem and I shine a light with my phone's torch amd and yup I see the image. So I disassemble it and before changing the LEDs I check the motherboard voltages (this unit works with an external 16V DC brick) and I see 54 volts at the input pin of LED strip, considering this TV has 2 strips of 7 LEDs which at 3~ volts it must be equal to like 42 volts. I remove...
                      12-23-2022, 07:00 AM
                    • theone111
                      by theone111
                      3. Problem: TV shuts down
                      07-22-2024, 10:36 AM
                    • brockauly
                      Macbook M1 A2337 EMC 3598 weird battery charging problem
                      by brockauly
                      Hi guys,
                      If I unplugged the battery and the charger, then plug the battery then the charger, it charges without problem.
                      Then if I unplug the charger and plug it back, it won't charge anymore.
                      In the first case, main voltage is regulated at ~12.5V and charges the battery.
                      After unplugging the charger, main voltage drops to battery voltage at ~11.5V.
                      After replugging the charger, main voltage stays at ~11.5V and won't go up to ~12.5V again.
                      I found C520A (2.2ยต after current sensor from USB-C source) completely burnt and removed it properly. I cleaned...
                      02-05-2025, 10:51 AM
