Lenovo thinkcenter mini m93 hit by lightning
  • sputnikoff
    • Feb 2016
    • 203
    • canada
    I have seven units lenovo think center mini that were hit by lightning.They all have the network blown out.No visible damage just no lights on network when plugged in.I assume its a blown icp fuse somewhere on board.The issue could also be in that cage around network connector.Otherwise the pc operates just fine.
  • caspian
    • Oct 2015
    • 1589
    • Laptop
    Re: Lenovo thinkcenter mini m93 hit by lightning
    is data transferred through the network connector properly?
    it would help if you find the mainboard's schematics.
    • sputnikoff
      • Feb 2016
      • 203
      • canada
      no data transferred network side is dead.No indicator lamp when cable is plugged into port.
      • caspian
        • Oct 2015
        • 1589
        • Laptop
        it is really difficult to fix a mainboard without schematics. you can use a USB Lan adapter that provides a cheap network connection.
        • piernov
          • Jan 2016
          • 4435
          • France
          Usually the Ethernet controller IC goes bad, but it gets shorted. Can't see anything on the pictures but there should be an IC somewhere that's the Ethernet controller IC, a Realtek RTL8111, Intel, Broadcom or Atheros IC.
          The ESD protection diodes can go bad too. This can be verified by checking for a short to ground on all the pins of the Ethernet port. If some of the data lines are shorted, then most likely the ESD protection diode is dead, you have to find where it is on the board (you can inject voltage like 1 or 2V and check which component is heating).
          Lastly, the transformer and the filter cap inside the Ethernet port can be bad. Nothing you can do to reliably check that, but if replacing the Ehternet controller IC and ESD protection diodes didn't solve it, and the Ethernet controller IC is properly powered (voltage on its VCC pins, check datasheet if available) then you can try replacing the Ethernet port.
          The Ethernet port (with USB ports) is hard to take out and you could damage the board, so better try it as a last resort.
          • RobbieC
            • Sep 2013
            • 26
            Did you find a resolution to this issue as I have a very similar one. I have 2 units which appear to have died post lightening but are completely dead. I have no 5v from U10 (PK5048A) but have 10v going to it but cannot trace where it is switched from.
            Again this appears to be a standby voltage which feeds ethernet as standby allowed network leds flashing when powered down on the good board. Any schematics floating for this board ?
              • 20323
              Theres 2 motherboards, the IS8XT and LITE-ON JC184/JC186 .No schematics for the IS8XT. There is a schematic for the LITE-ON JC184/JC186 ,can`t find a free one though.
              • RobbieC
                • Sep 2013
                • 26
                Sod's law - IS8XT. Hopefully have more time and patience to work backwards. Do have access to working units though to assist and swap parts.
                • piernov
                  • Jan 2016
                  • 4435
                  • France
                  As I said the first suspect is the Ethernet controller, so check if it is shorted.
                  • RobbieC
                    • Sep 2013
                    • 26
                    Apologies to sputnikoff for thread jumping, but I think I have a similar issue not the same, however my knowledge of the system is limited and possibly incorrect.
                    My assumption is the 5v / 3v standby voltage is not there. Be that something failing on the supply line or something pulling the output / input to a fet down. There also seems a SF1 fuse in close vicinity to the ethernet controller which I (maybe incorrectly incorrectly) assume would blow in this case.
                    Out of interest - on the basis the unit dies from a surge due to lightening, what usually pops ? Am I ok to rule out caps and concentrate of a fet / short on a standby line. Certainly none of the elecrolytics look swollen.
                      LENOVO ThinkCentre M900 Mini Tower ThinkCentre M i5-6500 Specification for Upgrade or Repair
                      This specification for the LENOVO ThinkCentre M900 Mini Tower can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the ThinkCentre M900 Mini Tower boardview and ThinkCentre M900 Mini Tower schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                      09-12-2024, 01:58 PM
                      HP 260 G2 Desktop Mini PC i3-6100U Specification for Upgrade or Repair
                      This specification for the HP 260 G2 Desktop Mini PC can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the 260 G2 Desktop Mini PC boardview and 260 G2 Desktop Mini PC schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                      09-12-2024, 03:36 PM
                      HP Stolní počítač 260 G3 Mini i5-7200U Specification for Upgrade or Repair
                      This specification for the HP Stolní počítač 260 G3 Mini can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Stolní počítač 260 G3 Mini boardview and Stolní počítač 260 G3 Mini schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer...
                      09-12-2024, 02:20 PM
