Dell Optiplex 745 hangs on dual core
  • Giskard
    • Apr 2017
    • 5
    Hi guys!
    Im new to the caps world. I used to had issues in the old p4 times.
    I replaced an old p3 with a "new" optiplex (looking for a cheap media center and multipurpose linux machine).
    I cant install XP or any windows on it (hangs or bsod), so Im using Centos.
    The problem it hungs after 10 minutes if Im using both cores (core2duo). When I disable one, it works 80% uptime! When it crashes randomly. Specially when Im doing long checks (md5 for example)
    I was wondering if it is the CPU, the motherboard, or maybe the caps. When check time ago the were apparently ok, there werent any popup (as far as I know).
    What would be the problem?
    Thanks guys!
  • cpt.charlie
    • Sep 2013
    • 270
    • Spain
    Re: Dell Optiplex 745 hangs on dual core
    Sounds like a problem of bad caps in the VRM of the motherboard, check them.
    • Giskard
      • Apr 2017
      • 5
      Ok, what should I've looking for? Do you have a guide perhaps?
      I was looking some over the internet and found several ones, but I dont know if all of them apply.
      Thanks again!
      • Topcat
        The Boss Stooge
        • Oct 2003
        • 16958
        which version of the GX745 is it? All versions were prone to bad caps....but different versions use different caps.
        <--- Badcaps.net Founder
        Badcaps.net Services:
        Motherboard Repair Services
        http://folding.stanford.edu/
        Team : 49813
        Join in!!
        Team Stats
        • Giskard
          • Apr 2017
          • 5
          hmmm version? Its the mini tower, or do you refer to a code?
          • Topcat
            The Boss Stooge
            • Oct 2003
            • 16958
            That would be the SFF. the USFF would have an external power supply.
            Here's the kit:
            https://www.badcaps.net/store/produc...roducts_id=127
            Team : 49813
            Join in!!
            Team Stats
            • Giskard
              • Apr 2017
              • 5
              Ok great! its good to know it must be the caps. Ill check them tonight and send a photo of it.
              • Seagorman
                • Apr 2017
                • 70
                • Ireland
                Hi Giskard, have you tested our PC's Ram?, I have had major trouble with O\S install on a similar model Dell (Optiplex 755) Customer was reporting frequent rebooting, freezing & bluescreening, the bluescreening offered no info as to why the problem was occurring (not unusual for bluescreens, lol) he suspected the issue was related to a new video adapter he fitted and claimed the problem started happening after updating the drivers for said Adapter. He requested a data backup & a fresh install of Windows 7, data backup went fine but i ran into major issues with the install with the system hanging and also reporting files could not be found on the dvd, using new DVD's didnt have any effect. I decided to run Memtest86+ (http://www.memtest.org/) and within seconds of the scan starting it started reporting errors in one of the memory modules, replacement of the faulty module sorted the issue 100% and PC has been working like a dream since, i suspect the customer may have caused static damage to the ram when fitting the Video Adapter?, just a suggestion before you start poking around at the Motherboard.
                  DELL OptiPlex 3020 OptiPlex 3000 G1840 Specification for Upgrade or Repair
                  This specification for the DELL OptiPlex 3020 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the OptiPlex 3020 boardview and OptiPlex 3020 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL...
                  09-12-2024, 02:15 PM
                  DELL OptiPlex 3020 OptiPlex 3000 G1820 Specification for Upgrade or Repair
