Asus F5SL bad caps
  • kloky777
    • Mar 2016
    • Slovakia
    Asus F5SL bad caps
    Hello, on mainboard f5sl I have some problem: I measured the resistance value of these components, and they have a resistance of 78k, but look like capacitors. What are the components?
    master hoarder
    • May 2008
    • 12170
    Re: Asus F5SL bad caps
    They are multi-layer ceramic capacitors (MLCC), or often just called ceramic capacitors.
    The reason you could see that 78 kOhm resistance across them is because they are probably connected in parallel with other components on the motherboard. So you are actually reading the resistance of some other component on the motherboard.
