P4C800 deluxe memory problem
  • jlavi
    • May 2008
    I've over 4 years old P4c800 deluxe motherboard which has been
    running 24x7 last 4 years. It has 8 OST RLXes as VRM output filter
    and about 20 OST RLS here and there.
    The machine booted itself and failed POST by saying "bad bios
    checksum". I have 4 pieces of Kigston 1GB 400MHZ ECC DDR dimms
    and one of them seems to have failed. Normally I would just order
    a new DIMM and continue using the board without giving a second
    thought.
    However, now having reads warnings about OST caps, I consider
    recapping the board or having it recapped, even if it seems to
    work -- except that one memory DIMMS has now broken. I've had
    reasonably well ventilated Antec case and CPU temp has usually
    been 30 degress Celsius or slightly abobe and the same for hard
    drives. Still, the airflow aroud memory banks may not have been
    that good because of the cables and case structure blockking
    flow.
    Here a some pics of the caps. I don't see real bulding, but many caps
    have 4 hang-gliders like vents, which was discussed in
    the thread Asus TUSL2-C Ost recapping.
    OST RLXes VRM output
    Memory bank
    Another memory bank cap
    One more close to the memory bank
    Clock generator
    Caps near AGP slot
  • bgavin
    • Jan 2007
    • 1355
    Re: P4C800 deluxe memory problem
    Recap everything from 470uF and up. Use premium caps. Buy them here from the board owner (Topcat). He has everything you need to do a first-class job.
    If you have not recapped before, read the Stickies on soldering tips. Read and Understand. There is a wealth of knowledge here. If you are a product of Sacramento Public Schools, have somebody read to you. There are no Books on Tape for the stickies...
    • jlavi
      • May 2008
      Thanks for the reply. I have previous soldering experience but to
      save time I asked a quote from local service, but they did not
      bother to aswer. I am located in Finland, so Topcat's service is
      not available.
      I've tried cleaning holes with needle on a junk board with
      employers JBC pro soldering station. This works, but cleaning tin
      from the other size needs extra work.
      I then bought Weller desoldering iron with my employers expense.
      Already with a little testing I can say the device is
      fantastic. Removing cap lead and cleaning the hole in a single
      heating in 5 seconds, no tin residues and minimal stress on PCB.
      I am going to replace 1500 uF 6.4V OST RLXes with the same value
      Panasonic FMs and 1000 uF 6.3V OST RLSes with Panasonic FKs or
      FMs. I am still waiting for some Panasonic FMs to arrive.
      Before removing the caps I am testing with Memtest86 if it was
      just one bad memory DIMM. With broken dimm replaced and 4 dimms
      inserted the slot 0 (closest to CPU and NB) gives large number of
      recoverable ECC errors, about 3000 erros per hour and about 5-10
      non recoverable errors per hour. Switching dimms between bank 0
      and another bank made no effect, and errors repeated on slot 0,
      so sounds like a power problem in slot 0.
        Lenovo ThinkPad T16 + Extra 8GB memory Notebook Specification for Upgrade or Repair
        This specification for the Lenovo ThinkPad T16 + Extra 8GB memory Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the T16 + Extra 8GB memory boardview and T16 + Extra 8GB memory schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
        09-07-2024, 06:21 AM
      • kokodin
        memory mod for amd radeon r7 260x
        by kokodin
        Hello, for almost a year i been trying to make something that seems impossible, or my testing software is lying to me and it works only i can't see that.
        I been trying to mod a memory on radeon hd7790 or 260x from 2 to 4 gb, but it doesn't seems to be as simple as i first thought.
        In theory 2 workstation graphic cards using the same graphical processor have 4gb of memory firepro w4300 has 4 256x32b layout and W5100 has 8x 128x16b layout all use gddr5 memory and internals of the bioses seems to be very similar so i was trying to wing it , but so far it seems either tserver can't show...
        03-28-2024, 03:48 PM
      • Adr3nl
        Asus Strix 1070 - Bad memory bank?
        by Adr3nl
        I have a GTX 1070 Strix that has all the voltages, boots, but shows no image. The screen detects the input after some time, but it stays black. After running MATS i found out that only the Memory Bank c0 was giving errors. Since i don't have a hot air station or skills to change the memory myself i've asked a technician to change the memory bank.
        The result was exactly the same. Still no image and still errors on bank c0. As far as i know if the issue is with the memory controller usually the banks fail in pairs (c0 and c1). I'm also making available the mats reports before and after the...
        01-25-2022, 05:18 PM
        HP ProBook 450 G6 + USB-C Essential Power Bank Notebook 400 Specification for Upgrade or Repair
        This specification for the HP ProBook 450 G6 + USB-C Essential Power Bank Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 450 G6 + USB-C Essential Power Bank boardview and 450 G6 + USB-C Essential Power Bank schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we...
        09-06-2024, 11:05 AM
