ASUS MAXIMUM VIII HERO POWER ISSUE
  • mo000
    • Nov 2017
    • 278
    • algeria
    HI
    I HAVE NOTHERBOARD ASUS MAXIMUM VIII HERO powering on and off with cpu 8pin
    NO SHORT IN VRM
    cpu vcor vccsa vccio apears when motherboard powe up
    vccpll missing
    i check vddq for ddr4 i found it 1.1 instead off 1.2v ?
    i check every coil no short .
  • DynaxSC
    • Apr 2021
    • 464
    • Poland
    Check all 4 RAM voltages (0,6V, 1.2V, 2.5V and 3.3V which sometimes is also a second separate 2,5V), mostly 0,6V is missing due to buck controller failure. 1.1V is strange, should be 1.2V, higher if XMP is on. 0,6V is usually generated from 1.2V, so low 1.2V might be result of too high load (failure) from the 0,6V buck controller.
    Look not only for shorts, but also for buck controllers generating no voltage but having its ENABLE pin ON. Not always there are shorts, sometime just the controller is gone w/o short.
    • mo000
      • Nov 2017
      • 278
      • algeria
      you mean ddr vtt ?
      but what is the relation ? even ddr vtt is missing but the motherboard should power with cpu
      i think ram circuit works fine becase yesterday the motherboard suddenly powered with display and vddq becomes 1.2
      i think somthing related to cpu because when test motherboard without cpu 8pin vddq becomes 1.0 v
      • C0dR
        ASUS ROG Crosshair VIII Hero Schematics
        by C0dR
        I am currently trying to repair my own mainboard ASUS ROG Crosshair VIII Hero with a defective Power regulator chip. I have already soldered off the Chip (ASP1405 / IR35201) on the backside of the mainboard but during that process i knocked off some of the resistors around it and now my problem is I don't know what resistor goes where. Does anyone has the Schematics of that board or at least of the area around the chip (I have found images of it https://www.techpowerup.com/review/a...pwmcontrol.jpg) but there are no values written on the...
        12-13-2023, 08:43 AM
      • C0dR
        Asus Crosshair VIII Hero no VCPU, Error Code 00
        by C0dR
        I am currently working on my Crosshair VIII Hero mainboard on which a GPU short occured after which the mainboard would not turn on again. I suspected the VRM Controller (IR35201) and soldered it off. After that the board turned on again, obviously without providing voltage to CPU etc. I soldered a new IR35201 on it but it seems like the board still don't want to boot correctly. LEDs etc. turn on normally and after I press start button the power supply turns on fully and stays on, so I guess no shorts. Also nothing gets really hot. The error code shows code 00 and I measured VCPU and it was 0...
        09-22-2024, 11:15 AM
      • ITnet
        Schematic and BoardView for Asus ROG Crosshair VIII Hero Wi-Fi X570
        by ITnet
        Hi Guys!
        Greetings!
        Does anyone have the Schematics for a Asus ROG Crosshair VIII Hero Wi-Fi? I need the PDF with the specs also.
        Thank you for your help!
        12-03-2023, 12:04 AM
      • Maxpower3
        Boardview Asus MAXIMUS VIII HERO 60MB0M90-MB0A15
        by Maxpower3
        Hello
        Search Boardview Asus MAXIMUS VIII HERO ALPHA rev: 1.0
        ref 596518 -00328 - MB0P50 - A03 0205
        1st look and test:
        Lots of missing components under PCH + Socket damaged and tracks ...
        Lights up, starts but no reaction
        initialization remains at code Q 00
        following :
        after inspection and replacement resitor and repair track
        I replace the 0 ohm resistor under PCH and add another 0 ohm. (look pics)
        NOW, motherboard start
        but missing I still think 2 caps under PCH....
        01-07-2022, 07:39 PM
      • bajdik
        Intermittent Power Issue on Asus X553MA – CPU Voltage Drops ftom 0.89V to 0V
        by bajdik
        I have a problem with an Asus X553MA motherboard. Sometimes the system works fine, but other times the CPU voltage drops to 0V. In most cases, the laptop reboots after a few seconds due to the voltage drop.
        Occasionally, it shows the ASUS logo or boots into the BIOS. Sometimes it can stay in the BIOS for hours without issue.
        I checked the board with a thermal camera, but I couldn't find any overheating or leaking capacitors.
        Unfortunately, I don’t have access to the schematic.
        It seems to me that when I bend the board, something changes.
        Could this...
        08-13-2025, 07:26 AM
