Zotac GTX 1060 3GB
  • marcinas1983
    • May 2024
    • 5
    • Poland
    Zotac GTX 1060 3GB
    Hello! I have a similar problem as the author of the topic. I'm starting to learn how to repair electronics. I bought a damaged Zotac GTX 1060 3GB graphics card. I measured what the author of the topic measured and I attach a photo. The card core is slightly warm after power-on. Does anyone know what could have been damaged? Sorry for my English, I use Google Translator.​
  • Traptor
    • Nov 2021
    • 111
    • Magyarország
    It seems to you have a shortage on memory line. (0ohm, 0V)
    Remove the coil from the pcb and measure the resistance on the two pins.
    Depending on the measured values, you can search further
    • marcinas1983
      • May 2024
      • 5
      • Poland
      Thank you for your answer. In the near future I will try to desolder the coil and check where the short circuit is. I will report the results in this topic.​
      • marcinas1983
        • May 2024
        • 5
        • Poland
        I desoldered the vram coil and took a measurement. I ordered a laboratory power supply, I can perform a short-circuit test and check whether any of the VRAM chips are heating up.​
        • marcinas1983
          • May 2024
          • 5
          • Poland
          I desoldered all the vram banks and the short circuit is still there. GPU short circuit.​
          • Traptor
            • Nov 2021
            • 111
            • Magyarország
            If you desoldered all memory chip and the shortage is still, it means the gpu core is possibly dead.
            • haoran wang
              • May 2024
              • 11
              • China
              I think you should have 5V before 1.8v was occured. and power sequence should be 3V--12V--5V--1.8V--NVVDD(GPU)--PEXVDD(PCIE)--FBVDD(VRAM)
              • haoran wang
                • May 2024
                • 11
                • China
                By the way, you need boardview cad file and schematic to compare what you need to do next
                • texas1978
                  • Nov 2011
                  • 3
                  Hello there do you have the Boardview for this or do you know where I Can get this for the Zotac 1060 ?
                    • 20977
                    Post your request in one of the existing topics in the Bios & Schematic Requests! sub forum https://www.badcaps.net/search?q=Zot...oardview%22%7D
                    • DynaxSC
                      • Apr 2021
                      • 463
                      • Poland
                      There is a real chance that GPU still could be OK. The short can be on some MLCC cap. Only way to discover the shorted cap is high current injection, 20-30 Amps (with voltage limit to nominal memory supply voltage) + spraying the board with isopropyl alcohol, looking where it evaporates fast. Alternatively a thermal camera, but they are quite expensive. To do this it is recommended to take off the GPU, as the short can disappear - burn out - and then the GPU is at risk, if injected voltage will rise too high. Also taking off the GPU will give the final definite answer what is shorted, GPU or cap/board.
                      The generation of 20-30 Amps current is not easy, either you have a very powerful swithing and regulated lab power supply, or you need a "short killer" device, they are available on Aliexpress, but the quality / throughoutput stability is low, they can generate such high current only 10-15 seconds, then shut off due to overtemperature, good for mobile phones, less for GPU cards. You might also run two/three 10 Amps power supplys in parallel.
                      BTW if the GPU is really shorted for good, it might not be possible to warm it up so you can feel or even measure this, as the resistance goes down to almost total zero, and there is no resistance, on which some heat can be generated even with 20-30 Amps. However this is more likely on NVVDD (VCORE).
                      Sometimes you can also discover a shorted MLCC cap with a magnifier glass, it may have some visible difference from a healthy cap, eg. a very thin dark line, or some crack.
                      It seldom also happens that the board itself gets a short somewhere between tracks/layers, this is very difficult to trace/repair.
                        Gigabyte AERO 14W-1060-BK7 Notebook Specification for Upgrade or Repair
                        This specification for the Gigabyte AERO 14W-1060-BK7 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 14W-1060-BK7 boardview and 14W-1060-BK7 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                        09-06-2024, 05:46 AM
                      • texas1978
                        Zotac Geoforce GTX 1060 AMP! Edition 6GB schematic or boardview
                        by texas1978
                        Hello there everyone,
                        I have been trying to repair these 2 different cards that are both 1060 same design by Zotac. I was wondering if anyone on the forum has a schematic or board view for this model. Both cards power on but no post and GPU fan turns off right away. Any help would be great, trying to get one of these to revive for my kids computer to work with Fortnite.
                        Thanks,
                        Jeremy
                        01-10-2025, 06:21 PM
                        Gigabyte Sabre 17-1060-803 Notebook Specification for Upgrade or Repair
                        This specification for the Gigabyte Sabre 17-1060-803 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 17-1060-803 boardview and 17-1060-803 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                        09-06-2024, 11:44 AM
                        Gigabyte Sabre 15-1060-803 Notebook Specification for Upgrade or Repair
                        This specification for the Gigabyte Sabre 15-1060-803 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 15-1060-803 boardview and 15-1060-803 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                        Gigabyte AERO 15-1060-BK81 Notebook Specification for Upgrade or Repair
                        This specification for the Gigabyte AERO 15-1060-BK81 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 15-1060-BK81 boardview and 15-1060-BK81 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                        09-06-2024, 06:42 AM
