HP 800 G4 DM Mini. Machine not in commited state!
  • Andreasbest
    • Aug 2014
    • 1196
    • Hellas ( Greece )
    Hello!
    Today i have a challenge, i bought 6x HP 800 G4 DM Mini from USA, the motherboards are blank and MPM state meaning no feature byte, no serial number, no system board CT number etc.
    I talked with a HP insider and informed me that i can set the same parameters as another G4 BUT "it will not lock MPM and after 250 boots you will not be able to boot"
    He talks about a HP tool that is not public (yet) that is required in order to "lock" this particular mode and make the pc fully usable for unlimited boots, he can't do it due to legal reasons and i understand him completely.
    So what do you suggest?
    Flash the entire BIOS chip from another G4 and see what happens? Enter manually the data from another G4? Or this tool is indeed available and i'm not aware of it?
    Thank you in advance!
  • Andreasbest
    • Aug 2014
    • 1196
    • Hellas ( Greece )
    In other words all i need is a way to lock MPM.
    • reformatt
      • Feb 2020
      • 1478
      Likely been reprogrammed with a vanilla BIOS. The HP BIOS Configuration utility should work on it I think as I have used it on previous EliteDesk generations such as a 800 G2. You just need to set the MPM mode to lock once you have set all of the board parameters with it.
      The motherboard will have stickers on it with most of the missing info etc. To make it easier, I dump out the contents via the utility to a txt file, edit manually, reimport, then lock MPM. You won't have a Windows key though so you'll need to source that another way.
      BIOSConfigUtility64.exe /GetConfig:"BiosConfig.txt"
      Edit in your info into the file then reimport.
      BIOSConfigUtility64.exe /SetConfig:"BiosConfig.txt"
      Lock it with
      ​​​​​​​BIOSConfigUtility64.exe /setvalue:"Manufacturing Programming Mode","Lock"
      • Andreasbest
        • Aug 2014
        • 1196
        • Hellas ( Greece )
        Ok, i'll try.
        • Andreasbest
          • Aug 2014
          • 1196
          • Hellas ( Greece )
          All good. Tried it and worked like a charm.
          I only changed the model from 800 G4 35W that was the dump config.txt to 800 G4 65W
          Also changed to System Board ID, i kept the ID from 65W that was the blank.
          Also noticed the Cover Sensor setting not works as DISABLED, while SetConfig get error so i change it to DISABLE and worked great too.
          Now i kept one with blank bios to upload it here, it's nearly impossible to found blank bios with MPM unlocked these days.
          Thank you for the great info!!
            HP 260 G2 Desktop Mini PC i3-6100U Specification for Upgrade or Repair
            This specification for the HP 260 G2 Desktop Mini PC can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the 260 G2 Desktop Mini PC boardview and 260 G2 Desktop Mini PC schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
            09-12-2024, 03:36 PM
            HP Stolní počítač 260 G3 Mini i5-7200U Specification for Upgrade or Repair
            This specification for the HP Stolní počítač 260 G3 Mini can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Stolní počítač 260 G3 Mini boardview and Stolní počítač 260 G3 Mini schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer...
            09-12-2024, 02:20 PM
            HP 260 G2 Desktop Mini PC i5-6200U Specification for Upgrade or Repair
            09-12-2024, 02:15 PM
            HP ProDesk ProDesk 600 G2 Desktop Mini PC ProDesk 600 i5-6500T Specification for Upgrade or Repair
            This specification for the HP ProDesk ProDesk 600 G2 Desktop Mini PC can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the ProDesk ProDesk 600 G2 Desktop Mini PC boardview and ProDesk ProDesk 600 G2 Desktop Mini PC schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer...
            09-12-2024, 03:44 PM
