RX 7900 XTX ,Help me identify this usb c /thunderbolt 3 part number
  • Ikols2
    • Jan 2024
    • 3
    • Romania
    This is a mac pro gpu RX 7900 XTX
    Thanks!
  • G-Sting
    iPad Pro A1876 SHORT Part Identify Help Needed
    by G-Sting
    So My iPad was not charging and booting up . i went to a local technician and he checked with thermal and this Part marked in 1st Photo is Short.
    So then i went on to boardview and downloaded the schematics and identified this part in 2nd Photo. Now i am confused what exactly is the part called ? where should i get this from ?
    i contacted my technician and he sent me his BoardVIew screenshot in 3rd Photo. In his Boardview the part is called X2826.... Something
    SO My main concern is what part should i order what should i search the name for ?
    on Ipad...
    05-15-2025, 09:30 AM
  • esinior
    Smd code to part number
    by esinior
    Hi i have a smd part with probably mark "QO 11" or "Q0(zero) 11" on it, and its package is SOT89, i doubt its KTB1260 PNP transistor, but in measuring with diode mode of multimeter it shows number 1.4 between emitter and collector pins and its not open circuit, and .59 from collector to base and .8 from emitter to base , and these numbers doesn't match a pnp transistor, i couldn't find any part number and datasheet for it, does anybody have information for that part number?
    I've attached pics of this part
    Thanks...
    08-20-2024, 02:50 AM
  • Yanleb
    Panasonic part number in service manuals
    by Yanleb
    In the Panasonic service manuals, both in the board schematics and in the part listing, the part numbers that are given are Panasonic part numbers instead of the actual part numbers.
    This is especially annoying for small SMD components like diodes and transistors when you only have 1-3 digits printed on the component body.
    For an example, look at the attached PDF.
    Do you have a way to cross reference the Panasonic part number with the actual part number?
    Thanks....
    07-03-2023, 08:16 PM
  • FreakyMex
    Trouble to identify part (Lunii screen) for replacement
    by FreakyMex
    Hello guys. I'm a complete noob in electronics. I'd like to repair my child Lunii's (a "story box"), basically an audio player that allows the childs to choose between several options the places, characters, objects of the story, and then play a story according to the choice of the child. There is a screen that display the selected option before each choice. The Lunii fell and the screen is now broken.
    I'd like to repair it (probably just have to change the part, because the lunii still works perfectly fine) but I can't manage to identify the part/order it online. Do you have any...
    02-17-2025, 01:16 AM
  • Mdink
    Schematic diagram for clevo w65jo and board part-number 6-71-w65j0-d01
    by Mdink
    Hello, I need help me with schematic diagram for clevo w65j0 and part number 6-71-w65j0-d01.
    07-10-2025, 11:35 AM
