Dell XPS 600 SLI Nvidia Chipset power issue
  • SeanH
    • Feb 2007
    Morning everyone;
    I have 2 x dell XPS600 SLI motherboards, neither will POST. The diagnostic lights on the case indicate an 'internal power problem'. The power button is lit as solid amber together with the No4 diagnostic.
    I came accross this site by chance when looking for a place to diagnose / repair the motherboards and so my interest has now been peaked!!
    I do not in any way shape or form have any experience of repairing motherboards, or know where to start............so I've been searching through your forums.
    I am a network manager / system admin by trade an have plenty of experience in diagnosis problems to a system component level, not to a motherboard component level!!
    After reading the reference about looking for damaged caps, I checked the boards and there is no 'obvious' signs of bulging or leaking with the vast majority being made by Rubycon.
    So it could be the VRM. Before condeming them completely, given there appears not to be any visual signs of damaged caps is there another way of testing them in situ, ie measure resistence, voltage tests?
    many thanks
  • willawake
    Super Modulator
    • Nov 2003
    • 8457
    • Greece
    Re: Dell XPS 600 SLI Nvidia Chipset power issue
    are you testing the board with the correct dell psu?
    that 10pin 12v is pretty strange....http://support.dell.com/support/edoc....htm#wp1052309
    • lightingguy32
      • Feb 2008
      • 14
      It could be bad CPU VRM caps, I have an XPS600 and currently it is still running, but 2 capacitors (aluminum electrolytic) that are close to a DIMM slot have burst. All of the caps that I see that are near the CPU socket are solid polymers (nichicons possibly). My powersupply seems to be ok though. Any thoughts as to weather I need to replace all caps on the board or just those that are aluminum electrolytic?
      • piernov
        NVidia bumpgate
        by piernov
        Just archiving everything related to bumpgate since most stuff has disappeared from Google. Maybe people will finally take the time to read some of it and stop shouting "reflow gpu" at every occasion but rather try to understand what the real issue is…
        Interesting parts about the failure analysis are "Why Nvidia's chips are defective" and "Why Nvidia's duff chips are due to shoddy engineering"
        May complete this post at a later date with more details.
        Basically issue is a combination of thermal dissipation of the chip with hotspot,...
        03-27-2021, 10:34 AM
      • SuperJames
        Dell G3 17 3779 Weird power cycling and shutdown/restart issue
        by SuperJames
        This one's a weird one, and still unsolved despite it having gone back to Dell once.
        Specs
        i7-8750H, GTX 1060 Max Q, 500GB SSD & Seagate 7mm 1TB HDD. 17.3 IPS screen. This has the fingerprint reader in the power button.
        Backstory
        I bought this from eBay, from a wallpapering shop. £650 in 2020 which was a good price considering it's a gaming laptop. Physically it's in perfect shape, apart from the hinge mounts on the palmrest failing in the time I've had it (I have a new palmrest for it). The usual thin plastic crap modern build quality!...
        10-23-2023, 04:09 PM
      • Bowline
        by Bowline
        06-11-2025, 10:13 AM
      • Ven
        Dell Latitude 3510 Overheating & Fan Control Issue – Need Help
        by Ven
        Dell Latitude 3510 (Intel Core i7-10510U) CPU Overheating
        Issue Description:
        1. CPU Overheating to 100°C
          • When I start the laptop from a cold state, it takes about a minute to reach temps around 80-90-100°C, and CPU thermal throttling triggers.​
          • When the CPU fan is running at full speed (by disconnecting PWM and TACH cables), CPU temperature stays around 50-60°C.
          • However, when the fan is connected normally to the motherboard, it does not kick in at high temperatures.
          • I also noticed a few times that the fan kicked in for a very short time, but it does not stay on consistently.
          • Thermal
        02-12-2025, 03:57 PM
      • tech_guru
        Asus ROG Zephyrus G14 GA401IU-HE103T GPU Nvidia Issue
        by tech_guru
        Hello all,
        I am having an issue with this laptop, on which I repaired the motherboard on other power issues (PMIC, mosfets etc) and it came back to life, but I am having problem with the GPU NVIDIA GTX 1660. It gets error 43 in device manager with exclamation mark and does not work. When I install official asus driver or official nvidia latest, the error goes away until you reboot the laptop, where the error comes back again.
        GPU-Z software does not show many information and vbios info is missing (photo attached).
        Because the customer sent the laptop to 2 other labs trying...
        01-18-2025, 05:45 AM
