Ms-6570 K7n2g
  • bgavin
    • Jan 2007
    • 1355
    Ms-6570 K7n2g
    The board died.
    This is a real pity, considering it is 100% populated with Rubycon MBZ, and Chemicon KZE, KZG caps. There are no junkers on this board anywhere. It has a nice nForce2 MCP chipset and 8x AGP.
    I can't spot anything fried, and no smoked land patterns. It won't power up with a known-good PSU and CPU.
  • pentium
    • Mar 2006
    • 2778
    Re: Ms-6570 K7n2g
    Pictures would be really nice.
    Are you positive everything is socketed right?
    Find Nedry!
    Check the Vending machines!!
    • bgavin
      • Jan 2007
      • 1355
      Re: Ms-6570 K7n2g
      The board is pristine.
      Using a known-good PSU, it won't even bump the fan when I jumper the momentary Berg strip contacts. I checked the manual, and am indeed using the correct pin pair.
      CPU inserted, or absent, memory inserted or absent. Fans don't even twitch. The poor thing is 100% DOA. Examination with a magnifying glass does not show me any apparent smoked land patterns or components. There is no smell I can detect.
      • danten
        • May 2006
        • 5
        Re: Ms-6570 K7n2g
        Stupid possibility: bad BIOS? Or a corrupted data in FlashROM.
        The IC FlashROM can die or a range of data get corrupted without a explanation, it is rare but possible.
        It is little hard to test it without proper hardware ( IC eprom-flash programmer like WILLEM with hub-lpc adapter to 3.3V flash I suppose needed ). Or with another same working motherboard to test if it is ok or not.
        Athlon XP-M 2400+/1.8GHz
        MSI K7T266 Pro2-RU c37mod BIOS 3.7
        512MB Kingston
        Matrox Millennium G450 Dual Head 32MB
        PSU Seventeam ST-420BKV
        • davmax
          • Dec 2005
          • 899
          Re: Ms-6570 K7n2g
          You said the board died. How long did it last??? Did it ever operate? I notice you now say DOA. Please clarify.
          160Gb WD SATAII Server grade
          Nvidia 8500GT 256Mb
          Samsung 18x DVD writer
          33 way card reader
          Windows XP Pro SP3
          17" Benq FP737s LCD monitor
          • bgavin
            • Jan 2007
            • 1355
            Re: Ms-6570 K7n2g
            The board ran for several years in a client's machine. The PSU is one of those hinky non-standard types: irregular shaped frame, non-standard mounting, and a fan that protrudes out the rear. Avance Technologies is the PSU manufacturer.
            I've been through a few PSUs in both this machine and others that belong to the same client. Mostly replacing failed PSU with those cannibalized from similar (retired) machines.
            It just dropped dead one day. Swapped in (yet another) PSU, and it stayed dead. Put in on the bench with a known good PSU, etc, etc, and it remains dead. Drained CMOS, replaced battery, still dead.
            Normally I avoid board repairs, but I am now learning to recap good boards and power supplies. I hate to toss out a good 462 board, as that leaves me with a pile of good 462 processors. Especially considering this board is 100% Rubycon and Chimican capped.
            • bgavin
              • Jan 2007
              • 1355
              Re: Ms-6570 K7n2g
              Jumpering ATX-14 to COM starts the PSU and fans.
              I attempted to trace back from ATX-14 to the Berg strip connector, but it gets lost very quickly.
              I don't have any idea of what the startup circuit looks like, and don't have any schematic. I can't spot any smoked land patterns.
              • gdement
                • Jan 2007
                • 690
                Re: Ms-6570 K7n2g
                Have you tried looking for any shorted mosfets?
                • bgavin
                  • Jan 2007
                  • 1355
                  Re: Ms-6570 K7n2g
                  I'm not that sharp (yet).
                  The southbridge nForce chip started heating up to red hot after I forced the board to power up.
                  Pity. Nice board, but shot. I found another one on eBay with a 30 day warranty. From the photo, it is laid out the same as this board, and will probably be all good caps like the dead one.
                  • pentium
                    • Mar 2006
                    • 2778
                    Re: Ms-6570 K7n2g
                    If it was alive before that it most certainly is crisped now.
                    Find Nedry!
                    • tazwegion
                      • Jun 2006
                      • 444
                      Re: Ms-6570 K7n2g
                      Scrap the old board for it's capacitors, jumpers, DDR retainers & anything else you can salvage
                      Viva LA Retro!
                      • bgavin
                        • Jan 2007
                        • 1355
                        Re: Ms-6570 K7n2g
                        I found an eBay replacement with 30 day warranty. I'm pretty sure all the K7N2G are populated with similar premium caps.
                        • Rainbow
                          • Aug 2005
                          • 1375
                          Re: Ms-6570 K7n2g
                          What PSU was used when it died?
                          • bgavin
                            • Jan 2007
                            • 1355
                            Re: Ms-6570 K7n2g
                            Avance Technologies ATX12V-250MNH, crappy little micro ATX supply. I opened it up to find the usual Fuhkyyu bulgers and leakers.
                            My client inherited a number of these systems when they bought out this business. Most of the PSU have died, and in this case one board went with them.
                            I'm getting a replacement board from eBay, and will use a standard case and recapped Sparkle when I redo this system for the client. I figure the HAL should work (same chipset), and his existing Windows configuration should boot right up.
