Intel DG45FC Mini ITX Help!!!
  • bushido-21
    • Mar 2012
    • Japan
    hi i'm new here just wana help if any one here know how to fix Intel DG45FC Mini ITX i dont know if the bios causing the problem i try any bios recovery but didnt work no video output no usb function...plz help thanks
    PS:i try bios recovery using usb method
    and if this thread is a wrong section plz move it into right section thanks
  • Uranium-235
    Comrade Glimmer
    • Aug 2007
    • 5042
    • US
    Re: Intel DG45FC Mini ITX Help!!!
    no its in the right section cause there is no 'intel' section
    hm, so you get no video? have you tried a separate video card?
    • bushido-21
      • Mar 2012
      • Japan
      no bcoz its has not equipt pci e x16 its only pci e x1 connector i try to connect to hdmi and dvi but its not working i also try the bios recovery method using usb but still not working thanks for the reply
      • Uranium-235
        Comrade Glimmer
        • Aug 2007
        • 5042
        • US
        yeah I see that now, and its not even an open ended pcie slot
        ok let me ask you...does this board already have a hard drive with an operating system installed? If so, can you see the hard drive activity light go off as if its loading its operating system? if so, only the video output components might be bad, but the rest of the board is good. they DO make x1 pcie video cards
        • bushido-21
          • Mar 2012
          • Japan
          hi thanks for reply
          no doest not have hdd or OS installed its just the mobo with core 2 duo and pulsar umax ram ddr2 800mhz 2gb single module this is the story i got this mobo from auction the seller told me that this mobo has a problem he use it a half a year all of a sudden this mobo was not work any more...
          this mobo got my attention to try to fix by my self i try so many time to fix this like recovery the bios but no luck and just one more thing correct me if i'm wrong if the mobo was a corrupted bios it means the usb port ddnt work? or if dont have any problem with the bios it means there was other problem like capacitor resistor or other component..sorry i really dont have any knowledge technically on that component. i hope you can help me thanks
