Motherboards with Bad Capacitors - READ BEFORE POSTING!
  • Topcat
    The Boss Stooge
    • Oct 2003
    • 16958
    Ok, the motherboard base with bad caps is getting huge! So I created this area to keep them all in one place. If you have a motherboard with bad capacitors, please post the make and model here. Also, please tell us who manufactured the faulty caps, their values, and how many are on the board. With this info, it will help others in diagnosing their faulty boards.
    Also, feel free to post a picture. If you don't have access to a web server, feel free to email me the picture and I'll add it to your posting.
    Just to save postings and time, please look through the posts and make sure that your board isn't already mentioned.
    <--- Badcaps.net Founder
    Badcaps.net Services:
    Motherboard Repair Services
    http://folding.stanford.edu/
    Team : 49813
    Join in!!
    Team Stats
  • qwerty99
    Xbox 1.6 Motherboards and Polymer Capacitors
    by qwerty99
    Hello!
    I need to change the capacitors on my three original Xboxes.
    Two of them are 1.6B revisions and have Hynix RAM, and the other one is a 1.6 with Samsung RAM.
    The 1.6 has the infamous Nichicon HM capacitors around the CPU, which have all bulged and started to leak. This Xbox no longer powers on.
    The 1.6B revisions have Rubycon MBZ capacitors that all look fine, but I’ll change them in due course. Both of these work fine.
    I’ve seen some excellent threads on the forum about replacing/upgrading capacitors, but I can’t...
    06-26-2022, 12:53 AM
  • Spudgun
    Why doesn't current just bypass faulty capacitors.
    by Spudgun
    Hello esteemed members. I appreciate that my question will strike some as being somewhat childishly simple, but it genuine perplexes me! I have repaired several laptops before by removing a faulty capacitor that was short-circuiting the motherboard, whereupon the laptop would then work. For me, it begs the question that, if the current can bypass where the capcitor was when it has been removed, why didn't it just bypass it when it was present and faulty,? I can't get my head round the premise that if the other side of the capacitor is connected to ground, then why doesn't the current simply bypass...
    04-01-2025, 10:33 AM
  • amelbye
    degradation of solid state capacitors in motherboards?
    by amelbye
    Hi, I have a question regarding a motherboard with SS capacitors that I'm having trouble with. Every now and again it would give overclock failed at boot even when not overclocking.
    Recently more often, and the last few weeks at every single boot. It seems like the typical capacitors needing to warm up, then everything is fine.
    Weird thing is the capacitors are all solid state. Do SS capacitors degrade the same way as normal caps? Is it worth trying to recap the board?
    I have already replaced the PSU.
    The board is a gigabyte x79 ud3....
    11-06-2022, 10:35 AM
  • Tr0ll
    by Tr0ll
    Original T-con:
    First replacement T-con:
    10-07-2023, 07:48 PM
  • JJAAMM
    by JJAAMM
    Problem
    07-06-2023, 06:01 AM
