SMC7008VBR possible bandwidth management?
  • Behemot
    • 4845
    • CZ
    I have this quite old broadband router (it is SMC7008ABR, not VBR actually) with 10Base-T on WAN. I do'n have it plugged for some time now, but when I did, I noticed strange thing.
    The fact is, when connected to Catalyst 2950, I have been able to reach arround 2,3-2,4 MB/s average speed to one way (either uplink or downlink). This was really average, sustained during even several tens of minutes or hours (files tens of GBs big over FTP).
    Actual speed reading from Everest showed speed oscillating arround the 2,3-2,4 MB/s. Even the whole transfer time suggests the speed really was there (otherwise I would noticed transfering it for example hour instead of half an hour).
    Thas was happening for several months. So I expect the router actually has some kind of bandwidth management. If so, any idea which this may be?
  • DynaxSC
    Activation of Management Engine after exchange Z590 chipset - ASUS PRIME Z590M-PLUS
    by DynaxSC
    Hi, i have an ASUS PRIME Z590M-PLUS board, which had an shorted Z590 chipset. I have succesfully exchanged the chipset to a factory new one, however there is a serious problem with the Intel Management Engine (later on: ME) not beeing activated after the chipset device replacement.
    For lower chipset families (on ASUS boards) it worked to program the oldest bios version into the SPI rom, and the bios had activated the Management Engine itself by default - there was a message on the screen prior booting - "BIOS is updating Management Engine ..... . Do not shut down to prevent...
    06-10-2023, 11:30 AM
    AD7276, AD7277, AD7278, AD7274, AD7273​ Datasheet
    The AD7276, AD7277, AD7278, AD7274, AD7273 are 12-bit/10-bit/8-bit, high speed, low power, successive approximation analog-to-digital converters (ADCs), respectively. The parts operate from a single 2.35V to 3.6V power supply and feature throughput rates of up to 3 MSPS. The parts contain a low noise, wide bandwidth track-and-hold amplifier that can handle input frequencies in excess of 55 MHz.
    The conversion process and data acquisition are controlled using CS and the serial clock, allowing the devices to interface with microprocessors...
    10-07-2024, 05:32 AM
  • msnessay
    ASUS chromebook CR1100FKA with management acount
    by msnessay
    plaese remove entreprise management account from this chromebook asus...
    05-12-2024, 06:22 PM
  • corrize
    How to diagnose little step down and power management BGA chips never shorted
    by corrize
    I have different sort of those little BGA chips (step down DC-DC, power management battery, …) I replaced 10 on differents mobile devices (no schematics) but I noticed often they can be dead but never shorted. I see some signs : burn marks, resistance drop by comparison with good board (40 KOhms to 1 KOhms for example)… but not easy to be sure of the diagnose. Because I can't access on all tracks (balls) with the meter.
    Sometime, I know only after replacing chips.
    Do you have tips for diagnose please ?
    05-02-2024, 08:30 AM
  • DynaxSC
    GIGABYTE X299 AORUS ULTRA GAMING - SATA PORTS 4-7 NOT WORKING ???
    by DynaxSC
    I have the above mentioned bord after repair, which was related to a lot of missing smd devices on the back of the board.
    There were almost 20 devices missing, caps, resistors and some diodes/mosfets.
    The board is generally working now, all PCIe ports are working, Windows installs normally.
    However I have a problem with SATA ports 4-7 (the board has 8 SATA ports) - disks are not beeing recognized by the BIOS neither by Windows (which is usually normal in case BIOS does not recognize them).
    The SATA 4-7 driver network is quite simple chipset<->buffers/drivers<->SATA...
    03-10-2025, 12:27 PM
